1. eNewsletter Sign Up
CA to Pittsburgh on a CSC
Discussion in 'Americas' started by Spoilyfarts, Jul 24, 2019.
  1. darmst6829
    darmst6829 Been here awhile
    Jul 25, 2006
    563
    Ocean Shores WA
    Yah and it was brand new as in first ride.
    #61
  2. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    19,724
    Villa Maria Sanitarium, Claremont, CA. USA
    Were you using it as designed or using it as a MX bike with 300 pounds on it? Sounds awful...but at least brand new it was under warranty.
    #62
  3. darmst6829
    Jul 25, 2006
    563
    Ocean Shores WA
    I was trail riding. I replaced the bars and adjusted the spokes then sold it. I am 6'2" 200lbs I get the wheel spokes needed to settle and be adjusted but I don't think it's normal in one ride.
    #63
    dp064 likes this.
  4. Spoilyfarts
    Spoilyfarts whomp whomp
    Feb 28, 2018
    76
    Pittsburgh, PA
    Those that ride CSCs (specifically the 250s) - how accurate were the mileage estimates from CSC? What do you generally get when you're fully loaded?
    The SG250/TT250 literature says they get ~60-65mpg - how realistic is that with what you find? We're estimating/planning fuel stops based on 50mpg. Should we estimate lower?
    #64
  5. ChopperCharles
    ChopperCharles Long timer
    Jun 7, 2006
    4,741
    Durham, NC
    To that end, also find out the speedometer error. My SSR was off 6.5 percent, and the gas mileage was calculated from the speedometer reading not from actual miles traveled. I went from a measured 60-65mpg to 56-61mpg just by correcting the speedo ratio. And then a k&n and aftermarket exhaust reduced that even further.
    So keep that in mind too when planning gas stops. Distances on the odometer may not match up with distances on the map.
    Charles.
    #65
    Spoilyfarts likes this.
  6. Spoilyfarts
    Feb 28, 2018
    76
    Pittsburgh, PA
    Was that a gear change to adjust the ratio or did you just calculate it differently? I wasn't expecting this to be an issue for fuel mileage, but it does make sense.
    Luckily, we won't need to really rely on accurate fuel estimates until the second day as we will be tooling around LA for the first day. Hopefully we can get a decent idea of mileage before heading out to Death Valley.
    We're also planning on carrying extra fuel for the LA to Mahogany Flats to gas to Rachel to gas legs of the trip.
    #66
  7. TUCKERS
    Dec 23, 2005
    19,724
    In my experience with a vast array of vehicles the speedometer was often off but the odometer has always been spot on. There would be a huge law suit if the odo was off, regarding mileage reporting, servicing and warranty.
    #67
  8. ChopperCharles
    Jun 7, 2006
    4,741
    Durham, NC
    On my SSR, it uses a common universal speedometer which was reconfigured as an OEM unit. (Different trip meter location and a slightly different software). I was able to enter service mode and reprogram the ratio for my bike. But if I didn’t have that ability, I’d have bought a universal speedo healer and wired it into the harness.
    That’s what I plan to do for my Yamaha.
    FWIW my odometer was off just as much as the speedometer, because it is all controlled by that ratio setting.
    Charles.
    #68
  9. dp064
    dp064 Adventurer
    Nov 11, 2019
    69
    Nashville
    I have a '19 SG.
    I think 50 mpg is conservative.. I've not measured a tank and got less than 65 mpg, mine are usually 68 or 69mpg. I'm 5'11" and 220 so the bike is not lightly loaded and I'm not really very aerodynamic. You may, however, be in the lower 60s from spending a greater amount of time in upper speed ranges.
    My odometer seems to read pretty true against gps.
    Speed is a different story, indicated 40 is really 36, 45 indicated is really 40 (@5000 rpm, CSC recommended max break in speed) and 50 indicated is really 44. I can get you higher numbers if you'd like.
    Don
    #69
  10. ChopperCharles
    Jun 7, 2006
    4,741
    Durham, NC
    The speedometer is off by TWELVE PERCENT?!? That’s insane! There’s fudging the top speed numbers, and then there is outright bold-faced lying. I thought a 6.5% difference was pretty bad, but 12% is the worst I’ve ever heard of. Usually the big four under-report speed by only 4 to 5%.
    Charles.
    #70
  11. dp064
    dp064 Adventurer
    Nov 11, 2019
    69
    Nashville
    My numbers seem right but expressed as a percentage it is the highest discrepancy I'm aware of as well. I'll check my numbers again.
    Don
    #71
  12. Spoilyfarts
    Feb 28, 2018
    76
    Pittsburgh, PA
    How long do they recommend for the break in period? Our Day 1 will be all LA city stop and go, so I think staying under 5000rpm will be fine. The end of Day 3 should see about 500-700 miles on the clock - we are planning on the first oil change then and checking the valves. Then I think change again at 1500-2000. Then normal changes every 2000-3000 miles after that.
    I'm guessing sustained 60mph speeds would be very taxing on the engine. How does it handle those?
    #72
  13. dp064
    dp064 Adventurer
    Nov 11, 2019
    69
    Nashville
    Following is from the owners manual..
    Engine Break-In Procedure
    When an internal combustion engine is new, it should not be subjected to hard acceleration, lugging,
    overheating, or running for long periods at a constant engine speed. You should avoid these situations
    during the first 500 miles of service. Caution! Do not violate the guidance provided here, or you may
    damage your motorcycle engine.
    We recommend the first oil change when the motorcycle reaches between 200 and 500 miles. We
    recommend a second oil change at 1,000 miles, and every 2,500 miles thereafter. We recommend
    using only 10-40W motorcycle oil. Caution! Never use any oils intended for automotive use, or any oil
    that contains friction reducing additives (use of these oils will induce clutch slippage not covered by the
    CSC warranty).
    Use only non-synthetic oils during the first 1000 miles of use. After that, you may wish to change to
    synthetic motorcycle oil.
    ..not sure where I got to avoid engine revs over 5000.. I changed my oil first at 350 miles. I had a piece of white sealer about the size of a pencil eraser in the screen.. nothing else. As far as engine speed, on my 01/01/20 run to the bridge, I was at WOT for a fair amount of the time.. I expected the worst but there were no I'll effects. I'll do a run at a steady 7000 and see where that puts me on gps to give you a speed reference.
    Don
    #73
  14. Spoilyfarts
    Feb 28, 2018
    76
    Pittsburgh, PA
    @dp064 That would be great! And I'm happy to hear our planned service stops just about coincide with what the manual says.
    #74
  15. dp064
    dp064 Adventurer
    Nov 11, 2019
    69
    Nashville
    Sorry this is late.. lots or rain in middle Tennessee and a new V-Strom have conspired against me getting new data. I have to stick with my original numbers regarding speed.. they seem right. Additionally, at a steady 7000rpm, my indicated was 61/62 and my GPS speed was 55. I'm unfamiliar with the redline but I don't think mine will pull much past 8000. Having said that, however, I think a 7000 cruise is pretty realistic.
    #75
  16. Spoilyfarts
    Feb 28, 2018
    76
    Pittsburgh, PA
    @dp064 Thanks for verifying this! We figured the claimed top speed of 65ish was fairly unrealistic and were guessing 55-60mph would be more in line with reality. It's kind of fun planning such a slow trip; not something I have ever had to worry about with the BMW.
    #76
    dp064 likes this.
