Callouses, anyone?
Discussion in 'Trials' started by LemmeTry, Feb 20, 2018.
  1. LemmeTry
    LemmeTry Over-thinker...
    Jan 27, 2016
    323
    Bozeman, MT
    How do ya'll prevent painful callouses from riding? Callouses in and of themselves aren't the problem - I've always got them from doing pull-ups, weightlifting, and riding - the problem is that when I ride for several hours my callouses almost develop a blister underneath. It's painful.
    I always wear gloves and find that thin ones without seams are best for preventing "hot spots", but even that isn't enough the prevent the aforementioned problem.
  2. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
    What grips are you running.
    Norman Foley likes this.
  3. mung
    mung Long timer
    Apr 18, 2008
    1,110
    Idaho
    How tight do you hold the grips ? First finger on a lever will let your hands relax.
  4. LemmeTry
    Jan 27, 2016
    323
    Bozeman, MT
  5. irishgb
    irishgb Adventurer
    Jan 31, 2014
    50
    I always use Talcum powder on my hands before putting on my Gloves & repeat any time I remove and replace the gloves , has worked for many many years !!
  6. LemmeTry
    Jan 27, 2016
    323
    Bozeman, MT
    Talcum powder?! What exactly does that do that helps prevent callous problems?
  7. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    3,950
    Boise aria
    lowers the friction between your skin in the glove fabric/leather, makes a big difference.
    Norman Foley, LemmeTry and KevinBB like this.
  8. motobene
    motobene Motoing for 49 years Supporter
    Mar 9, 2013
    7,055
    Wichita Mountains SW Oklahoma
    If your hands aren't relaxed most of the time you ride your technique probably needs tweaking.
    When the rest of your body is being used more optimally, you can stay connected to the bike at the grips by pulsings of the gripping muscles instead of a more constant clamping.
    Then again there is variability in how palm skin reacts to activity. You might have great technique but still build callouses. I get these thick pads on my outer knuckles and I'm not sure why.
    Ditto on talc! I put some in my gloves and that generally lasts through a 2-day event.
    #8
    LemmeTry likes this.
  9. Wingboy
    Wingboy Been here awhile
    Sep 11, 2008
    581
    Waterloo Ontario
  10. LemmeTry
    Jan 27, 2016
    323
    Bozeman, MT
    @Wingboy - can't see the facebook post you linked to, it says that it is no longer available.
    I'll give the talc powder a try next time. Also, I'll try to pay more attention to my technique, I'm sure there is always room for improvement there. ;)
    #10
  11. Greebe
    Greebe Been here awhile
    Aug 6, 2010
    593
    MN
    I do not get calluses from riding, but I have worked in the trades most of my life so my hands are used to being used. I do however get sore wrists, again from working in the trades, and I tend to death grip the handle bars which is something I am working on.
    #11
  12. slicktop
    slicktop Long timer
    Oct 20, 2013
    1,096
    Slicktop Mtn. Ar.
    #12
  13. Gordy
    Gordy SUPPORTER
    Dec 30, 2001
    32,250
    NM
    JFC people. Trim your callouses off with a single sided razor blade. I started doing that when I was about 16 and racing a bike with a Preston Petty front fender. :rolleyes
    If you let them get too big they WILL blister underneath. Beak a bone every once in a while, the callouses will go away then too.
    What next, how do I keep sweat out of my eyes??????
    :hide
    #13
    Nobade, LemmeTry and Fallacy like this.
  14. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
    Bar Risers.
    #14
    LemmeTry and Gordy like this.
  15. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
    It could be your aggresive grip with soft grips causes friction. Try harder grips. I used to always bleed from my thumbs getting blistered.
    #15
  16. PSchrauber
    PSchrauber Long timer
    Jan 3, 2011
    1,314
    Summer: Kemiƶ, Finland; Winter: North Germany
    Talcum works great in doubt but then you have to wash your gloves much more often.
    You can too use different grips I don't like the modern ones most are to hard.other again too much too soft.
    The standard Tomaselli grips sold for 30 works best, super grip and just right in hard- and softness. Too no big texture and still they stick in wet ir dry enviroment.
    Anything else is just 2nd, it may look fancier but ergonomics is wahr we need.
    #16
  17. LemmeTry
    Jan 27, 2016
    323
    Bozeman, MT
    :rofl
    #17
  18. RainyDaze
    RainyDaze Adventurer
    Jun 5, 2018
    54
    Seattle WA
    I've been riding nearly every day in my yard during this Covid crisis, and this is the first time I've ever developed painful calluses on my palms. Riding my enduro bike a couple times a week I've never had an issue, and that's with long hot +60 mile rides with only one or two breaks. The first month of trials riding, no problems, but I was working on balance, figure 8's etc, not gripping the bars tight. Now that I'm spending more time working on wheelies, getting over larger logs, etc. the calluses on my palms are killing me. I know gripping the bars tight is the issue, but when I need to loft the front wheel or climb a hill you gotta hold on. Clearly I've gotta work on holding on with less grip.
    I started shaving them down a couple weeks ago, which helped, but didn't fix it. I've taped them up, which also helps some, but is too big of a pain to do regularly. I switched to a tighter fitting grippier glove (TLD air) and they feel awesome, but they haven't help the calluses. I've resorted to giving them a break by doing more balancing, tight turns, and avoid the bigger obstacles for several days. When they feel much better I do a harder ride and after an hour or so they are pissed again.
    I may swap out the grips to something bigger. The ODI lock on grips on my KTM 300 are quite a bit fatter than the TRS. Though, I've often heard people suggesting thinner grips.
    Anyone else who rides 5-6 days a week struggle with this? How'd you fix it?
    #18
    riabma77 likes this.
  19. DyrWolf
    DyrWolf Long timer Supporter
    Jan 21, 2012
    2,713
    RICHMOND VA
    Ride like this guy
    #19
  20. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    15,404
    Dubuque, Iowa
    Who is that guy and is it photoshopped?
    #20
