Building a sidecar "camper".
Discussion in 'Hacks' started by doublemocha, Nov 11, 2015.
  1. GotDammitDave
    GotDammitDave Been here awhile
    Jul 27, 2016
    327
    Newport,NC
    Those look simple to make, have/did you ever take apart the first one you wore out to see how it's made?
    Even if you are good at reverse engineering!
  2. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    Los Angeles, California
    Hi Claude, great to hear from you. I will check tire pressures and toe in. As I said earlier I like the way it is handling with the new track wide 51”. I think the gas tank on the sidecar is also making a difference. I will do more test ride today. Thx for you help and Happy holidays!
    claude stanley likes this.
  3. 3legs
    3legs Real men ride sidecars Supporter
    Oct 3, 2007
    3,589
    Adelaide,South Oz
    " Those look simple to make, have/did you ever take apart the first one you wore out to see how it's made? "
    No never did. It just blew a seal so I just put the spare on. At that price I didn't bother with it.
    GotDammitDave likes this.
  4. ErictheBiking
    ErictheBiking Been here awhile
    Feb 28, 2008
    373
    Queensland, Australia
    Phil made this for the S10
  5. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    Thanks Davebig, I am thinking of changing my final drive with 1100GS i will post on the part section if one is available. I wonder if there is other opinion on this. Since test driving my rig I notice that the 850 final seems to be too low. Thx
  6. brstar
    brstar Long timer
    Aug 17, 2007
    3,134
    Shoalwater Western Australia
    Saw this 1150 GS minus the tank.
    He has a fuel bladder strapped were the tank was.
    Cut 41kg of the bike.
  7. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    Found a 33/11 final drive. Pls see picture there is a stamp on it that says 33/11. Just want to make sure the stamp confirm that it is 33/11.
    rg sw wa. likes this.
  8. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    11,973
    Minnesota
    That should be correct turn the pinion 3 times crown gear should go around once. DB
    draperg1, Bobmws and rg sw wa. like this.
  9. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    Ok problem is i don’t have it with me, I am buying it.
  10. davebig
    Jan 19, 2004
    11,973
    Minnesota
    that's marked correctly
    doublemocha and rg sw wa. like this.
  11. rg sw wa.
    rg sw wa. Long timer Supporter
    Feb 9, 2011
    2,048
    Southwest Washington
    Have the seller do it to confirm gear ratio.
    doublemocha likes this.
  12. DRONE
    DRONE Dog Chauffeur
    Oct 1, 2007
    10,131
    Tacoma, WA
    There's another way. That stamp is on the casing. Not likely but it's possible that at some time in the past a previous owner swapped out the gears. What you want to do is have the seller send you a picture of the stamped numbers in the end of the pinion gear. Like this -->
    See where it says 2.82? That tells you it's a 31/11. A 33/11 will say 3.00.
  13. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    8,010
    Fort Collins, CO
    Usually the owners won't bother with the time and effort it takes to replace the gears (expense) and will just replace the whole drive from a wreck.
    rg sw wa. and doublemocha like this.
  14. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    Thx the seller just confirm it turn at the ratio of 3 to 1. I just purchased it. Thanks for your help.
  15. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    I have a stupid question but i want to make sure. I am adjusting the valve tomm. I have read the manuals and watch videos. My question is this; when i set the bike to TDC do i adjust all the valve (left and right side) with out turning the engine again. None of the videos or the manual talks about turning the engine again after adjusting one side. Thx better be stupid than sorry
    rg sw wa. and brstar like this.
  16. brstar
    brstar Long timer
    Aug 17, 2007
    3,134
    Thinking that one through now.
  17. davebig
    Jan 19, 2004
    11,973
    Minnesota
    Oh come on :fpalm Put cylinder you want to start on on TDC piston at top both valves closed, I usually remove plugs and and stick a skinny screwdriver in plug hole and turn engine with bolt in end of crank under alt belt cover rather than looking for timing mark. Find the tdc both intakes and exhaust should be loose and ready to be adjusted.
  18. Bobmws
    Bobmws Curmudgeon At Large
    Jun 6, 2005
    4,816
    Same trailer, different park, FL
    Don't use the starter to turn the engine when finding TDC.......
  19. Pokie
    Apr 4, 2013
    8,010
    Fort Collins, CO
    With the valve covers off, rotate the engine until you see the intake valve open then close, you are now approaching TDC for that side. After setting the valves for that side, you will need to rotate the crank 360 degrees (or one complete revolution) to do the other side.
  20. draperg1
    draperg1 PapaBear Supporter
    Mar 31, 2013
    900
    Martinsville, VA
    I did have my LT FD rebuilt with a set of 3:0 gears so sometimes......
