Champion Escort on an R1150RT build
Discussion in 'Hacks' started by Ridn3, Mar 10, 2015.
  1. Ridn3
    Ridn3 Lopsidd
    Feb 18, 2015
    483
    S.W. Virginia
    Yes you did and yes it has. I think that most people under estimated the thickness of the angle that we used. It is approx 1/4" thick. Next time that you are at a farm supply or Lowes, try lifting a 3 ft section.
    btw, you were not the only one who responded negatively. There were plenty, both on and off list.
    #41
  2. davebig
    davebig Another Angry Hun !
    Jan 19, 2004
    11,529
    Minnesota
    Ok you guys oddly enough an old timer out here in the midwest uses allot of angle in places and 1/4" angle isn't going to twist easily. But allot of mounting durability depends on how one proceeds flying the chair allot and dropping it suddenly and powering thru lefts tests mounting rigidity.
    #42
  3. draperg1
    draperg1 PapaBear Supporter
    Mar 31, 2013
    736
    Martinsville, VA
    UPDATE
    As many know ridn3 had unfortunate mishap with this rig a couple of years ago. Totaled the bike, bent bike frame, bent sub frame ....... the angle iron was unscathed. Before we cut this to length ridn3 and myself propped it on two 4x4 pieces and stood in middle (we weigh 250lbs each - 500lbs) it did not bounce. It was connected to sidecar frame with two grade eight 3/4" bolts to the original strut locations. We were able to relocate upper struts to a better triangulated position. For practical explanation the sidecar frame had a sub frame. :D That's my story and I'm sticking with it!
    #43
    GotDammitDave, Bobmws, brstar and 2 others like this.
