Chain grinding top chain guide
Discussion in 'Ridiculous streetbikes with 6 CPUs and too much HP' started by jstyles, Jun 16, 2018.
  1. jstyles
    jstyles Adventurer
    May 6, 2018
    58
    Arkansas
    I have noticed a squeak for about the last tank of gas. I figured it was just the chain in the chain guide. I looked at it today and saw that the chain is off center in the guide. It doesn't look like it's adjustable and I think its only been like this for about 200 miles. That's the last time I cleaned and lubed the chain. What do I need to do or check? 20180616_200409.jpg 20180616_200420.jpg
  2. Lettikka
    Lettikka Been here awhile
    Oct 18, 2016
    380
    Loosen the guide and tap it over. My chain looks like yours all the time but I only have squeeking when I haven't lubed the chain in a while. The guide is designed to wear so it might be okay in another few tanks when it wears in.
    Bluesilver and KMC1 like this.
  3. earlmi
    earlmi Adventurer
    Mar 25, 2017
    37
    Check your rear wheel is in alignment with the two chain adjusters.
  4. Zuber
    Zuber Zoob
    Sep 28, 2004
    4,437
    Main Street, Oregon
    Put some lube on that.
  5. sizzlingbadger
    sizzlingbadger Been here awhile
    Jan 28, 2013
    155
    Wairarapa, New Zealand
    Looks very dry to me.
  6. Lewilewi
    Lewilewi Ride it like you stole it......
    Oct 22, 2017
    814
    N.W.Kent.Uk
    Lightly Lubed every ride
  7. DirtJack
    DirtJack Adventurer
    Aug 12, 2007
    3,163
    San Antonio, Texas
    Better to run the chain tension a bit on the loose side rather than the tight side.
    kokos79, rick danger and KMC1 like this.
  8. Lewilewi
    Oct 22, 2017
    814
    N.W.Kent.Uk
    I found the swing arm marking to be well out, I use alignment tool now...
    #8
    Barekat likes this.
  9. j_b78
    j_b78 Adventurer
    Feb 8, 2018
    70
    Sussex, UK
    What tool do you use? How do you get on with the chain guard, or do you have to remove it to use the tool?
    #9
  10. Lewilewi
    Oct 22, 2017
    814
    N.W.Kent.Uk
    Laser is OK, bit fiddly, my pal got one, when over his place I use it..
    If not the rod tool with guard off
    #10
    Barekat and j_b78 like this.
  11. DirtJack
    DirtJack Adventurer
    Aug 12, 2007
    3,163
    San Antonio, Texas
    #11
    Wodger63 likes this.
  12. Lewilewi
    Oct 22, 2017
    814
    N.W.Kent.Uk
    #12
  13. TheBritAbroad
    TheBritAbroad Just ride.
    May 11, 2016
    515
    Portugal, Corfu & London.
    #13
    Barekat likes this.
  14. j_b78
    j_b78 Adventurer
    Feb 8, 2018
    70
    Sussex, UK
    cheers all, alignment doodad ordered :)
    #14
    TheBritAbroad likes this.
  15. JoeyZ
    JoeyZ "I'de Like To Take That Ride Again" Might as Well
    Sep 28, 2013
    318
    Eastern LI N.Y.
    The chain slider needs to be replaced. The slider has a center strip that allows the center rollers of the chain to ride on the slider. Check the manual. The slider has a U in for siting the chain rivit. When the rivit is not visible the slider needs to be replaced. I got around 5000 mi out of my first one.
    #15
  16. jstyles
    jstyles Adventurer
    May 6, 2018
    58
    Arkansas
    I think when I posted threat i had around 1000 miles... I'm not changing it that frequently, needed or not...
    But I changed types of chain lube and it has not squeaked since.
    #16
  17. slacker83
    slacker83 Been here awhile
    Feb 2, 2011
    199
    Peoria IL
    I'm glad you posted this because I noticed mine was the same way. I've never heard the squeak, but the rubbing on the chain fo sho.
    #17
  18. JasonK94Z
    JasonK94Z Crash Tester
    Oct 9, 2010
    340
    Denver CO
    #18
  19. gsuks
    gsuks Long timer
    Oct 13, 2014
    1,078
    wilnis de ronde venen nederland
    My dealer(mechanic) told me that when it gets down to a certain point it hardly wears out
    So there is no need to replace.
    Mine wasn't replaced in the 75000km I had the bike.
    Verstuurd vanaf mijn SM-G935F met Tapatalk
    #19
  20. Doktor
    Doktor Been here awhile
    Nov 15, 2007
    208
    Austin, TX
    That is one dry assed chain.
    #20
