BW80 aka “The Witch”
Discussion in 'Some Assembly Required' started by greasyfatman, Dec 3, 2020.
  1. greasyfatman
    greasyfatman Long timer
    Oct 18, 2014
    5,153
    The china casting are very porous and the ports are in deferent places, like snow flakes no two are alike. Get some porting tools have some fun.
    the lighting coil is on my mind two, we night ride with enduro helmet lights.
    #41
  2. dbarale
    dbarale Squiddly slow
    Oct 20, 2008
    3,053
    Western NC
    Please post about this when you get to it as my kid wants to go trail riding on his PW80 and I would like to get him some lights for safety.
    #42
  3. greasyfatman
    Oct 18, 2014
    5,153
    Will do. For now we have been using these
    https://www.rockymountainatvmc.com/riding-gear/tusk-helmet-light-kit-p
    @RMATVMC
    I haven’t got many cycles on the batteries but they last a long time. And throw great light. More power than I will get out of a coil.
    I had thought about cyclops blinkers and kit to look street legal just to be ridiculous
    #43
    dbarale likes this.
  4. bikerbill2021
    bikerbill2021 Adventurer
    Oct 10, 2014
    29
    Phoenix AZ
    Ah gotcha, yea I'm not too worried about bottoming out, I know it will but the bike isnt going to stray too far from my camp site and I can always add a shock later, I plan on moving the mounting point up a bit to raise it a little bit, but nothing extreme, just gonna be a camp bike putter with a bit more pep, something different
    #44
  5. greasyfatman
    Oct 18, 2014
    5,153
    got some blue BW80 stickers
    #45
    Nathan_66 and Pezz_gs like this.
  6. bikerbill2021
    Oct 10, 2014
    29
    Phoenix AZ
    Dude that looks great! I'm sure you already answered this, but where did you get the black plastics/tank? or did you paint over the OG plastics?
    #46
  7. greasyfatman
    Oct 18, 2014
    5,153
    Tank is a white tank that I boiled with rite dye and Acetone. Plastics came from BW conversion
    https://www.fattireconversions.com/mobile/mbw80parts.html
    #47
    bikerbill2021 likes this.
  8. greasyfatman
    Oct 18, 2014
    5,153
    Got bark buster s fitted. I couldn’t find the barkbuster brand thats on the other bikes. Need to get longer screws. Going to mount a light between the guards.
    #48
  9. greasyfatman
    Oct 18, 2014
    5,153
    I got a 20mm mikuni and a scooter pipe to play with. Stll have to do more base line testing before I can make big changes.
    started a conversation with HPI to find a different ignition with lighting coil. Think I might put a ridiculously bright @Baja Designs light on the front.
    #49
    Nathan_66, Pezz_gs and spokester like this.
  10. bikerbill2021
    Oct 10, 2014
    29
    Phoenix AZ
    Keep it up, I just started my BW resto and am always curious what others come up with for hopping up these little bikes :thumbup
    #50
  11. greasyfatman
    Oct 18, 2014
    5,153
    Going to widen the id of the exit pipe. Cutting some take off handle bars to fit the bends. Then I will do some more testing. Also going to make an intake I have the plate laid out will try to get it cut out today. Need to make a flange for vm20 carb also.
    #51
  12. greasyfatman
    Oct 18, 2014
    5,153
    So anyone have ideas on jet size for the vm 20?
    vm 16 i run 20p and 135m
    going up the VM20 any idea what I should use in 20 or a range to buy?
    #52
  13. greasyfatman
    Oct 18, 2014
    5,153
    And this showed up today
    #53
    Pezz_gs likes this.
  14. bikerbill2021
    Oct 10, 2014
    29
    Phoenix AZ
    What is that? Lighting coil and heavier flywheel? Adjustable timing plate? I'd be interested in all that, the crank out of my bike (and the cases for that mater) are hosed, total corroded and been in a swamp for 20 years, so either ill have to run the PW80 ebay crank I have with the 18 degree offset for the timing and notch the stator plate to compensate, or pick up a used BW80 crank and rebuild it
    #54
  15. bikerbill2021
    Oct 10, 2014
    29
    Phoenix AZ
    Heres what I'm working with lol, rust and mud
    #55
    greasyfatman and villageidiot like this.
  16. greasyfatman
    Oct 18, 2014
    5,153
    PW80 cases and crank will work stock ebay or buy yourself a PW80 crank
    but thats a daunting starting point.
    #56
  17. greasyfatman
    Oct 18, 2014
    5,153
    Thats the HPI ignition. If I don’t go to loretta lynns i will be playing with the ignition this weekend.
    #57
  18. Mr. Fixit
    Mr. Fixit Reevaluating
    Jan 11, 2008
    8,153
    SWVA
    That'll buff right out.
    #58
    greasyfatman likes this.
  19. greasyfatman
    Oct 18, 2014
    5,153
    What can rust other than bearings? I think you can salvage that. Millennium can dam near fix anything. Oh or maybe re key or press the china crank with the left half of the stock crank. I have a china crank, shipping plus 10$
    #59
  20. bikerbill2021
    Oct 10, 2014
    29
    Phoenix AZ
    Already got a set of PW cases on order from ebay, and I have a new crank kit sitting here from way back, not worth it to me to try and salvage that crank or cases, started blasting them and that made it worse, rather spend some money now and get it all right then be messing around with it when I want to ride it, parts are cheap for these things
    #60
