Chethro's WV & Nearby Travels
Discussion in 'Ride Reports - Day Trippin'' started by chethro, Sep 24, 2020.
  1. chethro
    chethro Confidence is High
    May 11, 2012
    1,616
    NW WV
    Me too.
    In the old days, the rock bottoms were like interstates for horse and wagons. :D Much better than the red clay that would stick to everything. I guess wagons could even handle the deeper water to a point which would cover these roads half the year. Today tho, these roads keep cars away, so most of the homes up them are no longer in constant use. In places, folks still raise hay in the fields near the old homesteads thus keeping the roads somewhat open. You have to figure in between every hill is a stream and there are typically roads on each side of the hill, so there are a lot of crossings and such. Makes it nice for me...:ricky
    klaviator, B10Dave, JRowland and 3 others like this.
  2. chethro
    May 11, 2012
    1,616
    NW WV
    I started out on an hour ride to test a performance upgrade on the TT. It was overcast and 75. :ricky The next thing I noticed it had been 2 hours, then 3 and I made it home after 4. :lol3
    I installed a Mistral Vtwinboost dongle on the bike. It looks to be a an extended temperature sensor that you can run right to the air intake. It is supposed to help with decel poping and give a slight power boost when used with an aftermarket pipe. All I have is the cat delete Y pipe, but I did notice quite a bit less decel poping. I really tested it on some hard curvy roads that really had you getting on and off the throttle. I plan to install the GTM SAS block off kit too and then get a Mistral carbon fiber exhaust next Spring. I really like the sound of the Mistral verses the other brands. It doesn't sound as good as a V7 with Agostini's, but it's the best sound of all the TT pipes I have heard.
    No funky alarm codes were thrown, so I think the TT is ready for the Grappa. A little fuel and a quick clean and she will be done. Time to put the extra bags on...
    Imagine a series of S-turns cut out of the rock that look like this one on Rt119...:tb
    How can you stop riding when you are going thru places called Paradise, Romance and Harmony?
    I did wire tie a small clip board to the tank bag. It holds some cut up maps to help guide me when the GPS goes nuts.
  3. Higher Logic
    Higher Logic Delightfully Altered
    May 1, 2011
    10,555
    Weed Town USA
    What is this map thing you speak of ?
    Isnt that something off of a V 7 Ambassador ? :lol3
    chethro likes this.
  4. chethro
    May 11, 2012
    1,616
    NW WV
    I had my map out last Sunday when I encountered a closed road. Seems to happen more and more here. Who knows where the GPS would have routed me. :loco Old Tech saves the day...again.
    In an unrelated note, I ordered the Mistral slip on last night. Turns out they are putting catalytic convertors in all new pipes. AF1 had one stainless left in stock without them, so I bought it even tho I really wanted the carbon fiber one. Oh well, this is the only pipe which I like the sound. The others seem to dirt bikish. :roflReminds me of my old Yamaha 60.
    Bill will hear me now when I pull up to the Moto Grappa!
  5. Iron Cross Junction
    Iron Cross Junction Long timer
    Oct 6, 2013
    2,015
    Just above Pott's Camp along Braddock's route, Va.
    Good. Had Mistrals on my late, oft-lamented, now-lost Ballabio. Grand -- nearly inimitable, actually -- basso profondo sound.
    Apropos GPS, I posted these pix on ADV elsewhere recently, but gives you an idea of what happens when one -- with I being the "one" in this case -- forgets to leaven technology with common sense.
    I was leading a group from Atlanta to Buena Vista, the then-site of the Virginia Moto Guzzi rally.
    I was in denial as the GPS took us down a paved, then gravel, then dirt, then into a guy's yard!
    The GPS insisted that there was a bridge there and the road continued on to the other side of the significant creek. Doh. Obviously not.
    The owner was livid at first, but quickly went into super nice when he realized I was just stupid, not mean.
    He said he thought that the bridge washed out 30+ years ago, tho he had only lived there about 20!
    His wife never put down the shotgun. :hair
    As you might guess, drinks were on me that night.
    "No, Sir. It doesn't look like a road. Yes, Sir, I was stupid.” :fpalm
    See you next week. In the meantime, we are in N.C. visiting family, back tomorrow. Then, I'll ride (the EV) to Erie on Sunday, back Wednesday. Looking forward to your visit. The V7 III is waiting patiently on the lift for your electrical skills.
    I'll have that filthy rear cleaned before you put on your surgical gown. :D
    Bill
  6. chethro
    May 11, 2012
    1,616
    NW WV
    Easy, I'll have my wire cutters on me and will give'er the old WV smoke test when finished... :devildog :eek7 :eekers
    If there is no fire, we're good. :D A little electrical tape and the rest will buff...I'm sure.
  7. chethro
    May 11, 2012
    1,616
    NW WV
    With the goodies I'm bringin we should be able to fix the cosmetic issues too...
    Should be looking fine in short order.
  8. Iron Cross Junction
    Oct 6, 2013
    2,015
    :fpalm
    :pep
    B10Dave and chethro like this.
  9. chethro
    May 11, 2012
    1,616
    NW WV
    After mounting the Sys30 bag on top the others bags, I found it a bit of a Streeetch to mount the bike. Using parts left over from my winter fab work for the V7, I made up a C-Bow mount for the side. All that was needed was a small piece of 2x2 angle and the already fabbed V7 bracket. Drill a couple holes, C-clamp them together to get the right position and a few welds sealed the deal. :lol3 It came out straight enough so...I could have added a strut to the passenger peg, but with the straps from the bags ran up to the top bags it seems more than sturdy. There is not much weight in the side bag anyway just clothes.
