Canister Removal
Discussion in 'Hard. Core. (1090/1190/1290)' started by Deviant, Aug 6, 2017.
  1. Deviant
    Deviant Long timer
    Aug 14, 2013
    3,892
    Just need a little sanity check. I don't feel like pulling the whole tank, it's full and I'm still injured, but I do want to get rid of the charcoal canister to make room under the seat.
    If I remove it, I should be able to just plug the line going to the the valve and leave the tank vent under the seat right? Or is there a need to reroute the tank vent line?
    Also, if I just plug the valve line will the bike throw errors when it tries to pull from the canister?
  2. tmark1301cc
    tmark1301cc Long timer Supporter
    Jan 28, 2017
    1,216
    Chicago Suburbia
    Vent hose should be re-routed. There is a dongle to eliminate any error codes, supplied in a kit you can purchase from Rottweiler.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
  3. Capo Rick
    Capo Rick Please understand... Supporter
    Dec 30, 2005
    3,132
    NoPo Oregon
    The tank vents aggressively when it is hot. You don't want vapors spewing there or have gas dump under your seat if your bike tips
    Lewilewi and EkrebDK like this.
  4. Deviant
    Deviant Long timer
    Aug 14, 2013
    3,892
    Thanks. The cannister just vents under the seat so I figured it'd be fine, hadn't really considered fuel coming out. wonder if I can just pull it somewhere near the tail section instead of routing it to the other vent lines.
    Oh and, the rottweiler solution is to remove the valve, which I'm not planning on. Just not sure if the sensor is just a "hey I'm not here anymore" or a "hey I'm still here but not working correctly" kind of thing.
  5. V10SWC
    V10SWC Adventurer
    Aug 3, 2011
    18
    UK
    Removed my canister to allow me to place the tool kit and puncture repair stuff in the tail.
    Blocked and sealed one pipe and tucked it away in the tail, pulled the vent pip through the frame and re routed under the seat and heat cover and through a small gap in the frame which allowed me to feed it to the other drain points with no kinks and no tank removal.
    matt.the.ogre, Swoop and Deviant like this.
  6. Deviant
    Deviant Long timer
    Aug 14, 2013
    3,892
    Did exactly that, thanks! Wasn't much room but I got it snaked through after a bit. I did check and recheck that it was the right one, think I inhaled some gas fumes, there goes a few more brain cells.
    F650Dakar_Norway likes this.
  7. GoodOleBoy
    GoodOleBoy n00b Supporter
    May 14, 2017
    4
    Removed the entire system. Not much trouble pulling vent lines from charcoal filter. But, connecting new lines to throttle bodies was annoying due to space constraints. No issues with electronics afterwards. Re-routed tank vent along left frame and behind pegs.
  8. Lewilewi
    Lewilewi Ride it like you stole it......
    Oct 22, 2017
    3,271
    Europe
    did you notice any intermittent noises the bike made prior to removing the sas emissions canister, probably coming from the air box, usually very audible at slow speed or idle engine speeds
    if there was any weird noises, did the removal of the sas stop these noises,
    ive just started a thread on the weird noises the 1290 makes from new
    #8
  9. Swoop
    Swoop Been here awhile
    Feb 4, 2016
    149
    USA
    I'm planning on doing the removal on my '15 1190, using this video as a reference:
    No other additions or mod's associated at this time, just the removal for tool storage purposes.
    Anyone have any good advice to add specifically to this video? I like this vid' due to my low OJT mx moto skills level....("yes" I have used the search function)
    Thanks.
    #9
    billmaxx97, Dan Lorenze and Deviant like this.
  10. Lewilewi
    Oct 22, 2017
    3,271
    Europe
    Rottweiler s web site and you tube channel have outstanding step by step videos on the procedure.....one videeo solely on tank removal ....another on the theory of the system...
    i have a thread on it my self
    brand new 2017 sar 1290 engine noises (sas canister emissions possible)
    do you have the noises it makes
    #10
  11. Deviant
    Deviant Long timer
    Aug 14, 2013
    3,892
    The canister for sure has nothing to do with that and I doubt it's the SAS too. No need to ask the same question in a bunch of threads.
    Also, you don't need to do all the Rottweiler BS if you just want to free up storage space. Zero need to remove the solenoid and buy dongles.
    #11
  12. Deviant
    Deviant Long timer
    Aug 14, 2013
    3,892
    I pulled mine but left the vacuum hose capped under the seat. Saw no reason to pull it.
    BUT I'm pretty sure that the 1290R/S do not have the one way valve for the vent hose.
    I dropped my bike after removing the can and lost a bit of fuel. Have not verified that yet.
    #12
  13. SRTie4k
    SRTie4k Northeast Explorer
    May 11, 2009
    3,435
    Nude Hampster
    I don't think there is any dongle needed. I pulled my charcoal canister, plugged one line and rerouted the other 10k miles ago. I have yet to get any error codes. I believe you're thinking of the SAS.
    #13
  14. Lewilewi
    Oct 22, 2017
    3,271
    Europe
    just watched your suggested video , if i were you id watch rotweilers video.......i dont think that rear seat body work needs to come off really....although i have a 2017 1290 sa-r which is slightly different body wise.... for some reason he did not remove the valves of the side of the cylinders and blank them off....???
    #14
  15. Deviant
    Deviant Long timer
    Aug 14, 2013
    3,892
    Rotweiler has you to remove the solenoid for the canister too. if you did that you'd need a dongle. But that's pointless imo.
    #15
  16. Deviant
    Deviant Long timer
    Aug 14, 2013
    3,892
    You're confusing the SAS with the canister. The video he is just doing the canister to free up space under the seat.
    #16
  17. Lewilewi
    Oct 22, 2017
    3,271
    Europe
    ill be doing this soon on mine ..ill use the full stage 3 kit tho... cant stand the noise the sas makes
    #17
  18. Lewilewi
    Oct 22, 2017
    3,271
    Europe
    ahhh, fair enough...i did no read properly
    #18
  19. CO303
    CO303 Been here awhile
    Jun 11, 2016
    843
    Denver, CO
    I went to pull my canister shortly after buying the bike (1290SAR) and the canister wasn't even hooked up. Neither line and never any error codes. I rerouted the vent to the other vent lines in front, plugged the line from the pump and left it under the seat. No error codes and I have the tool kit, a plug kit and a tire pump in it's place. Deviant is right, you only need the Rottweiler kit if you remove the plumbing. I may do that later, like when I have to pull the tank for something.
    #19
  20. rick danger
    rick danger The further adventures of
    Dec 24, 2005
    12,252
    Oneonta, NY
    You wont get an error code unless you unplug the wiring to the solenoid
    #20
    kokos79 likes this.
