Call all XR600R!!!
Discussion in 'Thumpers' started by CSMonte, Dec 8, 2008.
  1. MattLikeyBikey
    MattLikeyBikey Been here awhile
    Nov 8, 2018
    626
    So Cal
    Can any of you share what the standard measurement for fork oil level in the bike is? IE from the highest part of the tube in the most vertical direction to where the oil and tube meet on the other side? Danke!
  2. msteward
    msteward Long timer
    Sep 14, 2015
    1,279
    Spanish Fork, Utah
    I think mine was 3 7/8 in the tube roughly.
    MattLikeyBikey likes this.
  3. webmonstro
    webmonstro A Aventura Continua....
    Jul 21, 2008
    1,244
    Portugal
    From the manual :
    available on my drive here :
    https://drive.google.com/open?id=10fqKPwzm7MUtZVgbT3SgLPkM6mmf2R6v
  4. MattLikeyBikey
    Nov 8, 2018
    626
    So Cal
    What's the best bet for good fitting, high quality plastics for an xr600r? Mainly want fender and sides and possibly headlight.
  5. mcma111
    mcma111 Long timer
    Jul 17, 2007
    18,196
    San Francisco,Ca.
  6. wrk2surf
    wrk2surf on the gas or brakes
    Dec 16, 2007
    9,152
    THE exact center of California/Bass lake/Yosemite
    So the REAR XR600R hub is discontinued. I need to know for sure if the 650L hub is basically the same and will interchange I can have spacers made or use the ones off the 600R. Has anyone done this personally not I knew a guy deal.
    I can see on the fische that the bearings and seals are the same. so that doesn't have to be touched on.
  7. Wookazoid
    Wookazoid Tree Basher
    Jun 2, 2010
    908
    Goobertown, Arkansas
    Front or rear? I know from experience that the front is different but from what I've been told, the rear wheels are interchangeable.
    Greg
  8. thebigman
    thebigman XR's all the way . Big Thumps or V-twins
    Jul 9, 2010
    5,155
    Texas Gulf Coast. Galvatraz
    600r and 650L rears are the same . pm me if you need 1 , I have ..
    wrk2surf likes this.
  9. wrk2surf
    Dec 16, 2007
    9,152
    I thought so even the pic in the fische looks the same. I have some SS moose spokes and rim as well as bearings for mine and it seemed all of them showed they interchanged
    THANKS ! PM SENT @thebigman !
    take note @woody's wheel works
  10. wrk2surf
    Dec 16, 2007
    9,152
    Its funny I am doing a 600 for a friend and I have a 85 350R and like the kickstand is the same length and mounts the same. It would be nice to have a editable post that shows what works or is the same but dont share the same PN.
  11. watchout4him
    watchout4him surfer
    Apr 2, 2013
    17
    Surf City, USA
    I did 20 oz of ATF in cartridge system 95 forks.
    OEM side plastics. Clarke Tank. Maier rear fender. Crf front fender. In red...
    Edit: I did 20fl oz of ATF in the stock 95xr6r forks. Which are not the forks in this shot. I just wanted to show my plastics I described. FB_IMG_1578944757087.jpg Is my ticket.
    Squily, Tallbastid and msteward like this.
  12. MattLikeyBikey
    Nov 8, 2018
    626
    So Cal
    Any of you know what this is? I think it's from an XR600R. Possibly the headlight? ~30mm in diameter. Thanks.
  13. Onederer
    Onederer Crunch Nugget
    Aug 24, 2008
    1,244
    Somewhere
    Steering stem nut lock tab?
    Didn't say year of XR.
  14. MattLikeyBikey
    Nov 8, 2018
    626
    So Cal
    1996 but hadnt had that off. It's thin so probably not for structure.
  15. Onederer
    Aug 24, 2008
    1,244
    Somewhere
    I have one of those headlight assemblies. It's not from that, I just checked.
    How certain are you that it's from the XR?
  16. MattLikeyBikey
    Nov 8, 2018
    626
    So Cal
    Not sure but that's the last mechanical project I was working on - I'm usually meticulous to a fault on parts so there's a very good chance it's from something else. I do have a box of mystery parts which should be worth a mint in unobtainium if I ever find the affected parts. Thanks.
  17. JAB
    JAB Unsprung Weight Supporter
    Dec 2, 2004
    1,804
    Beautiful Monrovia
    Looks like it is getting to be time for a clutch. Was is the "go-to" choice for replacement? OE or ? Fibers, steels and springs just to be sure or measure and choose?
  18. lookfar
    lookfar from the land of OZ Supporter
    Feb 13, 2011
    1,492
    D'aguilar
    Usually use Tusk myself, get the whole kit, fibres, steels and springs.
    HTH
  19. msteward
    msteward Long timer
    Sep 14, 2015
    1,279
    Spanish Fork, Utah
    I have only bought the oem stuff, as I have really abused it and it lasted a very long time. As a matter of fact I am on only the 2nd one after 18+ years. I also had done the basket with the last one because of grooves in the fingers.
  20. bork
    bork Been here awhile
    Oct 30, 2013
    780
    Basket purchased, a new OE or good used?