    On the back of the bag, an aluminum plate is bolted on along with the female C-Bow bracket. Loosen 3 straps and the bag pulls off with a key. The center bag has 2 easy access bolts and two straps. In less than 5 minutes, it all comes off.
    The Sys30 would easily strap to the top of the others...
    It ain't pretty, but it wasn't much work to get this welded up and it lines up perfect. I may make something a little prettier this winter. Then again....:augie
    You can see the straps here.
    klaviator, popscycle, B10Dave and 4 others like this.
  10. chethro
    May 11, 2012
    1,616
    NW WV
    You gotta love Sunday Fedex deliveries of motorcycle goodies. :nod
    Mistral pipe is on and even tho it's not black the stainless ain't bad. :D With he DB killer in, it isn't much louder than the stock pipe just more of a deep rumble. I will be trying it out with the DB killers removed for sure.
    Tank is now full and I'm ready to rumble East if the dang weather gives me a window. Not sure now if I will leave Thursday and stop at Snowshoe on the way out or maybe come by there on the way back...:hmmmmmI may just leave early Friday and go straight to the Grappa.
    klaviator, DCrider, JRowland and 3 others like this.
  11. Iron Cross Junction
    Oct 6, 2013
    2,015
    Chethro ventured out of W.V. into his thread's "nearby travels" category.
    Today, chethro conducted a cross-border operation to the Moto Grappa at the top of the Old Dominion in Cross Junction.
    Must have been a frightening ride as he immediately hosed out his pants! :D
    More pix soon, but riding local roads awaits dry gear!
    Bill
  12. Iron Cross Junction
    Oct 6, 2013
    2,015
    Chethro, Day 2.
    It was a tough one for Chethro today in the Moto Grappa. :D
    That said, he earned it.
    First, we went for a ride on some fine local roads. I had a hard time keeping his taillights in sight. :p3rry
    On the way back, he hunted up unobtanium fasteners for the Moto Grappa.
    Then, he installed a Fuzeblock on my V7 III. I questioned drilling into the battery to mount it, but he assured me this was the Mandello school solution. :hmmmmm
    Bill
    MCGMB, SoloRider73, B10Dave and 4 others like this.
  13. chethro
    May 11, 2012
    1,616
    NW WV
    It is Guzzifestivus! A nice 4 day trip aboard the TT. First leg was home to Snowshoe WV. I left with the roads mostly dry and the remnants of Fred coming behind me the entire way. Fred did catch up to me for a few sprinkles, but it was mostly just damp roads the last few hours before hitting the Morning Glory BnB.
    Day 1: Spencer, Clay, Birch River and Cowen WV...Tail of the Skunk! TT rumblings echo thru the hills. :ricky
    Craigsville -- A little Geno's Pizza, but this allowed Fred to catch up to me. It was worth it. :dukegirl
    Next, up to Rt 150. The Cranberry. Not an overly exciting road, but not boring either. It is all about the views here.
    JRowland, MCGMB, SoloRider73 and 4 others like this.
  14. chethro
    May 11, 2012
    1,616
    NW WV
    Day 1 continued...Then Rt219 to Snowshoe.
    Day 2... I left Snowshoe and went by Cass, Greenbank, Seneca Rocks, Petersburg, Romney to Cross Junction VA. It rained on me for just a short time, but I didn't get very wet. The roads were soaked from overnight rains tho. After an hour or so, the roads dried up enough to have some fun. :D
  15. chethro
    May 11, 2012
    1,616
    NW WV
    Day 2 continued...Seneca Rocks and the light was at the wrong angle all the way up Rt28 towards Petersburg, so most pics were crap. I think this is the prettiest stretch of road in WV...that I have traveled so far. :nod
    Out of Petersburg, I went up Patterson Creek Road...
    Bill, it's an easy road to find turn South at the Fire Station. Don't blink.
    popscycle, JRowland, MCGMB and 6 others like this.
  16. chethro
    May 11, 2012
    1,616
    NW WV
    Day 3 at the Moto Grappa...Bill thinking about what to take for a short ride. :hmmmmm
    He picked the one I like best! What a pair. :D
    We stopped at this Quaker meeting house.
    Back at the Moto Grappa the WV State flag is flying. :thumbup
    The patient needing a fuse block is ready for work and the EV sits patiently. The EV has over 100K miles and you wouldn't know it to look at it or ride it according to Bill.
    Then the lovely Norge. Very nice indeed. :-)
    Thanks for the wonderful weekend Bill and Kathi! :thumb
    B10Dave, popscycle, JRowland and 5 others like this.
  17. okiegtrider
    okiegtrider Long timer
    Mar 12, 2011
    2,918
    Indian Territory
    B10Dave, JRowland, drumdog and 3 others like this.
  18. chethro
    May 11, 2012
    1,616
    NW WV
    Day 4 going home with fine weather and almost no traffic. I only make 3 short rest stops and take all these pics from the saddle. I have to say the TT is extremely comfortable and I had no problem going 5.5 hours in the comfort tall saddle from MG. I could have easily done more is weren't for the back pain I have been suffering thru the last few weeks. No fault of the seat.
    Capon Bridge
    I saw this on the way to Bill's and I just though it looked kinda cool. Reminds me of one that was in my home town years ago.
    I can't remember if this was Rt 90, 48, 72 or 38. I was in the zone all alone. All great roads.
    Tucker County Courthouse Parsons WV
    Lunatic Asylum Weston WV -- You can check out but you can never leave....:robin
    B10Dave, popscycle, JRowland and 6 others like this.
  19. chethro
    May 11, 2012
    1,616
    NW WV
  20. okiegtrider
    Mar 12, 2011
    2,918
    Indian Territory
    If you did, I missed it. Great photo!
    JRowland likes this.
