Changing the front sprocket and chain breakers
Discussion in 'Dakar champion (950/990)' started by Mouse, Jan 23, 2006.
  1. Killer Whale KTM
    Killer Whale KTM Life is the adventure!
    Oct 24, 2003
    737
    The Mountains of Jasper GA
    Hey Guys,
    I hate to drag out this post..........but......I understand the need to cut (or whatever) the chain to replace it, however why do you need to ,in order to replace the sprocket ??? I loosened my rear axle and slid forward. This created enough slack to easily change the front sprocket. It was a long time ago ,but I think it only took an hour or so including cleaning and other maintenance. Has anyone else done it this way ??
    Hope this helps
    Killer Whale KTM
    #21
  2. KTMlvr
    KTMlvr Adventurer
    Jan 9, 2006
    25
    Motion Pro have good tools and at reasonable prices, considering if you had to go to your dealer each time you wanted work on your final drive etc.. I know its not a daily occurence but tools are like art, we collect, and this one will happen to last a lifetime
    http://www.motionpro.com/Docs/chaintools.html
    Cheers
    #22
  3. AntWare
    AntWare Lost In Translation
    Oct 10, 2002
    16,483
    I think that was the original question mate. Without cutting chain you're left with having to remove the clutch slave cylinder to create enough room slide the chain and sprocket off.
    I'm going from memory, but I don't think there's enough room to partially slide the chain and sprocket off enough to clear the metal guard, lift the chain off of the sprocket, then completely remove the sprocket, before you get to the slave cylinder.
    #23
  4. Stephen
    Stephen Long timer Supporter
    Feb 19, 2002
    3,476
    Austin, Texas, USA
    Jeez, guys... whatever happened to undoing things until it was all apart and bolting it back up until there were no more bits on the floor? :huh
    I remember yanking the clutch cyl -- just as Ant said. It just come off, no drama, no problem. I remember loosening the rear axle and adjusters to give me some room, and was gonna have to adjust anyway. I think I remember some guides and crap in there that got in the way, so I dealt with it, somehow. Chain and sprkt come off together, go on together -- boy, those are some nice close tolerances on those splines, btw.
    BigMac, I know replacing chain and sprockets as a set is The Right Thing To Do, but I'm not sure how much difference it makes in the Real World. I'm well within spec at 10k miles, and pretty sure it won't make it to 20k. That's ok. So, whether you are gonna act like a beemer geek or think Big Mac is a Big Pain in the ass is up to you. But he's still the guy to buy a used bike from. :wink:
    #24
  5. ktmMike
    ktmMike Long timer
    Aug 10, 2005
    1,303
    Alabam
    The easy way is to forget about the 16T sprocket. A 16/42 (2.625) is close enough to the same ratio as a 17/45 (2.647). Leave 17T in front. Change rear to 45T. On many bikes you would have to lengthen the chain, BUT NOT ON THE KTM 950. Just flip the adjustment blocks over. Mike
    #25
  6. Stephen
    Feb 19, 2002
    3,476
    Austin, Texas, USA
    Not only easy, likely a better solution.
    I think the reason I didn't go this route back when was unavailability of the 45. Or lack of brains. Or something.
    I'm considering going 16/45 when it's time for a new chain. With the 16/42, my 950 idles in first at 7 mph.
    #26
  7. eug_rider
    eug_rider Adventurer
    Sep 4, 2005
    12
    Loosened chain by removing the rear wheel, pulled the slave and worked the 17t CS off. As stated there is no bleeding (clutch or otherwise) involved in this method. The bike had about 600 miles when I changed the CS, no apparent wear issues at 4k.
    #27
  8. BLUE(UK)
    BLUE(UK) Long timer
    Dec 2, 2004
    3,442
    There is some fannying about i tells ya all!!:D
    I aint done this but my 450exc is the same sort of thing and i just whipped off the bolts and parts and reassembled as was required!!
