Calling out, TRS owners! Questions/things to share.
Discussion in 'Trials' started by Sting32, Mar 14, 2018.
  1. Norman Foley
    Norman Foley Devotee of the Husqvarna Supporter
    Mar 20, 2004
    4,631
    New York... The Finger Lakes
    Yinzer Moto, Huzband and jonnyc21 like this.
  2. alpineboard
    alpineboard Been here awhile
    Mar 2, 2016
    767
    New Hampshire
    Gold Carbonfiber air box spring mod, keeps it from slipping upward, before /after 1009201411-00.jpg 1009201417-00.jpg 1009201453-00.jpg
    jonnyc21 likes this.
  3. mung
    mung Long timer
    Apr 18, 2008
    1,196
    Idaho
    Good idea, my goldie has always had a very loose air filter. I much prefer the Gasser bolt in air filter.
    riabma77 likes this.
  4. alpineboard
    Mar 2, 2016
    767
    New Hampshire
    At first, gave the spring a stronger bend, and was checking it, all fine. But today, the filter had popped ajar from the bottom, it was not off , no air opening, but was enough to go at the spring again. Also a bend to get the spring to go strait at the pin, then add a bit more tension.
  5. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    16,182
    Dubuque, Iowa
    I must have just missed the cut again........:1drink
    Huzband likes this.
  6. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    11,118
    Cowford, Fl.
    I feel your pain. :2cry
    10K likes this.
  7. Buschog
    Buschog Long timer
    Nov 13, 2015
    1,289
    Carson City, NV
    I've heard Nigel Parker is on TRS as well. Dunno if it's a sponsored ride or not
    Yinzer Moto and Norman Foley like this.
  8. Sting32
    Sting32 Trials Evangelist
    Oct 27, 2009
    2,046
    Minneapolis, Ks
    On his Facebook it says it is same team as Roper?
    From his own post: Excited to be apart of the TRS Motorcycles USA family for 2021 Excited for the new adventures this bike and team will take me on Dirt Riders West TRS Motorcycles Factory.
    Buschog and Norman Foley like this.
  9. Yinzer Moto
    Yinzer Moto Sloppy 300 rider Supporter
    Jun 13, 2008
    40,317
    Pittsburgh PA
    Does anyone have a clue what this coating is? My bike is exhibiting symptoms of an air leak. I pulled the reeds to check the gasket and found this substance with some edges lifting on it. I started pealing the loose stuff away.
  10. lineaway
    lineaway Long timer
    Oct 1, 2011
    12,114
    nm
    Being on only one side of the case I would bet some kind of gasket sealer/glue. I used to use gasgacinch alot. That is my guess.
  11. Yinzer Moto
    Jun 13, 2008
    40,317
    Pittsburgh PA
    It was on both sides, it cleanly pealed off the right side.
  12. UstaKood
    UstaKood Been here awhile
    Feb 5, 2016
    538
    Michigan
    Gold edition?
    :photog
    Yinzer Moto likes this.
  13. lineaway
    lineaway Long timer
    Oct 1, 2011
    12,114
    nm
    For the Symptoms , you did try running it with out the gas cap.
  14. Yinzer Moto
    Jun 13, 2008
    40,317
    Pittsburgh PA
    Just on the inside. :imaposer
  15. Yinzer Moto
    Jun 13, 2008
    40,317
    Pittsburgh PA
    i have not. It is a bit random and I need a way to keep gas from splashing everywhere
  16. lineaway
    lineaway Long timer
    Oct 1, 2011
    12,114
    nm
    I would do away with the guts of the gas cap before searching for a leak. It has happened on several bikes.
  17. Yinzer Moto
    Jun 13, 2008
    40,317
    Pittsburgh PA
    It would be nice to be able to just take the check valve out without destroying the cap.
    Edit: that was easy. It just pulls apart.
  18. lineaway
    lineaway Long timer
    Oct 1, 2011
    12,114
    nm
  19. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    11,118
    Cowford, Fl.
    Are your Scorpa gas cap threads the same? :D
  20. North ride
    North ride Long timer
    Jul 10, 2017
    4,215
    Nwt Canada
    Is that coating just in the intake port or is it inside the crankcase as well ?
