Carolina Craigslist Crap!
Discussion in 'Southeast, The Lair of the Dragon - The Blue Ridge' started by GI_JO_NATHAN, Mar 14, 2011.
  1. ben2go
    ben2go I am Ben! Hear me snore!
    Jun 23, 2011
    6,854
    Upstate SC USA
    :lol3
  2. schnabba
    schnabba Long timer
    Nov 6, 2008
    4,649
    Wake Forest, NC
    Don't be hatin on my old bike!
    I bought that bike back in 2008 (?) from the second owner (I Think).... front fork seals were shot, fluid looked like coffee grounds. replaced the fluid, the seals, installed racetech springs (not progressive, flat rate)... and some whatever cartridge emulators (that part was a waste, the springs were the best upgrade).
    I had to replace the plastic fuel disconnects with metal replacements (there is a company that sells them - check tiger triple)... new fuel lines (just because)... the fuel regulator was a bit iffy, but I left it as is... runs a bit rich at startup, but so what? it's vacuum operated. That's a first generation fuel injection, but a second generation ECM. 1999/2000 885i motors had that.
    replaced the head gasket since the coolant was weeping when it would hit 28 degrees or colder. did a valve adjustment at that time. new coolant and new coolant cap. Rerouted and replaced the coolant overflow stuff (elbows were plastic and the old hoses were rotted).... replaced the clutch cable with a 1050 unit, different routing, easier pull... also the clutch basket lever - 10mm longer on the 955/1050 motors, direct fit. replaced every vacuum line just because I was there.
    the seat is a bill mayer saddle. Rider AND pillion. I did that. (was when I sold it, looks to be the same, but it's easy to check) I see that the reflective tape job is still there ;) The center stand is a touratech/SW motech (forget which one exactly)... the OEM unit would bend and fail. That one is better.
    I went through that bike when I bought it - was 28-30K back then. cleaned and regreased all the swingarm and suspension crap. Annoying tapered pin/axle for the swingarm pivot... f#$*^! tripumph)... new chain and sprockets, new EBC pads, bleed the brakes, and so on... (since 45K dunno though!)
    had to replace some of the rear wiring - mice had chewed up a bit of if from the owner in hillsboro... so it was a winter project. also replaced some of the turn signals and so on at the time since the sockets were somewhat rusted on a few. And the brake light.
    had a spare low mileage RSU and swingarm for a while... that will be annoying.... I am not sure the RSU is rebuildable, and there is not an aftermarket for it. So I had a few spares in the garage... one wears out, swap in a low mileage one.
    decent bike. Best version of that model was the late 2006 955i models where they were using the 1050 engine cases .... although, that 885i motor used a real alternator with built in rectifier. Tall, can't be lowered, zero rear suspension available. OEM cases are actually halfway decent. maintenance is easy. Lots of information at tigertriple forum....
    ordered a spare set of keys from triumph (proper key blanks with logo) and had them cut at a local locksmith... think I had 4 keys total.
    I used as a trade in in 2011 or so to get my tiger 1050 at ray price in raleigh. Around 40K. Good to see it's still riding around!
    NOTE: I haven't verified the VIN to see for sure, but all the mods look to be my old bike ... and there aren't a lot of eclipse blue 2000 models around ;)
    pir8liner, 4PawsHacienda and FishHunt like this.
  3. STBNE
    STBNE el Bendito
    Dec 20, 2008
    10,339
    Southern Comfort
    Wow thats cool Walker..you are quite meticulous as well... How tall is tall?...sounds like 30" inseam would be vertically challenging
  4. schnabba
    schnabba Long timer
    Nov 6, 2008
    4,649
    Wake Forest, NC
    Tippy tippy toes. Can't be lowered. Direct connection to the RSU. Not a linked suspension. Think of a tiger 800xc and even more tippy toe. Comfy seating position on long rides, sucked in traffic when you have to mount/dismount at stops.
    Get the price low enough, worst thing is you'll need the top end rebuilt at around 100K (valve guides mostly)... and an underdamped rear suspension that will be well worn by then. Be a fun toy for a number of years though!
    Sent from my iPad using Tapatalk
  5. bbanker
    bbanker Been here awhile
    Feb 24, 2011
    236
    Beautiful NC
  6. ben2go
    Jun 23, 2011
    6,854
    Upstate SC USA
  7. MaverickNC
    MaverickNC Gnarly Dude
    Jun 15, 2007
    336
    NC
  8. bbanker
    Feb 24, 2011
    236
    Beautiful NC
    No deal :(
    ben2go likes this.
  9. bbanker
    Feb 24, 2011
    236
    Beautiful NC
    Much better than stock. I'm #250 and have it set up pretty stiff. The rear shock blew at about 20,000 mi and the shock has been trouble free since. Also the progressive front springs really decreased the front end dive under braking. Especially with the 320 rotor up front.
  10. bbanker
    Feb 24, 2011
    236
    Beautiful NC
    That being said I might have gone with a Cogent Dynamics setup if I did it again. Mostly because I met Rick at Willville a few years back and he seemed like a stellar dude.
    Cuttle, kalonji and RidingDonkeys like this.
  11. RidingDonkeys
    RidingDonkeys Purveyor of Awesome
    Oct 23, 2009
    12,753
    Paso Robles, CA
    Rick is good people, and he knows suspensions better than anyone I've ever met. There is a big difference between engineering and practical application. Rick understands the difference between the two, and seems to be able to dial in exactly what a rider needs. That is what I like about him.
    greasyfatman, STBNE, kalonji and 2 others like this.
  12. MaverickNC
    Jun 15, 2007
    336
    NC
    Good to know, thanks!
  13. Pathfinders
    Pathfinders Been here awhile
    Oct 31, 2016
    408
    Upstate SC
  14. ben2go
    Jun 23, 2011
    6,854
    Upstate SC USA
    I looked at that Concours at Powersports of Greenville. Seems like a decent bike.
  15. Draechon
    Draechon Long timer
    Oct 7, 2008
    1,697
    Charleston, SC
    https://cosprings.craigslist.org/mcy/d/titled-2002-dr650-frame-2006/6279859723.html
    Titled 2002 DR650 Frame / 2006 GSXR motor - $1000
    small project: motor and components are mounted nicely in frame.
    Needs routing of return and vent fuel lines into tank, swing arm spacers fit. Flash Tune ECU, 4 into 1 exhaust with FMF forest approved spark arrester.
    This is a wicked hybrid that needs the right person to finish it up and ride this 120+ HP street legal trail bike.
  16. Ridge
    Ridge Outlier Extraordinaire
    Jul 25, 2006
    7,027
    cackalacky
    That one deserves the name "Widowmaker" more than any other...
  17. truck6driver
    truck6driver Proud Navy dad!
    Sep 23, 2007
    8,485
    Hope Mills, N.C.
    I see a project that needs to be un-done. Way more out of wack that just fuel lines. :nod
    But hey if you going to throw money and time at something why not a DR. :lol3
    ben2go likes this.
  18. fallguy
    fallguy Adventurer
    Oct 24, 2011
    47
    Chucktown
  19. SidewinderX
    SidewinderX Hey, watch this!
    Nov 3, 2009
    1,934
    NW North Carolina
    If that was closer, I would buy it. Just for the heck of it!
  20. kalonji
    kalonji nihilism or nothing
    Sep 16, 2009
    3,135
    Witness Protection
    ben2go likes this.
