Building a sidecar "camper".
Discussion in 'Hacks' started by doublemocha, Nov 11, 2015.
  1. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    Los Angeles, California
    Thx, this is exactly what i needed to confirm.
  2. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    Valve adjustment and carb synconization done. There is a little surging i will observe this for a while and figure out what is causing it.
    I also replaced my final drive to 33/11. Taking it out for a test drive today. Thx
    draperg1, rg sw wa., DRONE and 2 others like this.
  3. Pokie
    Pokie Just plain Pokie.
    Apr 4, 2013
    7,827
    Fort Collins, CO
    The valves should be set at .15mm and .30mm (or .006" and .008"), that doesn't appear to be what you are setting yours at. A minor amount of surging can often be addressed to spark plugs. Try a different brand.
    draperg1 and rg sw wa. like this.
  4. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    11,920
    Minnesota
    Ok well 1150's didn't really have a surging issue and the .15mm and .30mm should be .006 and .012 https://www.manualslib.com/manual/884258/Bmw-R-1150-Gs.html?page=104
    Surging is caused by overly lean conditions and 1150 doesn't really have much history of it , since you've changed the fuel system my first thought is fuel pressure changing low fuel pressure would cause a lean condition.
  5. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    That is what i set the valve .30mm exhaust .15mm at intake. I used NGK spark plugs.
  6. Pokie
    Apr 4, 2013
    7,827
    Fort Collins, CO
    Sorry, I was going by the color of your feeler gauges. They are expensive, but I have found the surge is gone with Brisk plugs. Mind you, this is on a R1200C.
  7. davebig
    Jan 19, 2004
    11,920
    Minnesota
    :fpalm:fpalm the gsa is a dual spark it shouldn't have plug issues like the single spark r1100 and R1200c, it could stagger a little if it has the original stick coils in the center position most of them where made in India and eventually operated erratically . If it had a ignition issue that's it https://www.ebay.com/itm/Stick-Coil...820683&hash=item3b222e2a19:g:DM4AAOSwBMpb6NQx
    When they fail one gets a intermittent miss/
  8. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    338
    The two oil cooler is making the engine run cooler, it took about 45 minute riding on stop and go traffic to get to 5 bars, the bar goes between 4 and 5. I will observe the other issues for a while and address them later. Thx
