Cardo Packtalk Bold with JBL speakers
Discussion in 'Equipment' started by Drif10, Jan 17, 2019.
  1. TBTSyncro
    TBTSyncro Been here awhile
    Dec 3, 2014
    482
    They plug in to the headphone port, not the speaker connector. In theory you could have the speakers installed, but use headphones only when you wanted.
    #81
    Chipk likes this.
  2. griemak
    griemak n00b
    Jun 18, 2019
    3
    Pittsburgh, PA
    Yes. Two wires come from the harness. One is a proprietary connector for the microphone. The other is a standard 3.5 mm stereo audio female jack. Any earbuds, speakers, headphones, etc. that has a 3.5 mm stereo audio male plug will work. The JBL and non-JBL speakers that come with the unit in the box terminate with a 3.5 mm stereo audio male plug.
    As for volume, once I positioned the speakers correctly, while wearing ear plugs, I have the volume at roughly 40-50% and can hear music, intercom, GPS, and phone calls at 85+ mph. I had to play with the Cardo Connect setting the individual volume levels. Default, the "phone" was higher than the others.
    I'm currently battling discomfort, may have to break out the knife and carve a bit of foam out of where I have the speakers mounted. I have an HJC IS-17, it does not contain speaker cut-outs.
    #82
    Chipk likes this.
  3. Cilantro
    Cilantro Adventurer
    May 29, 2018
    92
    North Alabama
    That makes sense, thanks.
    Not to derail the thread- but, how well does the Cardo bold get along with a modular helmet? How does the mic wire get routed?
    #83
  4. griemak
    griemak n00b
    Jun 18, 2019
    3
    Pittsburgh, PA
    A boom mic is included in the box with two sticky velcro mount points, same as an open face. Half helmets require an adapter that solidifies the boom to the unit instead of the helmet.
    #84
  5. cjmadura
    cjmadura Been here awhile
    Mar 4, 2008
    564
    Western Oregon
    Thanks for the link. I actually ordered a similar product from Amazon yesterday. I figured if I reduce the NRR I might be able to hear the comms better while still keeping the wind roar down at safe levels.
    #85
  6. lacofdfireman
    lacofdfireman Long timer Supporter
    Jan 29, 2008
    1,575
    St. George, UT
    I’m a Cardo convert after using Sena for many years. Been using the Packtalks for a few years now. Just recently bought the new JBL Bold. Best system to date bar none.
    #86
  7. MoneySlide
    MoneySlide Tall Teller of Tales
    May 2, 2014
    39
    North Alabama
    Is there any pros or cons between the bold and slim models. I just got rid of my sena 30K and looking to buy a Cardo
    #87
  8. cjmadura
    Mar 4, 2008
    564
    Western Oregon
    Tested the 20 dB musicians plugs today. At first I thought the wind noise sounded just too loud for comfort, but when my ride was done I realized the harsh, truly loud wind noise was gone and I was only hearing a low-pitched rush of wind - not bad at all. The radio was super clear and I needed to lower the volume to a comfortable level. I think I found my solution, so thank you!
    As a bonus they are much more comfortable than the foam plugs I've used forever, and easier to insert to boot!
    #88
    HYLYNDYR and dietDrThunder like this.
  9. CharlesH
    CharlesH Support those who support you.
    Jul 29, 2006
    376
    Albertville MN
    "No noise" ear plugs are my favorite. Haven't used with my packtalk bold yet though. Still have to install it to my helmet.
    #89
    Themastermike likes this.
  10. Travman
    Travman Long timer Supporter
    Aug 19, 2010
    1,036
    Marietta, GA
    Both units are the exact same functionality wise except the Bold has a little better range. Also check that the slim battery will fit your helmet in the rear. Other than that, it comes down to which form factor you prefer.
    #90
    MoneySlide likes this.
  11. TBTSyncro
    Dec 3, 2014
    482
    as provided by Cardo (since its not in any of their documentation, but this feature has been available since 4.2)
    * This new feature will allow you to use your bike’s infotainment system (Such as BMW’s TFT and similar systems) or a 3rd party GPS device, as a connecting platform between the phone and your Cardo unit.
