Can't decide on crash bars for Africa Twin...
Discussion in 'Japanese polycylindered adventure bikes' started by Hecklerboy, Aug 12, 2019.
  1. Lost Cartographer
    Lost Cartographer Been here awhile Super Supporter
    Feb 7, 2011
    756
    AZ and CA
    I don't like the roll cage look either.
    But I also don't like replacing ridiculously brittle (and ridiculously expensive) pieces of plastic.
    So I sucked it up and bought the Heed bars.
    They look ugly on the bike.
    But they look great when the bike is on its side.
    #21
    Junglejeff1 likes this.
  2. eakins
    eakins Butler Maps
    May 29, 2002
    36,155
    Fort Collins, Colorado
    I installed Outback ultimate package on one of our rental ATs. Bomber package.
    Bike has gone down alot...works as advertised.
    #22
    Cuchulainn likes this.
  3. Yooper_Bob
    Yooper_Bob Insert witty saying here....
    Aug 31, 2005
    4,879
    Da UP, eh! (Marquette, MI)
    I have the Heed bars and am very happy with them. Very reasonable price and excellent fit/finish/quality.
    I have "tested" them a couple of times and zero issues!
    #23
  4. grego10r
    grego10r Adventurer
    Jul 6, 2017
    21
    nj
    i use heed and so far so good
    #24
  5. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,635
    Upper Michigan
    I got the heads because yooper_Bob recommended them to me a couple years ago.They have been tried and tested and not found wanting.Excellent fabrication and welding and bars have been very crash tested.Unreal the great price they sell for.I don,t care for the full the cage look either but a couple slide outs they saved my plastic.
    #25
  6. Lear60man
    Lear60man Sleeping
    Nov 5, 2007
    901
    So Cali
    I went for the full meal deal on my brand new ATAS From Outback. You dont get better advertising than dropping a bike a few times on camera. My advice is to read the instructions a few times and line things up to get a game plan. If you fit the lowers first, you have to take re-remove the main cross bolts by the radiators to later mount the mids. Kind of a PITA to redo the main front support but it went together ok. If I had to do it again I would mount the lowers and mids together in front, then where they mount in the rear behind your knees. The only modification I did was to elongate the upper forward hole on the rear/upper/right side a few MM's ( I had to go up and forward 45degrees about 3-4 mm's). No matter how we pulled or cured, we couldnt get all three holes to line up enough to get the bolts threaded. Speaking of threading, The power coat can be a bit thick and ooze into the threaded holes. Take a moment to pre-thread the bolts so you arent trying to do a TaiChi pose while not stripping a bolt. If you get white, do yourself a solid and buy a 99 cent jar of gloss white Testors model paint. You will get some scratches during the install and the Testors paint is a dead on match.
    Finished product with some $30 Cree lights and a $10 handelbar wiring kit. Threw on some reflective tape for some added flair:
    #26
  7. ski-line900
    ski-line900 Been here awhile Supporter
    Nov 20, 2012
    596
    Seattle
    The rear "mounting" being clamped to the pressed steel part of the frame seems odd.
    #27
  8. Junglejeff1
    Oct 20, 2016
    4,635
    Upper Michigan
    Heeds hook up the there also and it works well.Very strong part of frame.
    #28
  9. Hecklerboy
    Hecklerboy Adventurer
    Jan 6, 2015
    58
    Cowen, WV
    I really like the option of buying the Outback Motortek crash bars in sections. I plan on getting the crash bars and engine guards and then if needed I can always add the upper crash bars later.
    #29
  10. Lear60man
    Lear60man Sleeping
    Nov 5, 2007
    901
    So Cali
    I wish the other side of that mount was the same type. Super easy fitting on that attachment point. Other thoughts: Fit/finish/welds are all high quality. Really impressed with this set of training wheels. Makes the stock 'light bar' seem like am umbrella pole in terms of ruggedness.
    #30
  11. mentolio
    mentolio King of the island of unwanted toys...
    Jul 14, 2016
    821
    Man, was just going to order their (Outback Motortech) last in stock set of silver lower and mid combo bars....too late, they gone!
    #31
  12. Hecklerboy
    Jan 6, 2015
    58
    Cowen, WV
    Yeah, I'm on their email list for when the black come back in stock.
    #32
  13. mentolio
    Jul 14, 2016
    821
    I'm on the list for both, can't decide which I would like better. My AT is the 2016 silver. I think either would look good.
    #33
    Hecklerboy likes this.
  14. mentolio
    Jul 14, 2016
    821
    I didn't like that at first either, thought it might be a "weak point." Then I watched the video of Lorry (the owner of the company) dumping what is purported to be his own bike, on that side, multiple times on pavement and gravel. That quickly changed my mind.
    #34
  15. Hecklerboy
    Jan 6, 2015
    58
    Cowen, WV
    I've got the same year and color.
    #35
  16. davidji
    davidji bike curious
    Mar 16, 2009
    2,616
    california
    Do you have DCT or not?
    I too wanted a more minimalist setup. The bike was already the heaviest I've owned, and I also didn't want to complicate service with a ton of extra crap to remove. So I went with SW Motech.
    But I realized the DCT is pretty vulnerable--less so after I installed a SW Motech bash plate. On the stator side I have a thin aluminum stator guard, but no such thing exists for the DCT side.
    I decided I was either going to get a B&B Dakar bash plate for the engine coverage, or switch to Heed Bunker bars. The latter cost less, and right now I'm waiting for them to arrive. If I didn't have DCT I think I would have been happy with what I had (SW Motech bars and plate)
    #36
  17. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,412
    日本
    I had Rugged Roads lowers. They did a good job of protecting the engine cases when I dropped the bike and also made great footrests while super slabbing.
    #37
