Call all XR600R!!!
Discussion in 'Thumpers' started by CSMonte, Dec 8, 2008.
  1. MattLikeyBikey
    MattLikeyBikey Been here awhile
    Nov 8, 2018
    626
    So Cal
    Skid plate - anyone recommend one on here? I see that one post says that a skid plate isn't recommended due to cooling needs. Anything better than stock but provides sufficient air flow? Thanks.
  2. bork
    bork Been here awhile
    Oct 30, 2013
    781
    Jeremy K and MattLikeyBikey like this.
  3. MattLikeyBikey
    Nov 8, 2018
    626
    So Cal
    One other question - Kenda K270 - it looks like the 3.25 will fit on the XR600R but which rear tire? Rocky Mt says 4.5 but would a 5.1 work well? Pros/Cons? They seem to both be the same weight rating so maybe net no nevermind.
  4. lookfar
    lookfar from the land of OZ Supporter
    Feb 13, 2011
    1,492
    D'aguilar
    5.1 is same as 130
    MattLikeyBikey likes this.
  5. Wookazoid
    Wookazoid Tree Basher
    Jun 2, 2010
    908
    Goobertown, Arkansas
    According to what I've read, Summers didn't run a skid plate since he was concerned that it would block the air flow to the engine. The frame guards underneath do provide some decent protection.
    I bought his last 600R race bike from his nephew last February and it didn't have a skid plate. The bike was set up for him but he broke his femur before he ever got to race it. It also doesn't have the XR400 oil cooler but appears to have all the other cool SRC stuff including the factory Yosh pipe. I have since put a skid plate on it (Ricochet from Rockymountain), since I'm a mortal and can't ride it that hard.
    Without skid plate (when I got it)
    With skid plate (now)
    Greg
  6. T4EaterJonny
    T4EaterJonny Not too hip...
    Oct 11, 2012
    325
    Corona, ca
    The skid plates don't even come up that high. I run the GSMark oil cooler so I don'tworry about temps.. I wish I knew which one mine was. Its probably something from a company that doesn't exist anymore from the 90s
  7. Wookazoid
    Jun 2, 2010
    908
    The skid plate has to come up and attach to the mounts used for the “Pipe, Skid” (underside frame guard) just below the oil drain bolt on the frame downtube. That doesn’t come up far enough to block the cylinder cooling fins but Summers primarily raced in the east where the courses are relatively tight and lower speed. Temperatures in the summer get pretty warm and with a skid plate, the engine would have a little more trouble dissipating heat. At the level he raced, they looked for any miniscule advantage they can gain for performance. Myself, I just don’t want to bust my engine case.
    I'm trying to leave the 600R as original as possible, but I also have a 650L. The Sutton's oil cooler was on my wish list, but I like that GSMark. How do they compare?
    Greg
  8. Onederer
    Onederer Crunch Nugget
    Aug 24, 2008
    1,244
    Somewhere
    Don't for get about aluminum skid plates reflecting sound back up, especially the larger ones.
    There used to be 'glide plates' available for the XR600R. They fit WITH the factory tubular engine guard, but did not extend past the side of the frame tubes. I think Works Connection made one for the XR. They bolted to the two places in the front that the factory guard did and had two clamps similar to other skid plates near the rear, under the engine.
    Here's an internet picture of one on a XR400R. It's constructed and mounted different from the XR600R ones.
    They provide frame and engine protection on the bottom, without the big wings on the side like skid/bash plates. With the stock engine guard in place, I'm not so sure the side wings are needed anyway. The XR600R stock engine guard was aluminum tubing, but one for a XR650L is steel, if that makes a difference.
    I have, or had one that was beat up pretty bad. I'll look for it or at least some pictures of it.
  9. Onederer
    Aug 24, 2008
    1,244
    Somewhere
    I sold the one I had, but here are some pictures. Maybe some companies still make them.
    XR600R Skid Plate (2).JPG XR600R Skid Plate (3).JPG XR600R Skid Plate (4).JPG
  10. Sub Zero
    Sub Zero Ice Breather!
    Apr 14, 2010
    859
    Orlando, Florida
    my 1996! runs fantastic. really fun bike! I spend alot of time on the street with it, i know it needs tires :D
  11. VittoXVIII
    VittoXVIII Adventurer
    Mar 1, 2013
    69
    Switzerland / Italy.
    Almost finished....
    WhatsApp Image 2020-01-21 at 00.04.32.jpeg WhatsApp Image 2020-01-21 at 11.53.38.jpeg WhatsApp Image 2020-01-21 at 11.53.38.jpeg WhatsApp Image 2020-01-21 at 11.53.38.jpeg WhatsApp Image 2020-01-21 at 11.53.38.jpeg
    BSW likes this.
  12. baldman1
    baldman1 Long timer
    Jan 18, 2013
    2,609
    Arizona
    Your bike needs tires.
  13. jcshew
    jcshew Been here awhile
    Jun 30, 2009
    211
    Hello,
    I have this set of Applied Racing tripe clamps. I know they are for an XR, but I'm not sure if they fit a 650R or the 600R. Anyone know what the diameter of the 600's upper fork tube is? Thanks.
  14. XRHondafan
    XRHondafan Long timer
    Oct 29, 2016
    2,197
    43
  15. jcshew
    Jun 30, 2009
    211
  16. webmonstro
    webmonstro A Aventura Continua....
    Jul 21, 2008
    1,244
    Portugal
    Just bumping the thread ...
    Last saturday
    Squily, msteward and JAB like this.
  17. ossaboy2867
    ossaboy2867 Been here awhile
    Dec 5, 2014
    151
    Wellsville
    E718BC7A-409D-4831-9FE9-7449EB08739C.jpeg C76FCC48-6129-40A9-9F2E-201BE57AA344.jpeg I previously posted this in the wrong area (XRL). I have an older friend from work who wants to sell me this. It runs and has a NY state street legal title. Based off the pictures, what would YOU pay? Just curious what the going price is for one of these. I promise to keep it a dirt bike. I cant stand the beardo hipster crap people are doing to these offroad legends.
  18. msteward
    msteward Long timer
    Sep 14, 2015
    1,279
    Spanish Fork, Utah
    Depending on the year I would guess 1000.00-1200.00, depends how it starts and runs also. Hope he's kept stock air cleaner on it, K&N less then that.
  19. ossaboy2867
    Dec 5, 2014
    151
    Wellsville
    Perfect. It had the stock filter and it appears a mouse ate it. I plan on doing a complete resto to handle my dual sport needs.
  20. AlpinaE24
    AlpinaE24 Long timer
    Nov 2, 2010
    1,511
    az
    I really need to find another nice 600
