Calling JVB (Jim) 1250 shift cam boxer internals question
Discussion in 'GS Boxers' started by Jontaff, Sep 15, 2019.
  1. Jontaff
    Jontaff Been here awhile
    Aug 28, 2010
    185
    Jim,
    Sorry to put your in the spot light, but you know a great deal about these engines than I do, so do you know what the shift cam mechanism (black solenoid) is made out of and it's durability?
    Thanks,
    Jon
  2. JimVonBaden
    Feb 11, 2005
    90,955
    Alexandria, VA
    I can't say about durability, but the mechanism is a combination of plastic casing, metal base and hardened steel pins. I can only assume they will be decently durable.
  3. Jontaff
    Aug 28, 2010
    185
    Jim,
    Thanks for the quick response.
    I did see those pictures on your thread but I only got the new GS a couple of weeks ago (traded the RT and before that that the GSA) I was concerned about the "life span" on that particular part.
    It will be interesting when you do more work on the engine as to how "the internals" are holding up. I hope the cams wear better than some earlier water boxers.
    Lastly, I appreciate your knowledge and helping the folks out here, including me.
    Jon.
  4. Jontaff
    Aug 28, 2010
    185
    Nice pictures.
    Do you re-use the valve cover gaskets if they are OK after the valve check?
  5. JimVonBaden
    Feb 11, 2005
    90,955
    Alexandria, VA
    The valve cover gaskets are completely reusable so long as you clean the surfaces well.
  6. Bikerboy108
    Bikerboy108 Pat from Jersey
    Sep 22, 2004
    4,944
    Jersey "Land of the Lane Closure"
    yes unless you are the dealer and want to add another $80 + dollars on the bill !!!
  7. Rider2
    Rider2 Been here awhile Supporter
    Jul 20, 2014
    531
    Delaware
    That's $80 each side
  8. Jontaff
    Aug 28, 2010
    185
    Thanks Jim
    #8
    JimVonBaden likes this.
  9. tentative_rider
    tentative_rider Wanna Be On Gravel
    Jul 11, 2009
    1,441
    New Braunfels TX
    Out of curiosity, what things move when the shiftcam engages, I can't wrap my head around it.
    TR
    #9
  10. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    5,915
    Zer0-Zer0-Zer0-Zer0
    The cam that controls intake valves moves left-right by the actuator thus different lobes engage to open/close the valves:
    #10
  11. atwoodtja
    atwoodtja Been here awhile
    Jun 6, 2004
    776
    New England, US
    BMW is using this same technology in the boxer and inline engines. Pretty big risk for them as a company if they weren't sure it was durable in the long term.
    #11
    Jontaff and scottdc like this.
  12. Jontaff
    Aug 28, 2010
    185
    Thanks for confirming that. I was advised by a friend the other day that this technology was used in the IL engines.
    #12
  13. adventuro
    adventuro Adventurer
    Aug 24, 2010
    54
    mocksville nc
    What keeps the cam in one position or the other. wouldn't the pin that shifts the cam have to retract almost instantly. Looks like maybe I see a third pin or dowel that remains in a extended position to engage one of two grooves.
    #13
  14. Rider2
    Jul 20, 2014
    531
    Delaware
    Here's a video that explains how it works on the SS 1000 RR. The relevant part starts at 1:40. I'm sure it's functionally identical on the R 1250s. Yes, it happens in a fraction of a millisecond, and the narrator says "it just sits there". There may be something encouraging it to do so, like a soft detent, but I've not seen anything suggesting that.
    #14
  15. adventuro
    Aug 24, 2010
    54
    mocksville nc
    Thanks for video, still just hard for me to imagine that it just stays in position...sure looks that way though.
    #15
  16. hammick
    hammick Long timer
    Dec 2, 2007
    4,467
    Kansas City, Missouri
    Yeah and good chance some dealers would charge for gaskets and use the originals.
    #16
  17. chris73
    chris73 Been here awhile
    May 29, 2013
    429
    vancouver island
    It looks like if there was a failure, it would just fail in the last position. Like if the solenoid failed. As long as the cam stays on one side or the other, it should get you home anyway. If cam started floating that would concern me. Like left to right.
    #17
  18. Lead Wrist
    May 26, 2007
    5,915
    Zer0-Zer0-Zer0-Zer0
    At 1:32 the narrator is using "soft" and "hard" cam expressions? I'd like to think that doesn't mean what I'd think that would mean - cam hardness is a rather sensitive topic... :D
    #18
  19. JimVonBaden
    Feb 11, 2005
    90,955
    Alexandria, VA
    There are two pins. They retract when the bike is off.
    #19
  20. adventuro
    Aug 24, 2010
    54
    mocksville nc
    Thanks Jim, I see that in the video, but it looks like something would have to keep it from drifting left/right. This question has kept me up at night....and I don't even own one....yet!:lol3
    #20
