Building a sidecar "camper".
Discussion in 'Hacks' started by doublemocha, Nov 11, 2015.
  1. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    11,973
    Minnesota
    That will probably require a BMW tech and new brake light switches it's not than easy with the IABS
  2. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    10,130
    Tacoma, WA
    ABS delete - confused as to what year you are working with? Did you buy a GSA and you're swapping parts over from the burned out wreck, or are you rebuilding the burned out wreck by swapping parts in from an intact GSA? And what years are they?
    My 2004 GSA had the ABS delete and I don't think it required much to do it.
    Also, @doublemocha , I have a 2.82 31/11 final drive here I can send you (free plus shipping) but that's probably going too far in the other direction. But PM me if you want it, or e-mail--you have my e-mail address from before.
    Bobmws, FLYING EYEBALL and davebig like this.
  3. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    Los Angeles, California
    I am putting together one bike from 2 salvage bike. They are 2004 1150gsa, I am using the transmission from the burned bike (my bike) everything else from the salvage bikes plus other used parts. My first time doing this so I do a lot of googling and watching you tube If you have a link on how to delete the ABS please send. I think the hydraulic is easy, basically by pass the ABS and go directly to the to the brake cylinders. The bigger challenge and I still do not understand is the electrical. I will send you a PM. thanks
    FLYING EYEBALL likes this.
  4. davebig
    Jan 19, 2004
    11,973
    Minnesota
    On replacing the power brake iabs it takes 2 new brake lite switches as the ones on the iabs bike operate backward they are open and close on application, and I believe some wiring needs a work around.
  5. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    10,130
    Tacoma, WA
  6. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
  7. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    Making progress, working on the EZS leading link today.
    Jim K in PA, Bobmws and draperg1 like this.
  8. brstar
    brstar Long timer
    Aug 17, 2007
    3,129
    Shoalwater Western Australia
    Your having a serious go at this.
    Very impressive.
    doublemocha likes this.
  9. Jim K in PA
    Jim K in PA Long timer Supporter
    Mar 15, 2011
    5,697
    Pocono Mountains, PA
    What is that rear wheel from? Love it.
  10. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    RidgeRunner56 likes this.
  11. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
  12. High Octane
    High Octane Long timer Supporter
    May 31, 2013
    3,200
    South Dakota
    Did you modify your telelever?
  13. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    I reinforced it with 1/4" metal plate on top and below. It is over build
    High Octane likes this.
  14. High Octane
    May 31, 2013
    3,200
    South Dakota
    Can you measure your wheel base, axel to axcel for me? I'm working through fitting up DB's leading links to my 2004 GS. My wheelbase ends up at 66.5 inches.
  15. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    mine is 66" center to center wheelbase.
  16. High Octane
    May 31, 2013
    3,200
    South Dakota
    Thanks. Mines not so far off then
    FLYING EYEBALL and doublemocha like this.
  17. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    Trackwide 49.5 inches, Two connected fuel tanks 6 x 13 x 19 inches. I am not using the OEM fuel tank to lower center of gravity and put weight on the sidecar also for easy access to the engine and other stuff.
    phughes and High Octane like this.
  18. davebig
    Jan 19, 2004
    11,973
    Minnesota
    I'm sure there's a suggested weight split someplace, I'd ask Claude when sidecars get too heavy they shove the tug around, but 1150s are fat old girls.
  19. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    Hope Claude chims in here. I think he already chimed in earlier. This cause me to split the tank in two to put more weight in the rear. see picture below on my original design. I am not doing the transfer tank idea the two tanks are connected together with three 3/4" fittings and hose. I also installing a 43PSI fuel pump to push the fuel to the engine. thx
    Bobmws likes this.
  20. High Octane
    May 31, 2013
    3,200
    South Dakota
    Good work. Keep going. Stay a couple steps ahead of me so I can steel your ideas!
    Ridn3 likes this.
