Calling out, TRS owners! Questions/things to share.
Discussion in 'Trials' started by Sting32, Mar 14, 2018.
  1. Yinzer Moto
    Yinzer Moto Sloppy 300 rider Supporter
    Jun 13, 2008
    40,317
    Pittsburgh PA
    It is difficult to tell, I can’t see much of the crankcase. I can see the bottom of the cylinder, it is clean aluminum.
  2. Thesolidman1
    Thesolidman1 Been here awhile
    Dec 15, 2011
    123
    Nor Cal
    "Does anyone have a clue what this coating is? My bike is exhibiting symptoms of an air leak. I pulled the reeds to check the gasket and found this substance with some edges lifting on it. I started pealing the loose stuff away."
    Man i would think that's a problem! Inside of the engine with something flaking off and getting in the bearings, top end, etc? What are you going to do?
  3. lineaway
    lineaway Long timer
    Oct 1, 2011
    12,115
    nm
    I don't think its that big a deal . I bet it would not of flaked off without his help. It could of been the fuel or oil the previous owner was running.
    Yinzer Moto and DyrWolf like this.
  4. DyrWolf
    DyrWolf Long timer Supporter
    Jan 21, 2012
    3,032
    RICHMOND VA
    Golden spectro
    Yinzer Moto likes this.
  5. DyrWolf
    Jan 21, 2012
    3,032
    RICHMOND VA
    I was cooking hotdogs anyway so i threw some anti seize on the grill
  6. Norman Foley
    Norman Foley Devotee of the Husqvarna Supporter
    Mar 20, 2004
    4,631
    New York... The Finger Lakes
    All TRS, all the time....
    2whlrcr, Yinzer Moto and Huzband like this.
  7. Yinzer Moto
    Jun 13, 2008
    40,317
    Pittsburgh PA
    The plastic end cap on the muffler is known to break. As you can see, this one has taken some hits. I thought about buying a new one but I just see that breaking fairly quickly. I decided to take a crack at fixing it.
    I drilled a hole in the plastic to take a 5mm RivNut.
    Then I cut a little piece of plumbing strapping the bridge the the two holes together
    Repeat the process for the other mounting holes.
  8. rokhopr
    rokhopr 2019 TRRS 250
    May 28, 2007
    178
    Owasso, OK
    Nice! I just replaced my end cap about two weeks ago - will try this next time.
    Norman Foley and Yinzer Moto like this.
  9. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    16,182
    Dubuque, Iowa
    So that's what they look like...if you ride em?
  10. Yinzer Moto
    Jun 13, 2008
    40,317
    Pittsburgh PA
    Especially if the rider has trouble staying upright.
    Norman Foley and 2whlrcr like this.
  11. rokhopr
    May 28, 2007
    178
    Owasso, OK
  12. lamotovita
    lamotovita DAMN SNOWBIRD! Supporter
    Oct 5, 2007
    3,345
    WA/AZ, USA
    Well put that in your pipe and smoke it.
    Thesolidman1 likes this.
  13. Thesolidman1
    Dec 15, 2011
    123
    Nor Cal
    But seriously, what about the internal coating flaking off? Just run it?
  14. Yinzer Moto
    Jun 13, 2008
    40,317
    Pittsburgh PA
    I removed everything that was loose, put it back together and have been running it.
    I emailed @Hoss Cartright but have not heard back.
  15. mung
    mung Long timer
    Apr 18, 2008
    1,196
    Idaho
    Gas tank breather attachment post behind steering head. To remove does it just pull out? My big fingers can't feel back there to figure how it is attached. Went to a short breather hose with cap on end. Don't want to carry any more weight than necessary!
  16. lineaway
    lineaway Long timer
    Oct 1, 2011
    12,115
    nm
    Warning TRS Promotional video!
    Gordy, jonnyc21, Yinzer Moto and 2 others like this.
  17. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    11,118
    Cowford, Fl.
    It has tabs & snaps into place. I tried to remove mine last year when I changed & routed a new tube, but was afraid of breaking it so I left it be. Took quite some fiddling but I got it done.
  18. Yinzer Moto
    Jun 13, 2008
    40,317
    Pittsburgh PA
    Anyone want a low hour TRS Gold for a good price?
  19. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    11,118
    Cowford, Fl.
    :cry Trailer or garage fire?
  20. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    16,182
    Dubuque, Iowa
    No but how much for the mtb and road bike? That carbon wheel looks like it just needs a little truing. WTF?
