Chain grinding top chain guide
Discussion in 'Ridiculous streetbikes with 6 CPUs and too much HP' started by jstyles, Jun 16, 2018.
  1. Kevin Graehl
    Kevin Graehl Adventurer
    Nov 11, 2008
    61
    Why is everyone complaining about a dry chain. It's lubbed on the other side of the orings
    #21
    Boatman likes this.
  2. Doktor
    Doktor Been here awhile
    Nov 15, 2007
    200
    Austin, TX
    Because you still have metal to metal contact between the chain and the sprockets. Have you ever seen any instance where metal to metal contact with ZERO lubrication on a moving part is OK?
    #22
  3. Andy_L
    Andy_L Been here awhile
    Jan 5, 2018
    197
    UK
    Train wheels on railway tracks?
    #23
  4. Doktor
    Nov 15, 2007
    200
    Austin, TX
    So so example, while they do run unlubricated, they require frequent resurfacing due to excessive wear.
    #24
  5. jstyles
    jstyles Adventurer
    May 6, 2018
    53
    Arkansas
    I have since switched lubes since this thread started. I was using chain wax, and believe it or not, that dry looking chain was well lubed, greasy to the touch just not over lubed. I typically clean and lube about every 300-500 miles so It always looks close to that.
    The new lube is an on-off road style wetter than the wax. I went a little above and beyond and I still got the funny black ring around the chain. It's not plastic though like I had first thought. It's just greasy gunk I have no Idea why its in such a clean line though.
    #25
  6. Deviant
    Deviant aka KTM 1290SAdvR
    Aug 14, 2013
    3,740
    My first chain guide lasted ~10,000 miles. My second one has lasted less than 1,000 and is worn worse than the first at time of replacement. Not sure if I got a "bad one" or what the issue is. Riding, lube, and maintenance have been consistent.
    #26
  7. Bluesilver
    Bluesilver Long timer
    Aug 6, 2013
    1,457
    South Africa
    Assume you not riding more aggressivee terrain now?
    If not and same roads/conditions then sounds like KTM have changed suppliers as they have done before.
    I will check tomorrow myside as I have a new spare guide lieing around.
    #27
  8. Deviant
    Aug 14, 2013
    3,740
    Same riding, same terrain, same lube, same frequency (more or less), same chain tension. I noticed it was low a few hundred miles ago and dismissed it but saw it had started to "clean" the top of the chain now. Not impressed, going to push the dealer to replace it and blame KTM.
    I'm guessing it's a softer compound or something.
    #28
  9. Pipeman
    Pipeman Been here awhile
    Jul 5, 2010
    126
    North Central Pa.
    Use a pair of digital calipers
    #29
  10. Bluesilver
    Aug 6, 2013
    1,457
    South Africa
    They feel the same,but funny enough no stamp on the guide so it could be from any supplier.
    #30
    Deviant likes this.
  11. JoeyZ
    JoeyZ "I'de Like To Take That Ride Again" Might as Well
    Sep 28, 2013
    318
    Eastern LI N.Y.
    OK! Good enough.I would choose to not have my swing arm cut in half by the chain, as that "shiny section" on the chain links makes it's way to the rivets. But that's just me. 30 bucks, 30 minutes no mo squeaking. Piece of mind: Priceless.
    #31
  12. gsuks
    gsuks Long timer
    Oct 13, 2014
    1,064
    wilnis de ronde venen nederland
    Once it got down to a certain point it didn't wear anymore
    My mechanic said it didn't need replacing, when I asked.
    And he's been doing road ktms
    Since the first adventure models,
    If he had said replace it would have been. I asked every 25000 when the chain was replaced
    Verstuurd vanaf mijn SM-G935F met Tapatalk
    P.s
    My chain on my 2015 didn't squeak nor does it on my 2018
    #32
    JoeyZ likes this.
