Building a New Garage in the Woods
Discussion in 'Shiny Things' started by ag_streak, Dec 2, 2015.
  1. silverbandit1
    silverbandit1 Adventure Dreaming..
    Jun 5, 2004
    1,374
    NorCal
    I wish I could have one built for that price here in California :bluduh
    What type of siding are you going with?
    #21
  2. ag_streak
    ag_streak Tiene Ruta Cuarenta?
    Aug 9, 2006
    5,848
    Blue Ridge, GA
    Dean O., you're in Copperhill? There's a meetup.com dual-sport group I've been riding with. We should get together sometime!
    #22
  3. ag_streak
    Aug 9, 2006
    5,848
    Blue Ridge, GA
    Going with 12" pine board and batten. That's 12" wide 3/4" thick boards placed vertically with 1x2 strips on every seam. Very common around here. The cabin is D-logs placed horizontally over traditional frame construction, not a true log cabin.
    With the brown metal roof and siding stained a similar color to the cabin, they will complement each other but not "match".
    #23
  4. JoshinBham
    JoshinBham fail
    Mar 21, 2008
    733
    Birmingham, AL
    That is awesome! I hope to follow in your footsteps one day.
    If I could find a 100% work from home gig, I would already have done much of the same.
    #24
  5. Deans BMW
    Deans BMW Granpa Hoon
    Feb 17, 2004
    5,927
    Copperhill, Tennessee
    Would love to, there are several like minded souls in this area that are on the Motorcyclist Café.
    Another fellow and I meet for breakfast at 8 in the morning in Blueridge at least once a week, PM me your phone # and come join us.
    When we moved up here 3 years ago, the place we found didn't have a garage either.........I built one and went from this,
    To this....took about two years to finish.
    Had a contractor dry it in and then I did all the rest. 32'x32', 2x6 walls, 10' ceiling, 12'x32' overhang on the left, 100 Amp service, enclosed toilet down stairs , full bath up stairs, ductless heat and air upstairs, kitchenette, cable, WiFi etc.
    Upstairs is a combo Man Cave/Den/Guest House.
    I use it as my Den......and where I take my Afternoon naps. :D
    #25
    Longbo, Benduro, Project84 and 4 others like this.
  6. bountybuddy44
    bountybuddy44 Adventurer
    Apr 1, 2014
    16
    Philippines and Michigan
    Great garage! Fantastic setting. My dream place. Enjoy every moment my friend. Ride safe.
    #26
  7. ag_streak
    Aug 9, 2006
    5,848
    Blue Ridge, GA
    Ho-lee shit! :clap :rayof :beer :super
    Color me impressed! That's AWESOME!!
    #27
    Longbo and Benduro like this.
  8. Deans BMW
    Feb 17, 2004
    5,927
    Lets have breakfast in Blueridge one of these days.
    #28
  9. Jetmech
    Jetmech Been here awhile
    Feb 25, 2009
    657
    Western MA
    If you don't mind me asking, why didn't you go with engineered trusses? That way you could get by without supports in the middle of the garage. Sorry if you covered this and I missed it.
    #29
  10. ag_streak
    Aug 9, 2006
    5,848
    Blue Ridge, GA
    Good question!
    So, my contractor is also a fireman. He said the metal plates used to construct engineered trusses get hot and curl in a fire, causing catastrophic roof failure. He said he HATES walking on the roof of a fire-damaged building because he's seen the entire roof collapse even if the wood of the trusses wasn't burnt through.
    The supports in the middle of the garage weren't a result of stick-building the roof. It was a late design change on my part, but one I'm really happy was made. By adding the wood-floored "extension" attached to the slab and overhanging the slope, the footprint went from 22' x 24' to 30' x 24'! :clap The slab was as big as could fit on the site, so adding the wood floor extension was a way to increase the size.
    If we had planned it from the beginning, we probably could have designed it for engineered trusses, if desired.
    #30
    Benduro likes this.
  11. ag_streak
    Aug 9, 2006
    5,848
    Blue Ridge, GA
    PM sent! :freaky
    #31
  12. Deans BMW
    Feb 17, 2004
    5,927
    Got it and sent you a reply, left my cell# and left a message on your phone.
    My friend and I are having breakfast at 8 AM at the Bumblebee across the 4 lane from Engles just east of the Yamaha/Polaris shop.
    If you can, join us.
    #32
  13. FrankS
    FrankS ...please wait...
    Sep 27, 2007
    443
    Austin, TX
    if the whole house is on fire do you really have to worry about catastrophic roof failure because of curled up metal plates? but i guess that's how a fireman sees it....
    #33
  14. Dr Klaun
    Dr Klaun Been here awhile
    Jun 1, 2007
    625
    Tumalo, OR
    Nice clean build. One question I have is about the tall earthwork cut on the house side of your garage. Is this retained in any way? Looks a bit steep to leave exposed. I'd also add some drain tile along your slab edge on that side since that spot will fill up with run-off.
    #34
  15. TheMuffinMan
    TheMuffinMan Forest Ranger Magnet
    Mar 31, 2010
    8,792
    Grand Junction, CO
    That's really not too bad considering. Really sweet!
    #35
  16. ag_streak
    Aug 9, 2006
    5,848
    Blue Ridge, GA
    Well, it's rock-hard Georgia clay and erodes very, very slowly, but I do plan to address that with planting.
    As for the drainage, I got that covered. There's a foot-thick layer of #57 gravel leading back to a 10" drainpipe, but a lot of it was disturbed by the excavation, so I'll throw another ton or two on it.
    That side doesn't get as much runoff as you'd think. The big drainage problem is on the front, because the water runs down the driveway towards the garage. Hence the French drain in the apron.
    #36
  17. Fire Escape
    Fire Escape Long timer
    Apr 13, 2007
    2,799
    Epsom, NH
    I am with your contractor on this one! The plates attach with rather small 'protrusions' into the wood members of the truss. Being steel they absorb heat quite well and transfer it through those 'protrusions' to char the wood. Being pretty much triangular in shape it doesn't take much 'char depth' for the plates to essentially fall out. If you go through the effort of renailing all those truss joints with conventional nails before using them, they are not a great hazard in a fire although the construction is still pretty light compared to stick built. It's not about what survives if the place is totally engulfed in flame, total loss is total loss regardless. It's more a localized fire generating enough heat that the whole roof goes to pieces or is weakened to where it can not be safely approached to repair.
    Bruce
    #37
  18. ag_streak
    Aug 9, 2006
    5,848
    Blue Ridge, GA
    ^ ^ ^ I think his main concern was the safety of firemen who have to walk on the roof, after the fire is out. Doesn't have to be a total-loss situation. I guess the roofs can fail when those plates are overheated, even if the whole building doesn't burn down.
    #38
  19. SafetyThird
    SafetyThird Pist-n-broke
    Jul 28, 2010
    9,271
    Hopkinton, MA
    It seems a bit much to worry about to me.
    #39
    BikerBobber likes this.
  20. ag_streak
    Aug 9, 2006
    5,848
    Blue Ridge, GA
    The last few days were a deluge of rain, but it stopped last night and this morning dawned dry and chilly (34 degrees). The guys got back to work framing the wood “extension”.
    This is how it was framed.
    First they framed the far wall, which will have 4 windows facing the forest.
    Then the side walls, with one window each, and the rafters.
    And most of the roof sheathing went on today.
    Looking good so far. One more day of framing and sheathing, and it’ll be ready for the windows and metal roofing.
    #40
    Benduro, Deans BMW and Shivanshu like this.
