Carburetor help, please
Discussion in 'The Garage' started by FreyZI, Aug 24, 2018.
  1. FreyZI
    FreyZI Adventurer
    Apr 24, 2015
    35
    Happy Valley
    TTR 125 sat for quite a while at POs. Rebuilt carb. Runs, but idle doesn't want to stay set. I can adjust idle right to where I want it, but when I give it gas and then let go, it either idles faster or or is slow in shedding rpms. Spring for throttle wire seems fine. Any suggestions on where to look for gremlin.
  2. sieg
    sieg Wearing out tires......2 at a time, day after day. Supporter
    Jul 9, 2008
    6,602
    Southern Illinois USA
    Sounds like a vacuum leak or mis-adjusted air screw/fuel screw.
  3. shovelstrokeed
    shovelstrokeed Long timer
    Jun 20, 2003
    5,461
    South Florida
    First thing to make sure of is adequate slack in the main throttle cable. You should be able to find at least 1/16" of lift at the cable end atop the carb without any change in idle speed.
    Then make sure the slide is dropping all the way onto the idle stop. Then recheck the play in the cable.
    Slow return from a high idle is normally indicative of a lean condition. Try richening the idle mixture screw.
    If none of the above works, you probably have a minor air leak, if not at the boots it could be the throttle Butterly shaft or the slide itself is worn and leaking within the body.
    spokester likes this.
  4. concours
    concours WFO for 47 years
    Dec 2, 2008
    6,748
    Kensington, NH USA
    Nope.
    Your idle passages are clogged, and your idle screw is in enough to begin running on the needle.
    Clean it THOROUGHLY this time...
    Richy, Hittman, gsweave and 2 others like this.
  5. ohgood
    Sep 21, 2010
    8,650
    alabama
    blast out all the passages with carb cleaner then air rinse and repeat a few dozen times. this is while fully disassembled.
    blast out all the Jets similarly. pull all the air/mix/idle access and do similarly.
    choke circuit too.
    all around the side/needle area also.
    it's not about having a positive flat bowl, but instead getting all the passages completely clear.
    when you think it's clean, put a pocket magnifying glass on it with a strong light and look again.
    Hittman likes this.
  6. scratchypants
    scratchypants Loathes the impolite
    Sep 30, 2003
    1,813
    Quebec
    Not shedding RPM's is usually a result of running lean. That can be caused by all previously mentioned conditions - dirt, vacuum leak, improper mixture settings. Anybody who has dealt with rebuilding carburetors has at one time said "I cleaned and rebuilt it - it must be something else" - this guy included. I'll add that not all carb rebuild kits are of equal quality. Spend the money on a reputably sourced kit, and do it again. Also, canned carb cleaner is no way to clean a carb (in case that's what you did) - you need to submerge it in a bucket of cleaner.
  7. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    6,269
    South Jersey... Close to the Pines
    I had a Honda XR 100 that I borrowed from a friend for my wife to practice riding on.
    It had a weird idle problem and I found that someone had the carb apart and put the needle in ABOVE the throttle cable retaining plate that sits on top of the slide below the return spring.
    The needle could float all over wherever it's happy self want to causing erratic idle issues.
  8. tominboise
    tominboise Long timer
    Jun 17, 2007
    2,425
    Boise, ID
    I had a TTR125 with similar issues. I couldn't get mine started. I rebuilt the carb once and then the dealer rebuilt it and then when it still wouldn't start without a lot.of drama, it went down the road.
    #8
  9. FreyZI
    FreyZI Adventurer
    Apr 24, 2015
    35
    Happy Valley
    Thanks for the thoughts, all. BTW, I completely disassembled and left it soak (overnight — got busy and temporarily forgot about it) in carb cleaner. It didn’t actually look that bad beforehand, except that PO had used some sticky goo in addition to the gasket for the float bowl. After the extended dip, I blew out all passages with compressed air. I will admit to using cheapest kit I could find on FleaBay.
    #9
  10. Tinker1980
    Tinker1980 Doesn't ask why, only asks how
    Dec 10, 2012
    4,476
    Nowhere, OK
    I've found it helps to clean the jets with a strand of wire or even an old guitar string. Removing the jets, poking something through them, then spraying them out helps a lot.
    #10
    greasyfatman and TonyKZ1 like this.
  11. pvt joker
    pvt joker Latebird
    May 11, 2011
    336
    Cucamonga
    There's a passage in the float bowl casting that is part of the idle circuit. It needs to be soaked, cleaned with a fine wire and blown out with hp air. You will always have problems if you don't get this passageway cleaned effectively.
    Or you can put on a new bowl - Nuke it from space, its the only way to be sure.
    #11
    VanXR likes this.
  12. PeterW
    PeterW Long timer
    Nov 11, 2005
    4,086
    Gold Coast
    Try cleaning it but there are occasions when I've just tossed carbs because nothing worked. (As above)
    #12
  13. squish
    squish Out of the office.
    Dec 4, 2003
    8,615
    Where the Ghetto meets the sea.
    I had a XR250L
    I could not get the carb to work right.
    It wouldn't idle, but it would run fine off idle, or it would idle but then bog as soon as you lifted the slide.
    Then it started leaking,
    Damned thing drove me crazy, I swapped it to my buddy for the use of his trailer that his stores on his property.
    He ordered up an all new cleaning kit and float.
    It still wouldn't work. He even took it to a buddy who used an ultrasonic bath.
    Still wouldn't work.
    He gave up and bought a NOS or early take off stock carb, (or maybe a XR250R carb)
    And I shit you not, it bolted on and the bike ran perfect, one kick, no bog, perfect idle,
    He paid like $50 for the carb that between four of us had spent hours working on.
    TL/DR
    Try cleaning it one more time, or just buy a new carb and be done with it.
    #13
  14. JohnCW
    JohnCW Long timer
    Dec 30, 2013
    3,529
    Sydney, Australia
    If you used anything from that kit other than just the gaskets ...... there's your problem.
    Go pull the jets, needle, and float valve or any other mechanical bits replaced out of the bin if you haven't emptied it yet, clean them up, and reuse. Assume NOTHING in that kit is either the correct size or of a suitable quality.
    #14
  15. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    4,924
    West of the West, Oregon
    Very common on small hondas. Valves get tight and it will run lean, with a floating idle.
    #15
  16. sieg
    Jul 9, 2008
    6,602
    Hmmm I can see a tight valve effecting fuel/air delivery and compression not fuel/air mixture, as in leaning the mixture. ?? How is this possible?
    #16
  17. shovelstrokeed
    Jun 20, 2003
    5,461
    South Florida
    It isn't possible or even likely. A loss of pumping pressure is possible so compression ratio goes down, this could lead someone who is reading a plug to make an error. Reading plugs with oxygenated gas and zero lead is a useless exercise in today's world anyway. Wide band O2 sensors have made the need to read a plug more or less obsolete. Most people have no idea how to interpret a reading anyway.
    #17
    sieg likes this.
  18. sieg
    Jul 9, 2008
    6,602
    What he said.^
    #18
  19. fast1075
    fast1075 Not a Lemming Supporter
    Dec 28, 2013
    1,540
    Flaw'da
    Textbook plugged air bleeds. Trust me.
    #19
  20. kenny robert
    kenny robert Long timer
    Aug 21, 2015
    1,642
    south orygun
    not applicable here
    but on older machines with centrifugal mechanical spark advancer units
    a sticky advancer ,that is reluctant to return to fully retarderd
    will cause high idle
    that said always make sure ignition is funtionally as new
    before carb tuning/troubleshooting
    #20
    sieg likes this.
