Cardo Packtalk Bold
Discussion in 'Equipment' started by ubermick, May 8, 2018.
  1. mickthesaw
    mickthesaw Adventurer
    Jun 1, 2016
    15
    uk
    "The parallel bluetooth is for sharing music with another rider,"
    not according to Cardo's blurb two seperate channels
  2. miken0vf
    miken0vf Been here awhile
    Apr 17, 2018
    367
    Broomfield, CO
    Yep, I'm wrong here. Thinking of something else.
  3. HAL 9000
    HAL 9000 2014 Yamaha FJR1300
    Jun 4, 2017
    781
    NC
    Even with a noisy helmet (even open face), people have had success with the Packtalk cutting out the wind noise. In the app, there are mic sensitivity adjustments. Also, if your buddy is using the boom mic, make sure the yellow arrow on the mic is directly facing his mouth. If it's rotated slightly off axis, the noise cancellation is much less effective.
  4. rider1150gsadv
    rider1150gsadv Long timer
    Oct 6, 2003
    10,883
    Ft Likkertail , USA
    I will tell him to readjust the mic in the app! Tx! :thumbup
    HAL 9000 likes this.
  5. Farmernick
    Farmernick Adventurer
    Sep 24, 2013
    27
    Hants UK
    Just done the latest update and now lost my voice command and phone answering, so that’s good!
  6. mrmagloo
    mrmagloo Been here awhile
    Jun 24, 2020
    163
    NW Chicago Burbs
    Just got mine and wasn't thrilled when I found there are two different competing, and incompatible updaters they have listed on their support sites. Gosh, why do all these hardware mfr always seem to stub their toes so badly on the software side?
  7. Phil8dirt
    Phil8dirt '17 BMW R1200GSA
    Aug 6, 2018
    135
    VIctoria, MN, USA
    I have a pair of Bold JBL for me and my wife. However, I've also put audio kits on my kids helmets for when I ride with them but they don't have the Bold. So unless they are riding with me they are riding without the Bold attached. Has anyone found a way to cover the audio kit mount while riding so that the audio pins are not exposed to the elements when raining? Or is the only option for them (not me) to buy a Bold for themselves.
  8. Bayner
    Bayner Long timer
    Mar 27, 2008
    2,429
    Penticton, BC, Canada
    Use a product like ACF50 to protect the contact points and related architecture and save yourself the cost of an additional unit.
  9. mrmagloo
    Jun 24, 2020
    163
    NW Chicago Burbs
    Some enterprising person could probably design a 3D printed snap fit cover.
  10. bmwroadsterca
    bmwroadsterca RadioFlyer
    Jan 3, 2007
    1,186
    Lanark County near Ottawa ON
    Funny I was thinking this morning that I might do that.
  11. mrmagloo
    Jun 24, 2020
    163
    NW Chicago Burbs
    Is the race on? Seriously, I really don't have the time now, but thanks considering it. I'm sure plenty of folks would appreciate it.
    Imho, the biggest issue is, unless you develop a dual durometer piece, one hard to create the snap in footprint, so it stays in place, and then a softer flexible piece to seal the terminals, all you will probably end up doing is trapping moisture, and causing more harm than good. Seems like a pretty simple design face value, but to perfect this, and actually print a superior solution would be more of a challenge.
    That said, Cardo's design isn't exactly inspiring in that regard either. But then again, their planned obsolescence is approx 3 years, so the contacts should outlive the battery. Perhaps the best route is to simply use a contact cleaner and protectant from time to time.
  12. bmwroadsterca
    Jan 3, 2007
    1,186
    No guarantees. I will look into it.
    I previously printed this charging stand for our Packtalks.
    scottydawg and Phil8dirt like this.
  13. Phil8dirt
    Aug 6, 2018
    135
    VIctoria, MN, USA
  14. Grinnin
    Grinnin Forever N00b Supporter
    Dec 10, 2005
    8,199
    Maine, USA
    The Cardo PTB unit itself doesn't have seal there. Riding in the rain with the unit attached might be no better than with a cover. The difference might be that riders will remove the PTB to charge so let the contacts dry out occasionally where they might leave the cover on longer.
    This is my strategy. I'm pretty sure the contacts are plated to resist corrosion. May not be a 10-year solution, but that's OK by me. Even if I rode with the PTB more often, I'd still take it off often enough to see the condition of the contacts.
  15. rider1150gsadv
    Oct 6, 2003
    10,883
    Ft Likkertail , USA
    A little dab of dielectric grease will go a long way to keep the contacts free from corrosion as well as keeping the connection to the baseplate working just fine..YMMV
  16. Grinnin
    Dec 10, 2005
    8,199
    Maine, USA
    Can "Hey Cardo, speed dial" select any of the 4 numbers in the speed dial list?
    Everything I've seen looks like it doesn't accept a keyword to choose any but the favorite. No selecting another phone in the list of 4 by name or number.
    I'm just hoping I've missed an explanation that's somewhere else in the documentation.
    I'm specifically asking about the speed dial feature, not "OK Google". I usually have data turned off which disables "OK Google".
    I usually ride with the phone in an inside pocket, so to change favorites I'd have to pull over, stop, remove gloves, fiddle with zips, change favorite, etc, etc.
    Thanks.
  17. V-Tom
    V-Tom Long timer
    Aug 26, 2006
    1,716
    Port Perry, Ontario, Canada
    Not answering your questio. But I've found " okay google" and "call John smith" (or any other name in my contacts) works well.
    ..Tom
  18. bigjohnsd
    bigjohnsd '14 BMW R1200 GS Adv Supporter
    Jun 1, 2014
    991
    Spearfish, SD
    You have to use the Phone App to choose any one of the 4 speed-dial numbers, only the Favorite can be dialed by Cardo Voice Command. I've had success asking Google to dial by voice but it does require data on.
    Grinnin likes this.
  19. V-Tom
    V-Tom Long timer
    Aug 26, 2006
    1,716
    Over the last fww days I left my antenna up on my ptb and nor only did I not get any cut-outs but I was picking up radio stations from a much greater distance.
    I thought the antenna is only for communicating but it appears it does much more.
    ..Tom
    cblais19 likes this.
  20. cblais19
    cblais19 Long timer
    Nov 3, 2017
    6,087
    NoVA
    Oh yeah, likewise - I got much less cutouts once I did that.
