Cannisterectomy Lite
Discussion in 'Dakar champion (950/990)' started by furndog, Apr 17, 2006.
  1. ethanggg
    ethanggg In search of dirt
    Feb 12, 2017
    13
    Portland, OR
    The canisterectomy lite still works in 2017! My '05.5 950 has had a dead spot in the middle of the power band (~5k rpm) where on full throttle the bike would hesitate before powering up again into 6 and 7k rpms. I was also under the impression my bike should be power wheeling no problem in 1st and 2nd gear, but not the slightest wheel lift. ADDITIONALLY, I was having some hard starting issues. It was by way of the hard starting thread that I came upon the canisterectomy and lite. I thought, this sounds like a quick possible fix. Fyi I have never dropped the bike (YET), but the previous owner probably did. I pulled the plug and low and behold, a bunch of oozy oil/gas mixture shot out. I went on a ride the next morning. The bike still took a minute (and a good amt. of choke) to get started up. I was on my way to my mechanic to finally try and get this issue sorted. Getting off the highway I yanked on the throttle and to my surprise, no stutter! I was skeptical so I took to some long straight roads and pulled through each gear, only to find that the issue has seemingly disappeared! I wondered if I might also be getting a bit more power...so I pulled back in 1st gear and did my inaugural wheelie on the 950. Since then (yesterday) I can't seem to keep the front wheel down :lol3
    My question here is, is it possible for this seemingly super minor fix to have such a significant impact on throttle response, power distribution/torque etc? Also, will the full canisterectomy provide me with even more comprehensive results re: hard starting? Cheers!
    #41
  2. DrFabulous
    DrFabulous Been here awhile
    Mar 20, 2016
    128
    Boise,ID
    I pulled my bash plate and checked in there, but only noticed a few hoses with no plugs. Anyone know if that hose needs to be plugged when in normal use? I assume someone had laid the bike over and just pulled that plug altogether. Anyone see a problem with that?
    Sent from my SM-G930V using Tapatalk
    #42
