Camp Table
Discussion in 'Camping Toys' started by Jamie Z, Nov 15, 2019.
  1. Jamie Z
    Jamie Z I'm serious. Supporter
    Oct 17, 2006
    9,907
    Around Denver
    Anyone carry and use a proper camp table?
    There's not much more that I like than to have a nice big picnic table at my camp. It makes cooking and eating easier, and also helps setting up and packing easier, as it offers a place to lay out gear and organize.
    But mostly I wild camp, or stealth camp, and I don't have any sort of table available to me. In the past, I've used my side cases, or I find some logs laying around, and use those things as ad hock tables to eat from and cook on, even though it doesn't work very well. Or I cook on the ground and eat while holding my plate.
    But I've been looking at lightweight camping tables. This is a hard one for me since I normally like to travel as light as possible, and adding a TABLE to my kit at first seems unnecessary.
    So I'm looking for words of experience. Do you carry a table? Do you consider yourself a light packer? Do you stealth camp? What do you use the table for?
    Kermit makes a table: https://www.kermitchair.com/products/store/the-kermit-wide-table
    And since I've got a Helinox chair, I've been looking at one of their camp tables: https://www.rei.com/product/158007/helinox-table-one-camping-table-hard-top
    Thoughts? Ideas? Experiences?
    Jamie
  2. Yinzer Moto
    Yinzer Moto Long timer Supporter
    Jun 13, 2008
    31,027
    Pittsburgh PA
    I carried one of those Kermit tables for 2 months of riding and camping a couple years ago. We used it twice. I gave it away when I got back. I think one of the times we tried to set it up, it had gotten wet and swelled. It was a struggle to get it put together. Once it dried out, it was ok.
  3. Maggot12
    Maggot12 U'mmmm yeaah!!
    Feb 21, 2010
    18,459
    Canada's ocean playground
    Couple ideas beyond a typical table...
    My last 2 bikes had aluminum cases and I cut a bbq grill to fit inside my top case. Once at camp I place/clipped the bbq grill between the cases. this becomes the table/cooking area. The grill only took up 1/4" of space.
    Another time I used a large pelican case as my trunk. I screwed 1 of these on each corner and then when setting upI screwed a dowel in it for a table. If the dowel is strong enough, the case can also become a chair.
    DyrWolf likes this.
  4. EvilClown
    EvilClown Reality show stunt double Super Moderator
    Sep 3, 2006
    19,351
    In the shadow of the Uncanoonucs...
    Believe your answer is here...
    Just a matter of you 'allowing' yourself to bring it along as a self described light packer. From there it's simply a matter of finding a table that suits your needs.
    Freestanding?
    Attaches to the bike for support?
    Utilizes side boxes?
    The more I travel the more I've reduced the size of the load but there are some things that I bring 'just because' - like a big ol' Kermit if I'm going to a place where I'm going to want a comfortable chair.
    For you it can be your table. You've earned it.:deal
  5. MCMXCIVRS
    MCMXCIVRS Long timer
    Nov 13, 2006
    1,567
    Calgary, Alberta, Canada
    I have the soft top Helinox table and find it quite useful, well made and sturdy. I would like to have the hard top version if I were buying today, but can't justify replacing it just because. I will say that it has limitations; it is light weight which is good, but it also means it tends to be a bit unsteady especially on uneven ground. I use it mainly as an eating platform and a spot to hold a beverage at the campfire. The fabric top is not cooking or hot pot safe, nor is it really stable enough for me to trust putting a cookstove on. If I have a picnic table available, I will use it to set up my cooking gear on, if not, my side cases make a more stable platform for that job.
  6. HarveyM
    HarveyM Been here awhile
    Sep 10, 2010
    568
    Ottawa, Canada
    I picked up a Tekology camp table a couple years ago- Aluminium slat top 13 1/2" by 15 1/2" and 12 inches high, packed size is 17 1/2", 5" x 3" weighs 1.8 lb. At around $30 it you might see how it works for you. They also have a medium sized one at 16" high for $45.
    Jamie Z and DyrWolf like this.
  7. phreakingeek
    phreakingeek adventurer Super Supporter
    Sep 17, 2010
    1,973
    VA
    I used a fabric top table (china special...bought from amazon for $40ish). While it work just fine, packed size was almost 2 feet long. During a couple month long trips, used the table a handful of times. All-in-all, decided that it really wasnt worth the work to pack and set up when I have other options around.
