Call all XR600R!!!
Discussion in 'Thumpers' started by CSMonte, Dec 8, 2008.
  1. 2manyrides
    2manyrides shifty charactor
    Aug 17, 2008
    2,566
    Citrus Heights Ca.
    So you’ve gone “hightech”?
  2. bork
    bork Been here awhile
    Oct 30, 2013
    615
    I use solid copper 14 ga insulated house wire.
    rustyx likes this.
  3. 2manyrides
    Aug 17, 2008
    2,566
    Citrus Heights Ca.
    So, Another high tech solution... Strap it down any way you can and don't worry about the dampening that a bit of stretchy rubber provides.
    Tell that to a 5.8 gallon tank... Don't worry about it...
  4. JAB
    JAB Unsprung Weight Supporter
    Dec 2, 2004
    1,692
    Beautiful Monrovia
    How about cutting out the rubber and using nylon webbing on the factory rings. Will damp a little and the bit of stock cable will give the strength it needs. Make the webbing just a bit short and stretch it into place.
  5. 2manyrides
    Aug 17, 2008
    2,566
    Citrus Heights Ca.
    JAB, those are the considerations passing through my mind. How to make, alter, or rebuild one.
    Of course the cable part of it is an overly long safety harness should the rubber break and you are doing a flip in the air. It’s way too long to rely on to keep things in place.
    Some day I will get something fabricated. Just looking to what/if anyone has a good start on that. Keep the ideas coming...
    I keep a couple new straps in the parts bin, but am tired of breaking them on one 600 or another. Besides, they aint cheap!
    The temporary fix I put on my friend’s 95 seems to be holding up and I’ve already had it on and off a few times.
    I put a fix on it because the last time I mentioned having spares to a buddy, it was like... wow, thanks... see ya...time to order more. Like I said in original post... sick of it.
  6. Karabanov
    Karabanov n00b
    Feb 29, 2020
    4
    Russia
    I already had a double ring and a ribbon of cloth. Holds well and does not weaken. Most helmets have this mounting system. I didn't know Honda was planning rubber there :hmmmmm
    2manyrides and JAB like this.
  7. JAB
    Dec 2, 2004
    1,692
    Beautiful Monrovia
    This is perfect.
  8. ossaboy2867
    ossaboy2867 Been here awhile
    Dec 5, 2014
    135
    Wellsville
    Finally got the frame and hubs back from powder coating, time to start re lacing the wheels
    1A2F0DC5-0960-41CF-954D-5DAEECB298F3.jpeg 6922F473-9E07-4A7E-BEB4-CC9D5E6CD53E.jpeg 4FEA7410-A2F3-46F1-A8A7-5876CA3F4EEB.jpeg AFD76EC1-72D3-487C-8BAF-E5F6EDFC1B7A.jpeg FA87BF40-6C56-406D-9ED0-D68A2375239F.jpeg
  9. ossaboy2867
    Dec 5, 2014
    135
    Wellsville
  10. thebigman
    thebigman XR's all the way . Big Thumps or V-twins
    Jul 9, 2010
    4,211
    Texas Gulf Coast
    Can ya elaborate to the peanut gallery how you come up with the correct offset of the hub , did you take a measurement before
    you tore it down or does the manual talk about this ? How bout if you were using a diff width hoop , how would you decipher
    offset ? Thanks
  11. mcma111
    mcma111 Long timer
    Jul 17, 2007
    17,783
    San Francisco,Ca.
  12. thebigman
    Jul 9, 2010
    4,211
    Texas Gulf Coast
  13. ossaboy2867
    Dec 5, 2014
    135
    Wellsville
    Sure. As mcma111 noted the offset dimension is listed. But....lets say you have no idea what it should be.
    As you can see I have the swingarm mounted to my mill, but you could use a sturdy table or bench. I measured where centerline of the swing arm is and marked center using tape streched taught across the two arms. Basically I have tape across the two sides filling in the void where the wheel would be, and a line representing center drawn down the middle.
    Leave enough room to install the bare hub with all the spacers and fixings included. You can see I have the center of the hub wrapped in tape with a line on it.
    Centerline determined on the swingarm/tape is now transfered on the the hub where you have tape wound on the center (you can still see this in my photos).
    You now have a centerline on the hub to work from if needed. Remove the tape when your done!
    I hope this helps, I didn’t take pictures of all the setups.
    thebigman likes this.
  14. ossaboy2867
    Dec 5, 2014
    135
    Wellsville
    F7732F56-173B-438B-8DE0-0295898CAD75.jpeg 5D226593-3E12-49C2-AFD1-225D6AF6F070.jpeg F29BF834-B6F9-4B61-B7D6-5EDB260F3572.jpeg E04FCA81-A629-4703-843C-F7789BAA6100.jpeg
  15. ossaboy2867
    Dec 5, 2014
    135
    Wellsville
  16. ossaboy2867
    Dec 5, 2014
    135
    Wellsville
    4DE9E40E-1653-4341-B156-882BFF0890B0.jpeg Here is the front rim offset measure.
  17. ossaboy2867
    Dec 5, 2014
    135
    Wellsville
    Made some progress today
  18. cmbthumper
    cmbthumper Been here awhile Supporter
    Sep 29, 2018
    829
    Ramona, CA
    I needed a CA Plated bike so picked this up today. Had a 97' XR600 and brought back a sh*t ton of memories. PO was at Sea Level so will re-jet and clean carb.
    20200717_110213.jpg 20200717_133758.jpg 20200717_133818.jpg 00L0L_2LC2vCoIxJF_0t20lM_1200x900.jpg
  19. spezjag
    spezjag Long timer Super Supporter
    Dec 29, 2004
    17,160
    Northern Virginia, USA
    ^ Congratulations - that's a fine looking bike!
    cmbthumper likes this.
  20. cmbthumper
    Sep 29, 2018
    829
    Ramona, CA
    Thank you for that. Look forward to re-learning about the XR600, what parts mix with other bikes etc etc.
    My other ride i just finished.