    #28
  9. Mouse
    Mouse I'm only smelly
    Nov 1, 2005
    16,154
    Byron Bay
    Thanks all, its winter/summer depending upon your tilt and everyone seems to be quiet so a good technical debate seems better than comparing a GS to the beast. (and to those asking go ride both and you'll have your own answer...)
    Not that I bothered to check but I figured a 16T is cheaper than a 45T so that made my choice easier given I just wanted to check out the difference....
    And yes, Bigmac sounds like the man to buy a second hand bike from :evil , its reaasuring to know someone listens to the manufacturers.
    I'm of the opinion that anyone who got the 17T off without breaking the chain or removing the slave must be a magician and we should all bow to them and their ability to achieve the impossible. :eek1 I'm always interested in learning new skills so if anyone who has done it can replicate it for me in person I will bestow many gifts upon them... :wink:
    #29
  10. Stephen
    Feb 19, 2002
    3,476
    Austin, Texas, USA
    #30
  11. YOGOI
    YOGOI Prick
    Jun 21, 2004
    3,821
    Logan, Utah
    :rofl Funny you brought that up. I just swaped the scorps. for some nobs. You would have laughed your ass off watch'n me wrassle that rear tire all day.:lol3
    #31
  12. RAGrote
    RAGrote Fishin w PICO
    Nov 1, 2004
    1,034
    Colorado fire road wandering....
    Pulled the slave. Swish, bam, boom..... no bleeding, no leaking.
    I used a little plastic "c" clamp to hold the cylinder in the slave while I swapped sprocket.
    #32
  13. ram1000
    ram1000 Long timer
    Feb 14, 2004
    1,883
    Tricities Washington
    OK I have a 45 tooth sprocket coming. Hope my links are the same umber as yours. I like the idea of not adding links. Bike has 2100 miles so nothing else will be changed.
    #33
  14. dirtyboy
    dirtyboy Wheel spinner
    Sep 12, 2003
    529
    Bend, OR
    Another consideration...
    Changing from a 17 to 16 will move your wheel back, thus increasing wheelbase.
    The 42 to 45 will move your wheel forward, decreasing the wheelbase.
    ...assuming no change in chain length...
    Pick your poison. :evil
    #34
  15. ram1000
    ram1000 Long timer
    Feb 14, 2004
    1,883
    That is precisely my motivation. I could have bought a front sprocket for half, but would like to shorten my wheel base. These things are way too long in my opinion. They will wheelie easier with less wheel base and I will never travel whoops hard enough to need additional swing arm travel afforded by longer wheel base. 61 1/2 to 62 inches is not needed for my purposes. When I used to race mototcross bikes were 57-58 inch wheel base. I want quick steering for offroad use and don't feel that I'm giving anything up losing an inch or so. I ride a 650 dualsport for single track riding and may go with a 450 next time.
    #35
  16. Hawk
    Hawk Pretentious Fukwit!!
    Apr 22, 2005
    28,757
    Paradise
    Is the nut that holds the counter sproket on LEFT hand thread by any chance?
    I am a pretty strong guy, and while using a 14 inch cresent wrench I was unable to budge this nut. :huh I am going to buy a 30mm socket tomorrow and try again.
    #36
  17. Mouse
    Nov 1, 2005
    16,154
    Byron Bay
    not to my recollection but then i don't remember a 30mm socket either!
    #37
  18. Hawk
    Apr 22, 2005
    28,757
    Paradise
    Gonna try a socket tomorrow. That SOB ain't coming off with a wrench and again I am not a little guy that is why I asked if it was left hand thread.
    #38
  19. Mouse
    Nov 1, 2005
    16,154
    Byron Bay
    what I meant was I don't recollect it being 30mm - for some reason I think its 32mm.
    Mine undid easily, rear wheel on the ground, chain still on, bike in gear.
    #39
  20. Hawk
    Apr 22, 2005
    28,757
    Paradise
    Well I used my calipers to determine that it was a 30mm nut so I could buy the socket today. Now you have me questioning my sanity.
    #40