  8. Jamie Z
    Oct 17, 2006
    9,907
    Around Denver
    I was looking at the hard top, but I can't find anywhere that says if it's safe to cook on.
    #8
  9. Bad Dad
    Bad Dad Been here awhile
    Apr 30, 2007
    818
    Been using one of these for 10 years.
    #9
  10. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    11,557
    Orange County, CA
  11. Jamie Z
    Oct 17, 2006
    9,907
    Around Denver
    Guess that means you like it? Seems kind of low.
    This just arrived today.
    I was looking at the Helinox table, but it sells for over $100. This one was $30 with free shipping. https://www.amazon.com/dp/B01HJ234E0/ref=cm_sw_r_cp_tai_tWB0DbDJAPZ8M
    I haven’t used it, just set it up. It feels pretty sturdy and it’s really light and packs fairly small. I’ll play with this in camp and see if it fits my needs.
    Jamie
    #11
    phreakingeek and HarveyM like this.
  12. Bad Dad
    Apr 30, 2007
    818
    What size did you get?
    #12
  13. Jamie Z
    Oct 17, 2006
    9,907
    Around Denver
    I got the small.
    The table top is 15.5” x 13.5” and it’s 12.5” high.
    It does seem smallish, but my stove and a few other small things fit on top, and that’s really what I’m looking for. Previously I’d been using various rocks, logs, or just setting everything on the ground.
    Jamie
    #13
    Bad Dad likes this.
  14. Jamie Z
    Oct 17, 2006
    9,907
    Around Denver
    That’s the trouble. Pack size for that table is 28” long. I want all my stuff to fit inside my panniers. As a rule, I don’t strap stuff to the outside on my bike.
    Jamie
    #14
  15. villageidiot
    Apr 29, 2010
    11,557
    Orange County, CA
    nowhere in your OP do you state that as a requirement
    #15
  16. Jamie Z
    Oct 17, 2006
    9,907
    Around Denver
    That's a requirement for me, sure. Other people have different thoughts and ideas. I'm curious what other people use and how they use it.
    Jamie
    #16
  17. Brun
    Brun Been here awhile
    Jun 29, 2012
    804
    BorderBurg, South East Oz.
    My solution: When I was thinking about racks for my soft luggage system it occurred to me that if the racks were connected by means of a horizontal surface I would have a table, and 'throw-over' racks that didn't have to stay on the bike.
    The frame is made from 8mm stainless rod and 25x3 flat. Top is 9mm marine ply.
    The bags hang on to the subframe ...
    .. and extra straps over the table tension everything up.
    The really nice thing about having skinny legs on the table is that it can be pushed into the ground to make the table level. I also carry another bit of plywood which becomes a shelf (or 'magazine rack' if you like).
    Here's the old dear, well laden for a 4 day camp in the bush:
    #17
    shinyribs, Ironforge, GPD323 and 27 others like this.
  18. phreakingeek
    Sep 17, 2010
    1,973
    VA
    Wow, that's a really nicely kitted out system. Well done!
    #18
  19. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    7,537
    below the sea
    I have a SnapOn collapsible table I was given. (Plate not included)
    They were about £20 at the time. It is a not very heavy, but packs as long as the legs. The top slats are fixed together with elastic and roll into a slimish shape.
    I gets used when we are base camping - up to six weeks, otherwise it stays home. Once levelled, works OK for proper cooking. Some times we pick up the cheapest chairs from the nearest supermaket, along with a frying pan and real glass glasses (we camp in a wine area).
    I think an improvement would be to saw an inch or two off the legs. a) pack size would be smaller, and b) would be a better height for working at while sitting down.
    The guzzi is from the days when road bikes all looked similar, little to no plastic, so lots of nooks and crevices, places to strap stuff like this.
    #19
  20. Big D
    Big D Sunny SoCal
    Jul 6, 2007
    302
    Grand Terrace, Ca
    Have taken this small lite 10x12" table when I knew I would be camping in the wilds. Can use as stool also. Out in the wilds you only have what you bring. On a motor cycle you are limited by space. Cooking on a small table is so much better than the ground. You are still on your knees, but its better. Don't count on finding the perfect flat rock or tree stump. Got this one in Quartzite AZ in January a couple years back. Was moto camping on BLM land, no nothing. Camco Aluminum Folding Table. enjoy 07GSA Sunny SoCal
    #20
