Building the Ultimate Adventure bike for me
Discussion in 'Some Assembly Required' started by racingxtc7, Jan 19, 2015.
  1. cachorroLOUCO
    cachorroLOUCO Banned
    Mar 11, 2015
    323
    Curitiba,Brazil
    subscribed. that's the kind of stuff i signed in for:ear
    #61
  2. RBnite
    RBnite Been here awhile
    Feb 28, 2012
    189
    Down by the river
    Notice you had to cut the frame. I know you did that to get the engine to fit but, what exactly needed to be moved, cut, repositioned.
    #62
  3. racingxtc7
    racingxtc7 Been here awhile
    Dec 31, 2014
    158
    Kenosha Wisconsin
    I'll take some pics and post them for you.
    #63
  4. racingxtc7
    Dec 31, 2014
    158
    Kenosha Wisconsin
    #64
  5. TheCheesus
    TheCheesus Killing time
    Jun 25, 2011
    141
    Indianapolis, IN
    your seat seems to be made of woven gold.
    Hard to tell from the pics, did you only have to notch the frame on one side? Assuming with the wider motor you had to push the motor towards the right (from the rider's position) to get the sprocket inside the frame rail.
    could you snap a pic looking straight on from the back? I'd like to see the width / sprocket alignment.
    Is there any particular reason you went with the Ninja 300 motor vs the CBR250R (proven in the CRF250L) thumper, which is bound to be a bit narrower? If the power lust got you, any reason the Ninja would be better than the CBR300R powerplant? My brother has a new-to-him CRF250L and I've ridden a CBR250R a few times and was surprised at the smoothness despite the single cylinder.
    #65
  6. racingxtc7
    Dec 31, 2014
    158
    Kenosha Wisconsin
    The engine is centered but I'll probably have to get a custom offset front sprocket to align the chain. The motor isn't that much wider and the notch in the frame on the right side is for the bump on the valve cover for the cam chain. I could have gotten away without the notch but I wanted the motor as far back in the frame as possible.
    The ninja 300 motor is a great motor and is basically a stroked ninja 250 which has been around for decades. I've ridden Ninja 250/300s and they're great on the highway and are super smooth.
    For this build, I wanted a twin cylinder, street bike engine because of the smooth running, power and wider rpm range. I've been debating installing higher compression pistons, cams, porting and power commander which should bump the horsepower up to 45-50hp but I don't want to give up much reliability or gas mileage.
    #66
    TheCheesus likes this.
  7. racingxtc7
    Dec 31, 2014
    158
    Kenosha Wisconsin
    I installed the seat on my CRF450R dual sport for a test fit. It feels really nice.
    before:
    After:
    #67
  8. cachorroLOUCO
    Mar 11, 2015
    323
    Curitiba,Brazil
    Def not a fan of the seat,but at 19yrs old,i still can afford to ride all day on a 10cm wide, thin piece of foam that some joker had the nerve to call a seat :lol3 looks more than comfortable :D
    #68
    mglsite likes this.
  9. BlueLghtning
    BlueLghtning Riding is my passion
    Feb 16, 2004
    6,239
    Peachtree City, GA and Full Time RV Travel
    Enjoy it while you can. :lol3
    I'm about to be 40 and I'm totally having seat envy on that dual Russell Day Long seat. I've had a Russell Day long on all 5 of my Vstrom's since 06 and ever since then, other seats just don't match up. My WR250R with a Renazco seat isn't bad, but I'd be lying if I didn't admit I'm constantly lusting after putting a Russell on it.
    #69
  10. NortwestRider
    NortwestRider TRIPOD ADVENTURER !!
    May 25, 2008
    5,138
    3.7 miles North of Hell...SEATTLE....
    A new seat to fit my fat ass is the #1 thing on EVERY bike..
    Live life,be yourself !!!!.
    #70
  11. cachorroLOUCO
    Mar 11, 2015
    323
    Curitiba,Brazil
    :lol3 will do. Check out my current seat. It's kinda ckmfortable but it's slippery,i need to change the cover for anti slip one
    #71
  12. Te Hopo
    Te Hopo Nomad
    Sep 25, 2007
    2,429
    Marlborough, New Zealand
    Yea, I'm not a fan of that seat design so I'd choose a Seat Concepts myself.
    But I do love the rest of the bike, it's about time someone posted a 300 build here. :clap
    #72
  13. racingxtc7
    Dec 31, 2014
    158
    Kenosha Wisconsin
    This custom seat is going to be for cross country rides and I have a stock seat that will be on it most of the time.
    #73
  14. RBnite
    Feb 28, 2012
    189
    Down by the river
    So Cool!! Keep going!
    #74
  15. sonic reducer
    sonic reducer Been here awhile
    Aug 19, 2007
    606
    SeaTac WA
    sorry if I missed it but are you using the engine as a stressed member? was there any possibility to get the engine into the stock cradle?
    what are you planning to run for an airbox? and how do the throttlebodies fit? must be tight under there.
    #75
  16. Navin
    Navin Long timer
    Sep 22, 2009
    28,723
    Pod filter on the 300 engine can only be described as
    TOO BLOODY LOUD!
    I hated it so much I bought an air box off eBay and reinstalled it. Total pita but GAWD it was stupid loud.
    #76
  17. racingxtc7
    Dec 31, 2014
    158
    Kenosha Wisconsin
    Yes, the engine will become a stress member. Making some pretty heavy duty motor mounts. There is no way to make the stock cradle fit. I'm going to use the stock crf450 air box but remove the rubber boot, install a plate and have tubes going from the plate to the throttle bodies, one on each side of the shock and use a shock with a remote reservoir. The frame does have to be pocketed on the inside of the rails to fit the throttle bodies. Lots of work.
    #77
  18. TheCheesus
    Jun 25, 2011
    141
    Indianapolis, IN
    Thanks for clearing that up! Your reasoning-fu is strong and I'm loving the way the build is going. Keep up the good work!
    #78
  19. slowpoke69
    slowpoke69 Been here awhile
    Feb 2, 2010
    827
    So. Jersey
    This looks interesting, not anything my big ass could ride, but looks like it's going to be great for a smaller rider than me. At 6'1"/ 250 I'd look like a gorilla on a tricycle. That seat has me though, it looks like a big comfy couch, in a good way though!
    I like this kind of build, not too many understand why we would do this, just take seemingly random pieces and make it work. It's a feeling of accomplishment, some pride too, for me at least. To know that you gave it life, is a cool feeling.
    Can't wait to see the end result. I'M IN!!
    #79
  20. racingxtc7
    Dec 31, 2014
    158
    Kenosha Wisconsin
    Thanks guys. I'm trying but slow process. The shock came in this week.
    #80
