Canyon Dancer Rings - another use?
Discussion in 'The Garage' started by DirtyDog, Jul 11, 2016.
  1. DirtyDog
    DirtyDog Omnia mea mecum porto Supporter
    Apr 27, 2007
    13,212
    Tulsa... it's OK
    Just thought I'd share this. If it's not novel, forgive me.:1drink
    Our entire work fleet (pickup trucks) has transitioned to CNG. The cylinders occupy the front 1/3 of the truck bed and the protective shroud conceals the front anchor points for securing cargo. Furthermore, the metal shroud clearly states "No Drilling." I haul irregular shaped objects often and need lots of anchoring options. All the really heavy stuff goes on a trailer.
    So after a couple months of casually looking around for solutions, here's what I came up with...
    katbeanz and Whodatschrome like this.
  2. RetiredandRiding
    RetiredandRiding Retired to Ride Supporter
    May 22, 2015
    1,557
    Da Lat, Vietnam
    Great idea!
  3. texas123
    texas123 Been here awhile
    Jul 8, 2018
    361
    Katy, TX
    Great application, but you should turn the ring portion to line up with the strap/
  4. ricker
    ricker booger eatin' moron
    Feb 7, 2008
    307
    Paonia,Co
    And put them on your lower triple clamp pinch bolts for tie down points-works great
  5. ohgood
    Sep 21, 2010
    9,963
    alabama
    if you look in the corner of truck beds, you'll see your down loops. they don't get loose, come unscrewed, or need extra holes drilled. use em
  6. squish
    squish Out of the office.
    Dec 4, 2003
    9,160
    Where the Ghetto meets the sea.
    You might also be able to use the bolt hangers used in rock climbing,
    And IIRC they are around $40 for about 10 of them.
  7. Tinker1980
    Tinker1980 Doesn't ask why, only asks how
    Dec 10, 2012
    4,844
    Nowhere, OK
    You mean those hooks under the CNG tank?
    JimVonBaden and DirtyDog like this.
  8. ohgood
    Sep 21, 2010
    9,963
    alabama
    i dunno, everything 've seen with cng started with forks and ended with lift :-)
    #8
  9. DirtyDog
    Apr 27, 2007
    13,212
    Tulsa... it's OK
    I'm gonna make sure I take these off when I get a new truck (non CNG this time).
    #9
