Cardo Packtalk Bold
Discussion in 'Equipment' started by ubermick, May 8, 2018.
  1. draco_1967
    draco_1967 Spoon!
    Aug 16, 2011
    978
    Salt Lake City
    Where did you mount it on the helmet? I couldn't find a good spot for the clamp mount, nor a flat spot for the stick-on. I ended up taking the plastic cover plate where the X-comm is supposed to go, and filed the ridges down. Then I used the Cardo stick-on mount to that. It has been working great for the last year.
  2. The Cone of Silence
    The Cone of Silence Been here awhile
    Jan 16, 2006
    473
    Kurrajong, New South Wales, Australia
    That's a nice solution mate.
    I removed the internal Nexx bracket that the external Nexx 'placeholder' plate screws into so I would have room to slide the clip between the inner and outer skins; the bracket was just a bit too bulky on the inside and wouldn't let the clip pass.
    The external plate seems to be well clamped in place now by my Cardo bracket but I'm not 100% as it isn't screwed in anymore and might end up sealing it with some silicone sealant. I'll see how I go. Ideally I'd still like it to be farther forwards so I might end up stealing your solution.
  3. heatmizr
    heatmizr n00b-tastic
    Jan 5, 2012
    1,056
    CLT, NC
    My Shoei GT-Air 2 had a similar mount area on the side. I just avoided it altogether and stuck my Bold to the helmet in front of it. It's actually easier to reach being a little further forward.
  4. Lost-Again
    Lost-Again Been here awhile Supporter
    Jul 12, 2016
    197
    Texas
    For those with a Arai XD4 how did you mount the speakers?
  5. Lost-Again
    Jul 12, 2016
    197
    Texas
    Well…. I’m silly. I didn’t realize the speaker velcro sticks to the earpiece material:-)
    Zubb likes this.
  6. cblais19
    cblais19 Long timer
    Nov 3, 2017
    6,089
    NoVA
    I mounted mine in the little pockets under the cheek pad cover. I need to play with it more though, unlike all other Arai helmets the XD4 pads put the speakers back from your ears.
  7. jb882
    jb882 13HP of fury.
    Aug 5, 2014
    1,500
    Peoples republic of Taxachusetts
    i did the same when i had mine, the only drawback is there move around sometimes when you put the helmet on. I have had mine move enough that i have had to take their helmet back off and reposition their speaker so i could hear it. This was one of my biggest gripes with the XD4 when i wore one.
  8. heatmizr
    Jan 5, 2012
    1,056
    CLT, NC
    My PTB came with extra pads, can't you stick those behind the speakers to bring them closer to your ears?
  9. Air Force Vet
    Air Force Vet Been here awhile
    Feb 9, 2013
    725
    Albuquerque, NM
    That's what I thought the extra pads were for.
  10. Lost-Again
    Jul 12, 2016
    197
    Texas
    Motomamatx likes this.
  11. cblais19
    cblais19 Long timer
    Nov 3, 2017
    6,089
    NoVA
    I used the Velcro pads to give them a surface to stick to behind the cheek pads covers. However, those pockets put the Speakers around the top of my ear and slightly back. The issue is the actual position, not the depth.
    bigjohnsd likes this.
  12. fmhrider
    fmhrider n00b
    Aug 9, 2021
    7
    Port Coquitlam
    I was looking for solutions to Siri via Packtalk and saw a suggestion to turn off button for the listen for "Hey Siri" and then reenable it. Also, in the Siri responses (in Siri and Search), I enabled choice to Always show Siri Captions and also Always show Speech
    This helped show what was being received by the IOS system via Cardo mike.
    This has solved the open Siri bubble for me.
    Melensdad and SoilSampleDave like this.
  13. fmhrider
    fmhrider n00b
    Aug 9, 2021
    7
    Port Coquitlam
    resource here https://www.fonegeek.com/iphone-issues/siri-not-talking-fix.html
  14. fmhrider
    fmhrider n00b
    Aug 9, 2021
    7
    Port Coquitlam
    also, for some of you who have British or similar accents (maybe Aussie, New Zealand, etc.) there is a language choice in Cardo settings for English (United Kingdom) which may help
  15. Langerik
    Langerik Adventurer
    Oct 6, 2018
    10
    Netherlands
    Got the same helmet and a freecom4+. A friend printed this model with a 3d printer. Not the most flat option but easy to use and non-destructive. A great benefit I see is that the wires for the speakers go through a hole instead of under the helmet so it does not wear out by placing the helmet on a surface
  16. The Cone of Silence
    Jan 16, 2006
    473
    Game changer. I was having trouble being understood and was having to put on an American accent which varied between the deep south and the Bronx on any given command. I'm English but have spent the last 20 years in Australia so I have a hybrid accent that voice recognition systems struggle to understand.
    Nice work, fmhrider, thanks mate.
    fmhrider likes this.
  17. Zubb
    Zubb he went that-a-way... Supporter
    Sep 8, 2002
    4,428
    San Diego
    Finally got fed up after riding 3,000 miles and not able to hear half of the podcasts and audible books. the PTB with JBL 40mm speakers couldn’t keep up with me at 70-90mph. With or without foam earplugs.
    Ordered the 45mm speakers today.
  18. boulet_boulet
    boulet_boulet Long timer
    May 14, 2018
    2,086
    Maine
    I see how to add riders to a group in DMC mode using the app, but I don’t see any way to remove a rider other than to create a new group. Anyone know how to remove a rider without creating a new group?
    TIA
  19. Zubb
    Sep 8, 2002
    4,428
    San Diego
    They are definitely an improvement over the 40mm JBL. Volume is a little higher, clarity is a little better, together it makes the sound at 70-90 mph ‘better’. Worth the money? For me, yes but I doubt I could convince some others. $80 is steep for the small gains. before, I could hear 50% of the podcast at 85mph. Now I hear 80% of the podcast.
    Klim Krios Pro helmet.
  20. cblais19
    cblais19 Long timer
    Nov 3, 2017
    6,089
    NoVA
    Podcasts are a much trickier proposition with wind noise too!
    Zubb likes this.
