1. ADVRIDER Print Magazine!
    We're doing two more print magazines year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
Call all XR600R!!!
Discussion in 'Thumpers' started by CSMonte, Dec 8, 2008.
  1. lookfar
    lookfar from the land of OZ Supporter
    Feb 13, 2011
    1,489
    D'aguilar
    If you can measure the piston, you will get an idea on the bore size. If it has been run hard as you say, I would get the next size up piston, and take it to a reputable engine shop to get the cylinder bored. Might as well take the head there too, and get them to give it a clean up and valve job. They should also be able to reface the head if it has warped.
    MCMA111 likes Engine Dynamics, I think they are in the SF area. I am on the other side of the world, so not really familiar with localities.
    I like to use Pro-X cast pistons, but each to their own. I build my engines for longevity, haven't had one burn oil yet, so not doing too bad.
    I use OEM valves if needed, most of my engines are around 30 years old, so new valves should last another 30 or so years.
    Give the tensioner shaft a light rubbing with 1200 emery paper to remove any marks from the tensioner, small marks can cause the dreaded timing chain tic.
    The top tensioner shaft has small marks on it from the tensioner, these were enough to cause the timing chain tic. Bottom shaft is new.
    Thebusdweller and MattLikeyBikey like this.
  2. JAB
    JAB Unsprung Weight Supporter
    Dec 2, 2004
    1,784
    Beautiful Monrovia
    All good advise. Replace the timing chain and the tensioner spring and have good look at the guides too. I am very happy with Honda parts when available. check the cam, rockers and cam center bearing on the cam and head.
    MattLikeyBikey likes this.
  3. mcma111
    mcma111 Long timer
    Jul 17, 2007
    18,138
    San Francisco,Ca.
    Matt,
    Wiseco piston. Chose from a 97.5mm, 98mm or 100mm.
    Here is my recent build with a 98mm.
    Valve job. Cut seats and grind valves, new seals,
  4. MattLikeyBikey
    MattLikeyBikey Been here awhile
    Nov 8, 2018
    626
    So Cal
    Steve, those are some great images! Speaking of which - it seems like I need to get the piston first and provide that to the shop correct?
  5. mcma111
    mcma111 Long timer
    Jul 17, 2007
    18,138
    San Francisco,Ca.
    Yes. The cylinder is bored to the piston. You can see how accurate Mike gets his finished bore to the piston
  6. XRHondafan
    XRHondafan Long timer
    Oct 29, 2016
    2,177
    Steve
    How do you get the engine as clean as that?
  7. mcma111
    mcma111 Long timer
    Jul 17, 2007
    18,138
    San Francisco,Ca.
    Bead blast then prime coat, color coat, clear coat. Cylinder and head left bare.
    XRHondafan likes this.
  8. XRHondafan
    Oct 29, 2016
    2,177
    Does that kinda treatment last ?
  9. mcma111
    mcma111 Long timer
    Jul 17, 2007
    18,138
    San Francisco,Ca.
    Sure. Once it heat cycles a couple times it's stuck pretty good.
  10. JAB
    Dec 2, 2004
    1,784
    Beautiful Monrovia
    I can vouch for the paint. Did the same thing and it has held up well and looks nice.
  11. Hurricane Bob
    Hurricane Bob Long timer
    Jun 6, 2007
    3,014
    Rhode Island
    YouTube find of the day
    blahzik and thebigman like this.
  12. VittoXVIII
    VittoXVIII Adventurer
    Mar 1, 2013
    65
    Switzerland / Italy.
    So, I've just bought this gem
    XR 600 R Frame with a few mod (1987)
    NX 650 engine
    XR 600 dual carbs (not sure about this one...)
    CR 250 forks
    CR 250 front brake
    Unknown rear brake
    Whatelse....mmh, wheels are supposed to be from a Nx 650
    Rides ok but it's going to be a long process to fix it up as I want it to be.
  13. Al-X
    Al-X Been here awhile
    Dec 26, 2007
    390
    Johannesburg, South Africa
    Thats a proper hybrid!! Greta will be glad....
  14. lookfar
    Feb 13, 2011
    1,489
    D'aguilar
    must have the ‘87 twin carb head on it, all the NX engines were single carb
  15. dedgerly207
    dedgerly207 Been here awhile
    Apr 15, 2014
    116
    Hello All,
    Very new to the forum and a proud new owner of a non running 1987 XR600. Purchased it last weekend for 600. I previously owned a 1998 XR400 in college and stupidly sold it. Regretting it ever since, I recently got the XR bug and found this 1987 that appeared to be complete but had not been started in who knows how long.
    Upon first inspection it appears that the kick starter lever does not return to the up position. I have searched the forum and realize that I need to remove the right side engine cover and inspect the kick start mechanism. I just ordered the Clymer manual yesterday so hoping I can tackle this on my own.
    It also appears that the PO has put gasket maker on just about every case mating surface I can see....both engine side covers, cylinder and head. Looks like someone smeared it on with their finger so I assume the motor has been apart before. It has a homemade oil cooler piped into the oil circuit which plan to remove as it does not look like it would fair well offroad. I will try to post some photos.
    My plan of attack is to pull the carbs off the bike and go through them. I would like to repair the kick started spring and reassemble the bike to start it. At that point I would like to assess if the motor needs a teardown and rebuild. Does that sound like a decent plan of action? I shoudl not start the bike with the broken kick start spring; correct?
    Or should I just assume the worst, pull the motor out and begin the teardown and rebuild process?
    My plan for the bike to build a reliable dual sport. It is basically winter here in New Hampshire (USA) so getting the bike going and riding it very far is probably not going to happen.
    Really appreciate anyones insight.
  16. Thebusdweller
    Thebusdweller Been here awhile
    Nov 23, 2012
    179
    Nevada
    PM sent
  17. dbur971
    dbur971 Been here awhile
    Jun 19, 2014
    202
    PNW
    Used a normal seal puller. Took about 10 seconds to pull out. Way easier than drilling holes and driving in screws and less likely to mar something up.
    T4EaterJonny likes this.
  18. T4EaterJonny
    T4EaterJonny Not too hip...
    Oct 11, 2012
    325
    Corona, ca
    Nice! This thread is dead. Has everyone put away their pigs for the winter already?!
  19. OBD
    OBD Other Brother
    Nov 30, 2011
    285
    New England
    sort of.
    mine’s patiently waiting on the back porch
    bork likes this.
  20. Ron50
    Ron50 Long timer
    Oct 12, 2008
    4,059
    Canberra
    Nah, Saturday.
    rustyx, bork and mrsdnf like this.
