Cheep Bike Challenge <$1500
Discussion in 'Old's Cool' started by nedodjija, Jul 7, 2009.
  1. NurseBill
    NurseBill Been here awhile
    Aug 20, 2017
    899
    Central PA
    Nice.....
  2. Brother J
    Brother J n00b
    Jun 24, 2013
    7
    Virginia
    I found this 2008 VStar 1100 on FB Marketplace in March of this year for $1,250.00. I turned it into a bobber.
    yokesman, ishmac, waylongway and 7 others like this.
  3. feisty
    feisty Been here awhile
    Mar 12, 2016
    155
    AU
    Awesome stuff. You've turned something that was absolutely hideous into something very appealing. If forgotton how bad that look was till I saw your pic.
    Love your work
  4. TheHeretic
    TheHeretic Been here awhile
    Jun 7, 2005
    442
    RI
    Wow, fantastic job. I have a 2009 Vstar 1100 Classic and it is a nice motorcycle. The engine has a nice sound/cadence to it with aftermarket exhaust.
  5. noman
    noman Long timer
    Jun 4, 2007
    2,787
    the sticks, southern vt
    wow! really nice. shedding even a little weight from the bike is an easy way for a little gain in performance, and your ride looks very cool.
  6. nedc
    nedc Adventurer
    Apr 27, 2010
    69
    Manning, SC
    I'm just happy to see that you kept the fenders and didn't put brown seat/grips and knobby tires on it! Looks good....
  7. Chickenstrip
    Chickenstrip Long timer
    Aug 30, 2008
    1,958
    NYC
    I was skeptical when I saw 'bobber' since I don't really get that style, but your bike looks awesome. Are the wheels OEM and just powder coated, or did you swap 'em out? New rotors?
    CCitis likes this.
  8. Dorzok
    Dorzok Long timer
    Jun 10, 2008
    6,393
    SoCal
    ultimate "YOU SUCK!!" post right there.
  9. Ozarkroadrunner
    Ozarkroadrunner Been here awhile
    Apr 12, 2014
    137
    Georgia and Arkansas
    Bobber turned out very nice. Blue Collar makes some nice kits. I wish I had seen this a few weeks ago. I had an opportunity to get the 650 version for little money. It would have been perfect for a bobber kit.
  10. NurseBill
    Aug 20, 2017
    899
    Central PA
    My Kid dropped his Shadow and put a nice dent in the tank when the turn signal hit it. He is going to fix the turnsignal and keep at it. This winter... color change.
    JagLite likes this.
  11. zap2504
    zap2504 Dave E.
    Feb 15, 2006
    1,483
    Middletown, PA
    Have him look up "paintless dent removal". Get the system with a slide hammer and the different glue-on plastic pucks. He might be able to completely pull the dent.
    TonyKZ1 and NurseBill like this.
  12. Dorzok
    Dorzok Long timer
    Jun 10, 2008
    6,393
    SoCal
    and watch TON of youtube videos
    i liked this one cuz all work was done from the outside, no pushing from the inside, and is on a tight compound curve like what you might find on a motorcycle tank. also look at the light he uses. multiple tubes really shows the imperfections as he gets closer to completion.
    this channel pretty cool cuz he explains step by step and stuff like that and do awesome work. BUT, he does a lot of pushing, working from the back side.
    https://www.youtube.com/channel/UCUyEa2HVxn64Ppd34qCtAvw
    NurseBill likes this.
  13. RedRocket
    RedRocket Yeah! I want Cheesy Poofs
    Feb 28, 2003
    38,969
    SoCal
    Don't waste your time. moto gas tanks are way too thick for that stuff. Nothing but heat and big hammers will help.
  14. Ozarkroadrunner
    Apr 12, 2014
    137
    Have him check the lower triple tree. The fork stop may be bent or broken.
  15. NurseBill
    Aug 20, 2017
    899
    Central PA
    That part is ok. I have a big piece of plate steel I run across the forks to make sure they are still parallel with each other. Wasn't a hard drop. The turn signals are mounted with a rubber clamp that goes around the fork leg so if the bike falls, the turn signal housing goes right into the tank. If they were mounted low, like the 1994 and up VLX's are, it wouldn't have dented the tank.
  16. zap2504
    zap2504 Dave E.
    Feb 15, 2006
    1,483
    Middletown, PA
    Since the tank has no major creases, it should pull out fairly well. Maybe not perfect, but it will not need a ton of Bondo and he can do it himself.
  17. Dorzok
    Dorzok Long timer
    Jun 10, 2008
    6,393
    SoCal
    tell'm ditch those one piece back breaking bars with the latter years' separate risers and any 1" bar of his choosing too.
  18. Dorzok
    Dorzok Long timer
    Jun 10, 2008
    6,393
    SoCal
    here was MY choosing for a while.
  19. Sir Denis Eton-Hogg
    Sir Denis Eton-Hogg Tap into America
    Apr 6, 2009
    1,289
    Loveland Colorado
    $750, runs nice
    JagLite, Dorzok, TheHeretic and 8 others like this.
  20. sh0rtlife
    sh0rtlife Long timer
    Sep 14, 2011
    1,994
    20 mins west of portland oregon
    i was a week or so away from picking a pair of those up...one of those and a street version?...and month after i woulda picked em up for my buddy in reno he passed.....if id gotten em picked up id own em now
