Chainsaw left sitting
Discussion in 'The Garage' started by double_entendre, May 14, 2019.
  1. double_entendre
    double_entendre It's nothing personal; just your existence.
    Aug 11, 2008
    12,281
    Huntington Beach, CA
    Yes, yes. Just sticking it on a shelf after the last use was dumb. I know, I know.
    But I need to use it again (first time in years), so I need to get it running again. It’s a Husqvarna 435.
    What should I expect to have to do?
  2. vsteel
    vsteel Adventurer
    May 11, 2018
    71
    Idaho
    Are you sure it won't run? I leave mine wet all of the time and never have issues. Shake the saw to make sure the oil is still mixed in the tank well, pull it, fire it up and pull curls with the chain all day long.
    If the gas does smell, pour it out and put in fresh and see if it will run like that. Worst comes to worst you will have to put a carb kit in it.
  3. Wentwest
    Wentwest How's that work?
    Feb 19, 2007
    2,987
    Northern California
    Might as well take out the spark plug and clean it, and maybe put a couple of drops of oil in the cylinder. That's about all.
  4. kenstone
    kenstone worn out
    Mar 3, 2013
    1,865
    Boysee
    Get some Starting Fluid, put some fresh gas mix in it, pull it over a few times to get some gas/oil into it.
    Then spray that "start you bastard" fluid into the air intake/filter, wait 30 seconds, then start pulling the pull cord...
    Starting Fluid ignites via compression, works for me but not so sure about 2 smokes, worth a try though :dunno
    :lol3
    double_entendre likes this.
  5. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    9,385
    Anchorage, formerly Spenard (hub of the universe)
    I would pour out the old gas and put in fresh mix. clean the air filter and the plug, pour a thimble full of fuel in the hole and try it. it should go.... at least for a spurt. usually they will run on high even if it won't idle. after it warms up, if it won't idle, the low speed jets are gummed. I dump some Seafoam in the gas and pull it through, prime it, stumble-run it --- whatever it takes to get the fresh fuel in the carb & then let it sit. if it doesn't get better after a couple cycles doing that, then pull the carb. I am always reluctant to crack straight into the carb because they often have little springs, balls, and stuff that wants to jump out. and then theres gaskets, etc... once you tear it apart you're stuck to it
  6. JT105
    JT105 Let's Ride!
    Jun 24, 2014
    443
    SE Michigan
    +1 on fresh fuel and Seafoam.
    Get it running, warm it up and let the new gas and Seafoam do their work. Like was said before, it may not idle at first. Seafoam May take a bit to dissolve the gum out of the idle jet.
    JT
    Gillus and Beezer like this.
  7. foxtrapper
    foxtrapper Long timer
    Sep 6, 2011
    4,072
    Good chance the flaps in the carburetor fuel pump will be stuck and sticky. Simply pull the screw(s), and wipe the plastic flappers down with solvent.
    Gas in the tank, probably worthwhile to simply dump it into the recycled oil jug. It's kinda hard to nose test modern gasolines for combustibility.
    cal08 likes this.
  8. Amphib
    Amphib A mind is like a parachute....
    Sep 19, 2018
    2,506
    Wnc
    I have the same saw. It always starts. I only run ethanol free in all my small engines, but great advice above.
    #8
  9. cagiva549
    cagiva549 whats a cagiva
    Oct 10, 2004
    6,531
    Cypress Tx
    My husky saw is in the scrap pile now , tygon gas lines desintigrated in the gas tank after a year , I fixed that with real gas hose then the carb quit carbing so I quit jacking with it . No more than I need a saw these days I use a homelite electric now .
    #9
    Wentwest likes this.
  10. telejojo
    telejojo Long timer
    Feb 2, 2010
    1,262
    Huntsville Ala. foothills of the Smokey's
    Go to Amazon get a carb. for about 15 bucks and fire it up.
    #10
    vector6, Jonnybow and kenstone like this.
  11. cagiva549
    Oct 10, 2004
    6,531
    Cypress Tx
    My old homelite saw ran over 30 years with nothing more than bows and chains , and that was several cords of firewood every year . I’m done shopping around if I ever want another gas saw it will be another homelite or ill reseal my old one and bring it back to life .
    #11
  12. ericm
    ericm Long timer
    Sep 12, 2002
    1,901
    Santa Cruz Mountains, California
    Chainsaw carbs have a lot of tiny and delicate parts compared to motorcycle carbs. You can disassemble, clean and put them back together but it requires more care and higher power reading glasses than moto carbs.
    #12
  13. Pathfinders
    Pathfinders Long timer
    Oct 31, 2016
    1,250
    Upstate SC
    Replacement carb is under $20.00 on Amazon, carb rebuild kit is $10.00. Buy a carb and rebuild the old for next time.
    #13
  14. double_entendre
    Aug 11, 2008
    12,281
    Next time?
    What are you implying? :lol3
    #14
    mitchapalooza likes this.
  15. Cal
    Cal Long timer
    Mar 11, 2008
    3,483
    Calgary
    My husky 61 was bought in 1977 when I took a log building course. Still have it and have used it hard some years and others not. This model 61 Husky 2 stroke always starts or maybe just the ones that are built like a tank from the 70's some times in the spring it will take 10 or 12 pulls!
    #15
  16. ozmoses
    ozmoses Contrary
    Jul 3, 2009
    37,730
    USA??
    Pull the cord.
    #16
    ohgood and MrVvrroomm like this.
  17. double_entendre
    Aug 11, 2008
    12,281
    I mean to get it running. Unlike @Jim Moore, I'm not posting for help in JM. :lol3
    #17
    ozmoses likes this.
  18. ozmoses
    ozmoses Contrary
    Jul 3, 2009
    37,730
    USA??
    I've let my 459 sit for months at a time,fires right up. :dunno
    Actually, few months ago I pulled out an old Poulan I put away wet 10 years or more ago.
    Took more than a few pulls, but it did do some limbing that day.
    I was shocked!
    Honestly, 5 pulls at full choke,go to 1/2 choke and pull again.
    I've rarely seen a Husky fail to fire.
    My Husqvarna backpack blower gets used and abused and stored improperly but keeps on keepin' on.
    #18
    Amphib and double_entendre like this.
  19. ohgood
    Sep 21, 2010
    9,694
    alabama
    Push primer bulb, pull the cord?
    Seriously my lawn stuff sits outside all winter and starts up second pull in the spring. I'm using really high dollar Lucas 2t and hard to find 87 octane in them though.
    #19
    MrVvrroomm and shinyribs like this.
  20. Jim Moore
    Jim Moore Souped-Up Weasel
    Dec 24, 2001
    33,875
    Jax, FL
    I happen to be a Husqvarna chainsaw repairman. But I'm not gonna help if you're gonna act like that.
    #20
    ozmoses, double_entendre and Amphib like this.
