Carpenter Talk
Discussion in 'The Garage' started by disconnected, Jan 22, 2016.
  1. GutsyGibbon
    GutsyGibbon Adventurer
    Mar 25, 2014
    48
    San Diego
    I was able to complete my tool shed this weekend. My biggest challenge was to place the shed close to the wall, but not attach to the wall. We have lots of rats that nest in our palm tree, so I wanted to seal the back of the shed. I built the complete back wall with the siding and then continued to install the rest of the shed.
    The other challenge were the doors. I made a few noob errors with the hinge placement, trims, and panel gaps. I was not able to install trims on the doors, which makes it look rather bland. Also, I think I picked a latch and a door handle that are way too small. Other than that, the shed is very much functional. I am looking forward to build a mobile workbench and stick it in this shed.
  2. Gillmartin
    Gillmartin Desultory Dilettante Supporter
    Aug 3, 2001
    1,656
    Oregon City, OR
    The slab is pretty standard pole barn construction; 4" of 3000psi concrete. Is that not adequate? And if not, I assume I need to go down 24" with the footer?
    Steel beams might be worth looking into, thanks.
  3. HardWorkingDog
    HardWorkingDog Super Ordinary
    Aug 20, 2009
    3,576
    Walnut Crick, Cal.
    Update--I wound up buying a few Fein carbide metal cutting blades and used a multimaster tool. Worked well enough, 1 blade would last through 10 screws = 1 blade per panel. Definitely better than the bi-metal blades. No flames or burnt wood :lol3 like I got once using a bi-metal blade. Really appreciate everyone who posted with ideas.
    I will say that Andersen's quality control has gone down the toilet...one panel was supplied without any of the supporting parts and pieces needed for install, the other had supporting parts & pieces, but for a different model panel. :baldy Took 3 phone calls and 1 superb customer support person (after getting a useless one) to get it straightened out. Oh yeah, and a week's delay, and $60 additional cost to get the right parts. I haven't decided whether to fight them over that, as it will cost me well over $60 in time just to fight with them.
    ArielNut likes this.
  4. HardWorkingDog
    Aug 20, 2009
    3,576
    Walnut Crick, Cal.
    Most likely not. The only way to tell is to do the engineering work needed--figure the load you want to support, determine the bearing capacity needed, and compare that to what you have. There's really no shortcut to doing the math.
    MrBob likes this.
  5. TheOtherBart
    TheOtherBart Long timer
    Jan 16, 2006
    3,449
    DeKalb County, Illinois
    If the math doesn't work out in your favor another alternative would be to place something like steel plates between your posts and the concrete. If the plates are thick enough to distribute the load a 12"x12" plate would reduce the pressure on the concrete by a factor of 4 compared to the 6"x6" post itself.
    silsen likes this.
  6. Camarodude
    Camarodude Been here awhile
    Sep 13, 2013
    637
    Oregon
    Drawer Slides question??? - 24" drawer slides, full extension.
    How do you get the last (third) screw at the back of the drawer?
    Is taking the drawer off, once it is all installed, to get those back screws, the only way?
  7. GutsyGibbon
    Mar 25, 2014
    48
    San Diego
    Can you use a 90 degree impact ready right angle attachment? Amazon link
  8. MrBob
    MrBob In the Pines. Supporter
    Oct 27, 2005
    19,039
    Boulder CO and Tallahassee, FL
    I almost made it through a season without getting stung by a wasp. Didn’t even see the little bastard before he nailed me.
  9. Camarodude
    Sep 13, 2013
    637
    Oregon
    i have the room. just cant seem to get the the three pieces of the slide to line up to hit that last hole. thought i may doing something wrong.
  10. lkraus
    lkraus Long timer
    Dec 15, 2012
    1,195
    Central Ohio
    Which manufacturer and model? They are not all the same.
    Nearly all have an easy way to remove the entire drawer with it's portion of the slide, leaving easy access to all of the drawer screws. Pull the drawer all the way out, and look for a lever at the end of the first sliding section that serves as the drawer stop. On this Accuride, it is the wedge shaped piece.
