Building a sidecar "camper".
Discussion in 'Hacks' started by doublemocha, Nov 11, 2015.
  1. claude
    claude Sidecar Jockey
    Mar 17, 2002
    5,756
    Middleburg, Pa. (Snyder County)
    Yikes
    #81
    Dan Alexander likes this.
  2. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    204
    Los Angeles, California
    i am paying $350. delivered to my home
    #82
  3. claude
    Mar 17, 2002
    5,756
    That sounds much better. Make sure they are prepping the metal well by blasting or dipping it.
    #83
  4. Salsa
    Salsa Long timer
    Dec 12, 2006
    1,213
    Arizona, Alaska
    I had a mini pickup that I put a camper shell on it. I used a blue tarp and framing for the sides. Then I headed to Alaska. After 400 miles of horrible noise I bought masonite and covered over the blue tarp to kill the noise.
    I hope yours is better.
    Don
    #84
  5. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    204
    yes sand blasting and priming
    #85
    brstar likes this.
  6. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    204
    delivered this morning 33 pieces .... looks good, covered up my ugly weldings nicely.
    #86
    claude likes this.
  7. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    204
    i will try switching out the abs ring with mine see if that works, according to the dealer my abs unit is shot, so i will take you up on your offer of free abs unit :-)
    #87
  8. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    204
    assembly is much easier, don't miss all the grinding and the welding. i think i have decided on a canvas sides for the tub, more to come on that later.
    #88
  9. Hookalatch
    Hookalatch Born Under Bad Sign
    Feb 8, 2006
    1,044
    Cottonwood, CA
    Have enjoyed following the progress you have been making. Your doing a great job and look forward to see the (near) end result.
    #89
  10. Zoef zoef
    Zoef zoef Long timer
    Apr 19, 2009
    1,146
    Finnøy Island, near Stavanger, Norway
    When removing the abs unit, just remove the mechanical part and leave the "brains". Then brake lights will work normally, onle the abs warning light has to be removed from the dashboard. This is the "steptoe" method.
    #90
  11. claude
    Mar 17, 2002
    5,756
    Black duct tape. The NASCAR method. :-)
    #91
  12. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    10,426
    Minnesota
    Ok Dave the iabs pump from my 04 GSA is on its way, priority mail. http://modulemaster.com/rebuilds/abs-modules/
    These guys rebuild the newer and older versions but not the ones you or I have.
    I second the remove the ABS option mentioned earlier or at least researching removing it but the brake doe need to be replumbed, I did this at 82 k miles as the bike was all apart anyway.
    #92
    Bobmws likes this.
  13. Bobmws
    Bobmws Curmudgeon At Large
    Jun 6, 2005
    3,923
    Same trailer, different park, FL
    Your HP has this removed also, is the K system similar? (saved for future reference!)
    #93
  14. davebig
    Jan 19, 2004
    10,426
    Minnesota
    Yes Bob just packaged different, but on the K's they run the cruise control and speedo thru the printed circuit board in the ABS module,( look in a service manual at the electrical diagram, you'll be swearing) so I think they leave the pump in place turn the power off to it and replumb the brake lines in a conventional manner and "Bob's your uncle "
    On the GS they changed brake light switches and hook some wires together remove the pump and replumb no speedo or cruise.
    I wonder if the next generation module could be made to work 07 and later as those are rebuild-able. F**kin BMW and their consumers who demand the latest in technology ! It's not your uncle Bob's pathetically simple and reliable old airhead !
    #94
    Bobmws likes this.
  15. claude
    Mar 17, 2002
    5,756
    On going joke is those Nazis are still trying to get back at us. LOL. Seriously...Most manufactures today want you to bring stuff to the dealership to work on it.
    #95
    davebig and Bobmws like this.
  16. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    204
    Thanks davebig, yes got the ABS pump sorry i have not been able to follow these very helpful post . it is exactly same as mine (see picture). i am still deciding on the option i just have a few questions and still researching. one question is; if i took the ABS out will the front and rear brake on my 04 r1150 gsa continue to be link?
    i will admit, going to a simpler system by removing the ABS and getting 7 pound lighter is an attractive option.
    #96
  17. Crilly
    Crilly Long timer Super Supporter
    Dec 12, 2005
    1,136
    Wi
    Ceconite would work well for covering.
    #97
  18. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    204
    very interesting stuff, i have started researching, wish i knew about this before i started on a path. see picture below, i have attached an "awning rail" at the bottom of the tub that will allow the canvas to slide out or removable. i am open to the ceconite option, i know it will not be removable but i like that it will shrink tight. i need to find out if i can attach it to the white polyester that you see on the picture. that is where the canvas was going to attach as you can see i am trying to illustrate on the picture. thx canvasside.jpg
    #98
  19. Dexter!
    Dexter! Long timer
    Mar 13, 2012
    1,261
    Buenos Aires, ARG.
    Interesting idea... :lurk
    #99
  20. doublemocha
    doublemocha Nulla
    Nov 4, 2013
    204
    ceconite is great but i am too far along on the canvas set up so i will stay with the canvas. ceconite would have been a real option if i was not this far along. thx Crilly. her is what i did today. i was not that sure about the skid plate cause it added more weight but i can always take it out. assembled front.jpg assembled rear.jpg assembled skid plate.jpg
