Cam chain noise
Discussion in 'Parallel Universe' started by rwcfrank01, Feb 11, 2020.
  1. rwcfrank01
    rwcfrank01 Adventurer
    Nov 12, 2016
    23
    I’m in the market for a used F800GS and looked at one today. It was loaded with goodies like Matris fork inserts and Wilburs rear shock etc. when the owner fired it up from cold I heard the cam chain slap for about 2 seconds then the noise went away and the bike purred. Is this normal? 42,000 kilometers on the odo.
    sieg likes this.
  2. Strawdog
    Strawdog Strawdog
    Jun 5, 2012
    332
    Fannystelle
    Normal mine has F800GS 85000 KM on current engine it all good
    rwcfrank01 likes this.
  3. rwcfrank01
    Nov 12, 2016
    23
    Did it make the noise when new?
  4. nonchuck
    nonchuck Adventurer
    Jun 1, 2018
    35
    US
    Mine did/does.
  5. kaspilo
    kaspilo Been here awhile
    Jun 26, 2011
    112
    NW Arkansas
  6. adventuro
    adventuro Adventurer
    Aug 24, 2010
    54
    mocksville nc
    My 2010 has done it since day one, hasn't gotten any worse, 36,000 miles later. Wife's 2017 700gs can set for a month and no rattle on start up. I think they redesigned the tensioner at some point.
  7. bmwroadsterca
    bmwroadsterca RadioFlyer
    Jan 3, 2007
    974
    Lanark County near Ottawa ON
    As long as it goes quiet then there is no issue.
    sieg likes this.
  8. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    6,885
    South Jersey... Close to the Pines
    My 2013 800 had the rattle at 20,000 miles when I got it. I got tired of hearing it plus every once in a while it made a rattle for a split second sitting at a stop so I decided it was time to do the manual tensioner as linked to previously rather than take a chance.
    #8
  9. Strawdog
    Strawdog Strawdog
    Jun 5, 2012
    332
    Fannystelle
    SnDrtRider what brand did you get ?
    #9
  10. SnoDrtRider
    Mar 21, 2006
    6,885
    The California Motor Works one linked to above by Kaspilo...
    When I did the install I pulled the cam cover and check the valve clearance while I was in there as well.
    #10
  11. shuswap1
    shuswap1 Long timer
    Mar 30, 2014
    1,207
    British Columbia, Canada
    That's a great time to install the tensioner. I won't be doing the same, however, at a cost of $250 per bike(we have 2) in Cdn funds I can't justify that cost for a simple tensioner. I've installed them on other bikes but that is just a bit too much graft for me.
    I guess if you make it for a BMW and there are no competitors? Similar (most) tensioners are in the $US30-60 range, which is more palatable.
    Anybody know of alternative manufacturers?
    #11
  12. SnoDrtRider
    Mar 21, 2006
    6,885
    The thing is most of the tensioners on bikes that have tensioners available for $40-$60 have a problem that their tensioners lock and cannot collapse but in locking they put too much tension on and cause the chain to stretch.
    The BMW tensioners rely on oil pressure to keep them tight without applying too much pressure which is a good thing EXCEPT if you stall a bike on an uphill and for some reason you roll backwards with the clutch out the timing chain can easily jump a tooth without the oil pressure keeping the tensioner snug.
    When I bought mine a few years ago they were $170 (us)... I would rather spend $170 or even $250 to prevent a problem that could result in a repair bill in the thousands.
    #12
  13. shuswap1
    shuswap1 Long timer
    Mar 30, 2014
    1,207
    Can't argue with that, but I have never heard of that happening in over 50 years of wrenching my stuff. I am referring to tensioners that don't ratchet, are fully manual, which is the only type I have actually installed to date. It does take some care to get them just right during the initial install. So that's why I thought the perfect time to do this is while in there checking Valve clearances and can pay extra attention to the manual tensioner and get the tension set just as it should be.
    If I thought this would ward off a serious issue the tensioner would be changed, I just have never heard of this happening. There are other good reasons to change the tensioner....but I'd prefer a less costly option, given that I'd be looking at over $500 to do both our bikes.
    #13
  14. dpike
    dpike BeeKeeper Supporter
    Nov 21, 2015
    1,828
    New Jersey
    there's a thread here somewhere where an inmate was machining the plunger with tighter tolerances to build pressure faster i think and had good luck with it iirc. i thought he was going to produce them.
    #14
    rwcfrank01 and shuswap1 like this.
  15. SnoDrtRider
    Mar 21, 2006
    6,885
    I think shimming the spring or a slightly heavier spring would work as well.
    I wonder if anyone has compared a new spring to a used one both free length and tension?
    #15
  16. NCD
    NCD Dirty Hairy Supporter
    Nov 13, 2008
    808
    NE Ohio
    I have. I replace my stock tensioner every 12-18K miles. The new spring is always about 1mm longer than the used one coming out. I have often considered shimming the spring with a 1mm washer of some sort but never found anything I felt confident using.
    #16
    rwcfrank01 and SnoDrtRider like this.
  17. Shakey23
    Shakey23 Been here awhile
    Sep 12, 2016
    224
    Sherman, TX
    I have 96,000 miles on my 2013 800. It just makes noise. If it goes away it’s fine. I replaced my timing chain at 75,000 miles via the master link method posted on this site. It wasn’t difficult. While there I checked the valve clearance and they were still in spec. I change my oil every 5,000 miles. It’s a beast. Runs like a champ and I would highly recommend buying one! At 90,000 miles I took in on a 2,000 mile trip to Colorado and rode around on the alpine loop. I did have some cosmetic damage from dropping it but nothing that made me have to stop riding. I would recommend a GSA rather than the standard GS as they have a larger fuel tank. Going across New Mexico got a little hairy! Fuel stations are few and far between sometimes!
    #17
    shuswap1 likes this.
  18. sieg
    sieg Wearing out tires......2 at a time, day after day. Supporter
    Jul 9, 2008
    7,891
    Southern Illinois USA
    Had or have 2, 700gs, 1, 650 twin gs, 1, 800 gs. They all did/do it. The highest mileage one at 85000 of course did it the worst. (Or best, the way I look at it.) I would not use a manual adjuster because the factory one confirms two thing at start up. 1, I have good oil pressure, 2, my cam chain tensioner is working.
    #18
  19. Zoef zoef
    Zoef zoef Long timer
    Apr 19, 2009
    1,232
    Finnøy Island, near Stavanger, Norway
    And not having the risk with a wrongly adjusted manual tensioner leading to too much wear.
    #19
    shuswap1 and sieg like this.
  20. rwcfrank01
    Nov 12, 2016
    23
    Just picked this up with 12000 kilometers, no cam chain noise, yet 60341815635__6E8E0182-1E26-4645-923F-762262C6D4F3.jpg
    #20
