Broken rear light assm mount on subframe
Discussion in 'Thumpers' started by TTU, Sep 27, 2020.
  1. TTU
    TTU n00b
    Apr 19, 2017
    8
    Well was having a great day riding today until I stopped and noticed my rear right turn signal was melting!!!! After close inspection I could see the whole taillight assm was hanging lower then normal. I headed back home and removed the rear fender and found the plate where the assm mounts broken.
  2. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    10,234
    Anchorage, formerly Spenard (hub of the universe)
    you can see the crack continue up the left side tube from the toe of the weld. pretty sure I see the same thing on the right side. I would put money on it. the other cracks are more obvious. all due to lack of post weld heat treatment/stress relieving.
  3. TTU
    TTU n00b
    Apr 19, 2017
    8
    So you are thinking factory failure? If its a bad weld then I suppose a proper weld is all I need and do not need to figure a way to better support this area.
