Bulb holders
Discussion in 'Airheads' started by CAW, Jul 9, 2018.
  1. CAW
    CAW Been here awhile
    Sep 4, 2010
    157
    I am reinstalling a stock gauge cluster on my R65. I am wondering if anyone has a good source for bulb holders for the instruments. Th three I am looking for are the backlight bulb for the speedometer and the two indicator bulb for the turn signals. OEM and alternative suggestions welcome. I was looking at the Volkswagen Beetle bulb holders as they look similar, but thought I would ask about other’s experience before I started experimenting.
    Cheers,
    CAW
  2. georgesgiralt
    georgesgiralt Been here awhile
    Aug 12, 2012
    223
    Hello,
    I bought some from one of the usual suspects but can't remember which one? They are NLA at BMW.
  3. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    14,577
    Silver Spring, Md
  4. Geezerrv
    Geezerrv Been here awhile
    Mar 6, 2015
    508
    MO Ozarks
    I used a VW holder in I believe the clock. My memory is poor but I know I robbed it out of my beetle.
    CAW likes this.
  5. 190e
    190e Long timer
    Feb 20, 2013
    1,751
    England
    CAW likes this.
  6. CAW
    Sep 4, 2010
    157
    That is the part I’m looking for. I’m in the New England. Maine to be exact. I’ll see if I can find a stateside seller. Thanks for the info.
  7. CAW
    Sep 4, 2010
    157
    Thanks. I’ve looked through the Kat dash products before. Unfortunately, like many of he things on the early r65, the dash is different from other airheads and his products don’t help me.
  8. georgesgiralt
    Aug 12, 2012
    223
    While you are at it, I kindly suggest that you put LED bulbs in the speedo and tacho for general illumination. And buy a couple of small LED bulbs from Katdash for the clock and voltmeter. This way, you will SEE the exact speed you are driving and the odometer...
    Pay a special attention when you get the LED bulbs that they may cause a short into certain bulb holder and find a way to attach the bulb to the socket for the speedometer. Mine got into the speedometer and I had to open it up to recover the bulb... a PITA.
    I hope this helps.
    #8
  9. CAW
    Sep 4, 2010
    157
    Thanks. I’ll probably stick with the old fashioned hot wire bulbs in the speedo, and I don’t have a voltmeter or clock. I don’t use the speedo for much other than checking my speed if I see police or if someone is on my tail to see if I am riding too slow. Plus I find a darker dash improves my vision on the road (I live where there are few streetlights). 28 years of riding the same bike has given me a sense for how the bike should be sound and feel in certain environments. I am going to put some LED bulbs in the turn signal indicator spots to be sure it catches my attention if I leave one on. Thanks again for the info,
    CAS
    #9
  10. Geezerrv
    Mar 6, 2015
    508
    MO Ozarks
    I had an issue of all 4 LED t/s bulbs flashing due to current crossing the single indicator bulb in the cluster. I added 2 small diodes to cure it. (83 RS)
    #10
    CAW likes this.
