Centerstand, getting it up
Discussion in 'GS Boxers' started by Meritlane, Oct 14, 2018.
  1. Meritlane
    Meritlane Been here awhile
    Jul 8, 2012
    676
    LA,CA
    no problem without boxes but is there an easy hack ie placement of a strap to get a gsw on its centerstand with touratech boxes attached?
  2. adam71
    adam71 Been here awhile Supporter
    Oct 23, 2010
    211
    San Leandro, CA
    I grab this spot (on the kickstand side):
  3. Fastman
    Fastman Been here awhile
    Sep 15, 2002
    709
    Webster Groves, MO
    adam71 likes this.
  4. Meritlane
    Jul 8, 2012
    676
    LA,CA
    I have a full altrider rack, so that spot is nor an option.
  5. 150flyer
    150flyer Been here awhile
    Oct 8, 2016
    142
    Ft. Worth
    Install a handle on top of the front right side of the left box.
  6. Chaostrophy
    Chaostrophy Been here awhile
    Oct 24, 2017
    548
    US
    Get fat. I'm 340, and find putting my 2005 R1200GS on the center stand fairly easy. But, frankly, that's still an absurd amount of force! Much prefer my R80RT with the ride off center stand ;-)
    Sent from my Nexus 6P using Tapatalk
    Meritlane and 9Realms like this.
  7. andynj
    andynj Been here awhile
    Jul 9, 2013
    557
    My 2017 is the hardest bike I have owned to get on the center stand but I am #160 and can manage it OK as long as the bags are not full. I found that the trick is to find the find the right angle to pull at, not straight up its up and back and then its much easier. Also technique is key to use your legs not your arms.
    JimVonBaden likes this.
  8. Boondox
    Boondox Travels With Barley
    Aug 4, 2007
    4,336
    Northern Vermont
    I face forward with my legs bent, grab the left grip and the frame near the left passenger peg, then lift with my legs while leaning slightly back. Grunt Factor Two when the bags are full, but empty it goes right up.
    #8
  9. Bill-66
    Bill-66 The End of the Republic is upon us... Supporter
    Sep 13, 2009
    9,853
    The Northwet..
    Just put a finger or two in frame right in front of panniers...
    They're easy to get up..I can do mine with flip flops on..
    #9
    ydarg, RoundTrip and x32792 like this.
  10. FireSpaceLigers
    FireSpaceLigers Been here awhile
    Aug 26, 2018
    376
    Cleveland
    I have 1150, but I grab near the rear footpeg, is this not an option for your bike?
    Key is momentum and not strength. The correct body mechanics will come in time. Its 80-90% slamming your full body weight onto the center stand foot lever at the correct time. You might try rocking it back and forth very slightly with your foot on the stand lever (body weight on, body weight off), then slamming your full body weight onto the center stand foot lever during the exact moment the bike rocks into the favorable direction while pulling up and back very slightly.
    #10
    Meritlane likes this.
  11. usgser
    usgser Long timer
    Nov 6, 2005
    3,580
    Westside WA
    Don't know about your year or with your boxes. On an 05 R1200GS w/Jesse hard boxes I had a folding lift handle that bolted to the sub frame. Made it easier for my skinny old arse.
    Handle came from Wunderlich(sp?).
    #11
    K12Pilot likes this.
  12. Chaostrophy
    Oct 24, 2017
    548
    US
    I have one as well, but I find grabbing the diagonal part of the Jesse bag mount to be more convenient. It's a little bit higher.
    #12
  13. JimVonBaden
    Feb 11, 2005
    95,488
    Alexandria, VA
    That is how I did it. Now I grab the space between the mount on the rear foot peg.
    #13
    Boxerbreath likes this.
  14. WesF
    WesF Been here awhile
    Jul 10, 2018
    470
    KC
    For my Tiger l made a piece of wood that you either push it backwards or forwards depending on the incline you're on & as it raises the back wheel then the centerstand angle becomes less acute making it easier to lift, l keep it in my pannier/side box & it weighs nothing & takes up very little space.
    #14
    x32792 likes this.
  15. Bill-66
    Sep 13, 2009
    9,853
    The Northwet..
  16. Meritlane
    Jul 8, 2012
    676
    LA,CA
    I'm thinking a web strap around the sub frame instead of a handle to help pick up the sleeping beast as well. anyone try that? curious if you found something the correct length or made one that would be just long enough to use the efficiency of a wrist hang instead of using hand strength.
    Grunt level will always be huge when the boxes are loaded.
    #16
  17. pistole
    pistole Long timer
    Jan 11, 2013
    2,620
    earth
    with panniers and topbox , yes , it can be hard.
    #17
  18. Bikerboy108
    Bikerboy108 Pat from Jersey
    Sep 22, 2004
    5,596
    Jersey "Land of the Lane Closure"
    18 is easy compared to the 05 GS
    #18
    Bill-66 likes this.
  19. the78outlaw
    the78outlaw Adventurer
    Jun 24, 2018
    44
    PNW
    These. Little bit of extra weight helps for sure. However, being new to the ownership pool, I can absolutely attest to technique more than brute force for sure. For those few times I don't time it right, it's definitely more difficult to try and muscle the bike onto the stand, than using the center stand and my body weight to leverage it up.
    My .02 YMMV
    #19
  20. Botch
    Botch Been here awhile
    Mar 17, 2013
    800
    Ogden, Utard
    The problem I had for quite awhile was, I didn't have both feet of the center-stand firmly on the ground before lifting/pulling. Its kind of scary tipping Pig up that far, where it feels like you could tip her over the opposite direction. You can have a friend stand on the other side of the bike and try it a few times, until you get the "feel".
    The panniers have never interfered with my grabbing the lower frame...
    #20
