1. eNewsletter Sign Up
cell phone durability VS, GPS
Discussion in 'GPS 101 - Which GPS For Me' started by Kribensis, Jan 7, 2015.
  1. Albie
    Albie Kool Aid poisoner
    Mar 31, 2004
    15,662
    NWA
    Hell, I've never broken one IN a crash. :lol3
    #21
  2. Kribensis
    Kribensis Adventurer
    Jun 20, 2014
    16
    Came back to fallow up again on this posting. Got real busy with work. So I read through from the beginning. And just wanted to say thanks for all your postings.
    #22
  3. bush pilot
    bush pilot Long timer
    Jun 23, 2006
    2,526
    Thailand
    Yep my 276C failed me too, leaked around the front screen cover.
    Dried it and it works again, but it don't get used much any longer.
    The Samsung Note3 is the do all go to implement of navigation.
    #23
  4. Kribensis
    Jun 20, 2014
    16
    That's funny you mentioned the Note3. Im debating on the S5 Active or the Note3. I read about the S5 having a clear screen in direct sunlight. And I read the S5 had a feature to use it with gloves on. But that Note3 has that larger screen and handy note taking features.
    I had to reply when I saw your note3 post. You really like it. Do ya?
    #24
  5. abhibeckert
    abhibeckert Long timer
    Feb 15, 2010
    2,032
    Cairns, Australia
    I would go with the S5, it goes into "boost mode" in full sunlight, bringing the brightness to about 30% brighter than the Note 3.
    Just make sure you have brightness set to auto and whatever mount is attaching it to the bike does not cover the ambient light sensor (that's one of the dots at the top of the phone).
    #25
  6. bush pilot
    Jun 23, 2006
    2,526
    Thailand
    Yep it's pretty good for most everything. If out on the road using it a lot I carry an extra battery pack device to keep the note charged up.
    Having the stylus option to write an navigate the screen is pretty handy.
    #26
  7. NortwestRider
    NortwestRider TRIPOD ADVENTURER !!
    May 25, 2008
    5,138
    3.7 miles North of Hell...SEATTLE....
    I bought this case from Amazon for $15,2 piece alum that bolts together with a rubber gasket and it has gorilla glass.It has fallen out of my semi,dropped in mud and left out in the rain NO PROBLEMS !!.The only problem is that it weighs as much as the phone and it's huge.
    #27
  8. abhibeckert
    Feb 15, 2010
    2,032
    Cairns, Australia
    I find it very hard to believe you're getting actual gorilla glass at that price. The stuff is very expensive.
    #28
  9. ohgood
    Sep 21, 2010
    9,761
    alabama
    i wonder if there is enough room in there to use the lightening connector plugged into the phone ?
    i'm assuming the back is aluminum or heavy plastic, and could be drilled for a ram mount too ?
    amazing what you can get for a few dollars on amazon. wow
    #29
  10. NortwestRider
    May 25, 2008
    5,138
    The whole thing is aluminum,the description said Corning Gorilla Glass !!.
    Live life,be yourself !!!!.
    #30
  11. Mala Suerte
    Mala Suerte Been here awhile
    Nov 25, 2011
    444
    Fruita, CO
    I have the Note 4 and the screen is amazing. It also has the feature to use it with gloves.
    #31
  12. worwig
    worwig Long timer
    Nov 30, 2009
    1,951
    Hog Mountain
    Have you used it in direct sunlight yet? It has the feature where it 'boosts' the screen brightness in direct sunlight. It is REALLY bright. The only thing with that is that some maps become washed out they are so bright.
    I'm really liking the device though.
    #32
  13. sharkmotorcycle
    sharkmotorcycle Been here awhile
    Nov 12, 2014
    204
    Brooklyn
    #33
  14. NortwestRider
    May 25, 2008
    5,138
    You could drill it for a RAM mount and I believe it would work great !!.However it is not quick OR easy to remove the phone from the case ( 6 LITTLE Allen screws) so you would be walking around with a giant case/phone with a RAM ball sticking out of it .
    #34
  15. Mala Suerte
    Nov 25, 2011
    444
    Fruita, CO
    I have, the colors are washed out some, but it's very see-able. Just not as vibrant.
    #35
  16. abhibeckert
    Feb 15, 2010
    2,032
    Cairns, Australia
    I've been told you need to make sure the screen brightness is in "auto" mode, and that your case/mount does not cover the ambient light sensor.
    The colours are washed out because the Galaxy S4 auto-brightness feature activates an extra bright mode that cannot be triggered manually. Basically it sacrifices colour accuracy (washed out colours) to increase the brightness.
    Thanks to that feature, the S4 is probably the only AMOLED screen that works well in direct sunlight.
    #36
  17. worwig
    worwig Long timer
    Nov 30, 2009
    1,951
    Hog Mountain
    You mean the Note 4.
    And I used an S3 and S4 before the Note 4. I used those in direct sunlight for many tens of thousands of miles. They were only a problem when there was glare. Adjust the RAM mount, glare gone, no issue.
    And since I PREFER the saturated colors on AMOLED displays, it works well for me.
    #37