    1. Pair cardo to BMW navigator (GPS Mode)
    2. Pair Phone to BMW navigator (uncheck phone calls in the list)
    3. Pair cardo to TFT
    4. Pair Phone to TFT
    Still waiting to hear back in regards to doing this with a GPS as the connecting platform. Hopefully their 2 day support doesn't take 14 days again. :)
    #91
  12. Chipk
    Chipk Adventurer Supporter
    Jan 19, 2014
    84
    Just south of Chicago
    My Sena is currently wired to the mounted speakers. When I want less road noise I put my earbuds on and plug then into a different 3.5mm input on the unit and do not have to unplug the speakers.
    Sounds like with the Cardo I have to choose one or the other or can I have both connected at the same time?
    I also play music from my phone (via Bluetooth) from any source, Pandora, Spotify, any app on my Android, will I be able to do the same with the Packtalk?
    #92
  13. Daechir
    Daechir Adventurer
    Oct 14, 2018
    51
    Belgium
    With the packtalk you need to use the same connector. So you can't connect them at the same time without a splitter. But you keep your waterproofing.
    And I can get my packtalk to accept any music source, from my phone and even my LCD from my motorcycle. It's a bit of a change but I came from a sena 20s and I'm not going back.
    Hope this was helpfull.
    Grtz
    #93
    Chipk likes this.
  14. Chipk
    Jan 19, 2014
    84
    Yes it did, thanks.
    Glad to hear you like it, I'm coming from a 20s as well and looks like I would add that splitter.
    Did you get the bold or the slim? Unsure, from a few comments, if the slim battery would bother me or not on my xd4 helmet...
    Chip
    #94
  15. Kingfish
    Kingfish Been here awhile
    Nov 30, 2007
    157
    Has anyone installed the Packtalk Slim in the Klim Krios Pro?
    #95
  16. draco_1967
    draco_1967 Spoon!
    Aug 16, 2011
    633
    Salt Lake City
    I switch back and forth between my earbuds and speakers. I just unplug the speakers and plug the earbuds in. It's super easy. I do need to adjust all the volumes in the app when I switch because I have them maxed with the speakers, and at about 20% with earbuds. Even with the volumes in-app set that low, I still have the master volume control (little wheel on the headset) at the lowest setting.
    #96
    Chipk likes this.
  17. Roadhawg011
    Roadhawg011 Been here awhile
    May 25, 2015
    466
    South Africa
    I Bought the SmartH last weekend and installed into a Tour X4 (XD4 for you). The local cardo suppliers obviously have excess stock because the SmartH is less than half the price of the Slim or Bold, for essentially the same piece of kit as the Slim. (I believe they simple re-released the SmartH as the Slim. Slim has added/better voice commands though)
    It installs pretty easy, The battery pack is not noticeable when riding, but is noticeable when you put the helmet down, it seems like it could tip over more easily so just watch out for that.
    I feel it a bit if I am standing and purposely looking up more than usual. It touches my Neck brace. I don't think it's a problem it's just a slightly reduced ROM that I am not used to. Will probably go for a proper ride this weekend and see if it actually bugs me or not.
    Excuse the dirty helmet and old sena mount residue:
    I think I got both the control unit and the battery sitting more flush with the rim of the helmet after those pics. Takes more force than you think, just be careful haha. I used the long clip for the rear and the attachment without the rubber piece (you'll see what I mean if you have the kit in your hands)
    #97
  18. Roadhawg011
    May 25, 2015
    466
    South Africa
    If the pricing was the same, I'd probably get the Bold though. Just seems simpler. But for half price.....The SmartH suits me good.
    #98
    Chipk likes this.
  19. massrider
    massrider Been here awhile
    Apr 23, 2006
    481
    Mas a chews its
    The biggest reason I chose the Bold over the Slim is the ability to pop the Bold off the helmet and charge it from my battery pack in the tank bag while I'm riding if needed.
    BTW, I just got my JBL speakers in the mail, I'm hoping to get them fit into my helmet and try them out today!
    #99
    Themastermike and Chipk like this.
  20. Roadhawg011
    May 25, 2015
    466
    South Africa
    That is true as well. I thought the control unit could separate from the whole setup on the slim but it can't. The battery life seems really good though so charging at stops is fine for me.