    The Accuride instructions linked above actually call for separating the drawer and cabinet sections before installing either. Once the levers have been released the drawer can be pulled out of the cabinet. Sometimes the levers move up, sometimes they move in different directions on opposite sides. I've seen some slides that have a plastic stop that have to be pried out instead. The moving sections are left in the cabinet, but access to those screws is just a matter of moving the slides back and forth until they are uncovered.
    Re-installing the drawer is just a matter of lining up the lever type slides and closing the drawer completely. The plastic pry-out types usually need to be inserted with the slides partially pulled out for access.
    thebigman, GregDavidL and GutsyGibbon like this.
  11. GregDavidL
    GregDavidL Been here awhile
    Feb 27, 2017
    508
    That brings back memories of the cabinet shop and having to program the CNC router to drill the holes in the parts.
    Ugh...
  12. Camarodude
    Sep 13, 2013
    637
    Oregon
    They are some no name, i got off ebay.
    It looks like the only way is to separate the slide parts, to get to that last screw.
    Wow, installing separately to drawer, and cabinet, does not sound like fun.
    I installed as a whole unit to the cabinet.
    Thanks for the feedback!
  13. filmfan
    filmfan Long timer
    Sep 13, 2011
    2,946
    Live Free or Die
    The answer to drawer slide questions is Blum
    They are pricey though.
  14. TheOtherBart
    Jan 16, 2006
    3,449
    I haven't done it nearly as much as others here, but in my experience it's way easier installing the two halves of the slide separately.
  15. GregDavidL
    Feb 27, 2017
    508
    The drawer guide parts are fastened separately.
    To position the drawer guide parts that go on the drawer box, we used a shop-made jig.
    If the cabinets were face frame construction, the other drawer guide parts were attached to a "cradle", again using a shop-made positioning jig. (The vast majority of our cabinets were face-frame.)
    Euro-style (frameless) cabinets had the guide mounting holes drilled by the CNC router in the side panels.
    For both styles of cabinetry construction, we had jigs for mounting the drawer fronts to the boxes.
    It was not unusual for us to have employees that had great difficulties using a tape measure, so for us it was all about using jigs to speed up production and to eliminate the dumb-ass factor.
    Camarodude and CA_Strom like this.
  16. jar944
    jar944 Long timer
    Aug 2, 2010
    1,309
    Warrenton
    Install bare slide in cabinet, then separate halves, then install remaining half on drawer,
    Thats the easy way.. as a entire unit as you have discovered is a huge pita
  17. Camarodude
    Sep 13, 2013
    637
    Oregon
    Ya, i like that idea. Could set the drawer in place, mark, separate and install.
    Thanks.
  18. GregDavidL
    Feb 27, 2017
    508
    Like the Accuride example posted above by @lkraus, the manufacturer will supply spec sheets, both for the guides and clearances for the boxes.
    How elaborate or invested in purchased or shop-made jigs and fixtures you want to be kind of depends on how many drawers you have to deal with.
    Figuring out the set up for the first one is the hard part. The rest are easy.
    Camarodude likes this.
  19. Renaissanceman
    Renaissanceman DON'T PANIC! Supporter
    Feb 24, 2007
    684
    heart of the valley, OR
    Haha... Ain't that the truth! First one takes a half hour - the next one takes two minutes!
    I almost always make a full scale drawing on a piece of 1/4"mdf to get my slides located.
    Lay out the slides off of the centerlines.
    Hold the case member back 4mm from the face of the cabinet and flush the drawer box member with the back of the drawer front. Easy
    Accuride, Haffele or eBay... they'll all have the same hole pattern.
  20. MrBob
    Oct 27, 2005
    19,039
    This is bad dog Gordon. I got called back to his house after he trashed the plastic protectors the homeowners put up and scratched the door again.
    wee-twin and Yinzer Moto like this.
