Centerstand, getting it up
Discussion in 'GS Boxers' started by Meritlane, Oct 14, 2018.
  1. gsapilot
    gsapilot Been here awhile
    Aug 15, 2010
    229
    calif sur
    If you have a bike with ESA, I found it helps to set it at max preload. I use a Park n Move dolly, which adds an extra 3/8" to the equation, and it's a bit of a challenge without raising the suspension.
    #21
    Boxerbreath and Jbrjbr21 like this.
  2. MX2ADV
    MX2ADV MX2ADV
    Mar 14, 2007
    178
    Southern MD
    +1 on technique over brute force. 06 1200GSA here but I've also owned various other boxers and F800GSA, I don't so much lift the bike onto the centerstand as rock or rotate it backwards onto the centerstand. I'm 5'11 200lbs. I find that weight in the panniers makes little difference for me with ease of putting the bike on the stand. On the left side of the bike I grab the pannier mount with my right hand and hold the left grip with my left hand. I deploy the stand with my right foot by putting all of my weight on the centerstand arm (on my right foot) and gently rocking the bike backward. Works like a charm but you have to commit.
    #22
    LAFS likes this.
  3. KKORO
    KKORO Been here awhile
    Oct 13, 2014
    393
    Northern Michigan
    I just put the front tire on the upside of any hill. There's almost always a slant somewhere.
    KKORO
    #23
  4. JimVonBaden
    Feb 11, 2005
    90,968
    Alexandria, VA
    The 05 was an off centered pig. They fixed it in late 06.
    #24
  5. Jbrjbr21
    Jbrjbr21 Been here awhile
    May 17, 2017
    622
    Marion Il
    I will roll bike backwards and then step on stand and it goes up pretty easy.
    #25
  6. rboett
    rboett posser noob 205
    Nov 5, 2002
    2,429
    nwa
    This
    #26
  7. Dan-M
    Dan-M Long timer Supporter
    Aug 21, 2007
    3,283
    US 550 & I-25
    What he said. ESA or not, increase preload just enough to give you a little more ground clearance. Makes all the difference.
    #27
  8. Boxa
    Boxa 2 Smoking Barrels
    Jul 22, 2014
    679
    The Bush
    I just fitted some new shocks to my 05 GS, the rear one is 12mm (1/2 inch ) longer. Made lifting onto the center stand maybe 50% easier.
    Dave
    #28
  9. vanha
    vanha Finnspacko
    Nov 25, 2013
    150
    Finland
    If it's too hard to get on the centerstand just stick with the sidestand..?
    #29
  10. BywayMan
    BywayMan Been here awhile
    Mar 1, 2018
    521
    USA
    Video
    #30
  11. MrVvrroomm
    MrVvrroomm Been here awhile
    Aug 16, 2006
    958
    Burnsville, MN USA
    Seriously, it's not rocket science. I made this a couple of years ago after painfully reading a thread just like this one.
    It's technique, not brute strength.
    #31
  12. BywayMan
    Mar 1, 2018
    521
    USA
    I posted it because it contradicts other videos that show the right-side passenger handle being pulled up or back, among other flaws.
    #32
  13. Boxerbreath
    Boxerbreath 2017.5 GS Black Storm
    Feb 7, 2018
    3,775
    Lost Angels County
    This helps. Max will raise the bike so less distance to get it up...
    I have the TT racks and have to grab the passenger peg bracket to raise the bike with the bags in.
    Note that pulling it is part of the technique. BMW recommends putting weight on the center stand while pulling...
    #33
  14. kneeslider
    kneeslider Insufficient privileges!
    Jul 28, 2004
    2,320
    Southeastern Xenophobia
    I have discovered as I get older (80) it has been more difficult to "get it up!"
    #34
    Hogges likes this.
  15. Hogges
    Hogges Been here awhile
    Apr 7, 2018
    282
    Burlington, VT
    Newb question: the bike is in neutral during all this?
    #35
  16. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    5,944
    Zer0-Zer0-Zer0-Zer0
    It shouldn't matter as rear wheel gets lifted in the process of center stand being deployed... If in gear, you can squeeze the clutch...
    #36
  17. ChrisViperM
    ChrisViperM n00b
    Feb 19, 2018
    1
    Cape Town
    #37
    Boxerbreath likes this.
  18. huck629
    huck629 Been here awhile
    Feb 3, 2019
    115
    Ohio
    The 1250GS is my first bike with a center stand and I've practiced enough that getting it up on the center stand is really no big deal but I still have problems getting down off the stand. I'm always just a little wobbly and it feels like the bike is really close to falling over.
    #38
  19. DMack_762
    DMack_762 Been here awhile
    Jul 31, 2018
    204
    Camden, SC
    I pull into the parking space, wherever it may be. I place my bike in neutral. I cover the front brake with my right hand, with my left heel, I push down on the center stand. I stand up on the center stand, whilst pulling back on the bars. It takes one or two "rocks" with the front brake keeping the bike from moving forward, but it pops right up. No issues at all. 2019 GSA, and I am 6'3" / 250 with a 34" inseam. Tall setting on the stock seat. :)
    I never have to dismount my bike to put it on the center stand.
    #39
  20. ADKGsa
    ADKGsa Been here awhile
    Jun 20, 2019
    118
    NY
    I found that while I am standing on the center stand foot it goes up much easier if I shift my weight toward the rear of the bike instead of straight down.
    #40
