Chillis rolls out of Vegas
Discussion in 'Ride Reports - Day Trippin'' started by Chillis, Feb 29, 2020.
  1. Chillis
    Chillis Long timer Supporter
    Aug 25, 2005
    19,091
    __________
    I guess anything is possible.
    My money is on the disintegrated woodruff key. Also found shavings on magnetic drain plug. It was completely gone from flywheel and crank.
    About to seal it up!
  2. Chillis
    Aug 25, 2005
    19,091
    __________
    Tool time. My one torx bit I broke is the size needed to swap the sprag from old to new flywheel. Off we go.
    I'm still thinking loctite on the crank taper is a good idea to keep this thing solid. The new woodruff keys are a very snug fit needing hammer taps to seat and position.
  3. Mofrid
    Mofrid Been here awhile Supporter
    Nov 27, 2012
    428
    State of Jefferson
    Ok ... not yet "advertised" ... not great... you know..., weak old host, maybe lots of mosquitoes, limited space, the water is cold, scary big trees, rural roads, no cell, no internet, no phone line, no TV but an outhouse (yeah really) ... yet still hot showers and charging ability. People keep coming back. Whatever... bring Monkeys!
    Hope to post soon. Mo
  4. ZoomerP
    ZoomerP Long timer Supporter
    Apr 16, 2020
    2,987
    American Southwest-ish
    As long as it's cured so it won't act as a lubricant, I guess it can't hurt as long as you can heat it up for removal.
    Chillis and Dirt Road Cowboy like this.
  5. Chillis
    Aug 25, 2005
    19,091
    __________
    That's what they say, it isn't permanent. I'm afraid now after the last go round. I want steady positive lock. I added a thin film. Hondabond needs to set too.
    Going to finish assembly and probably wait until tomorrow to put it in the frame. Saturday to prime and fire.
    The Virginian, y2blade, dp064 and 6 others like this.
  6. Chillis
    Aug 25, 2005
    19,091
    __________
    Mostly done. Cam sprocket install, tighten mounting bolts, exhaust and oil cooler lines.
    Went smooth. Only had to run to the auto parts store twice to replace a broken torx bit that was necessary to transfer the sprag clutch. Grabbed the wrong size on first attempt. :patch
    Was able to salvage the countershaft seal by respringing the inner sealing surface. We'll see if it holds. If not, the guy doing the wheel bearings will pop a new one in.
    I'm going to finish assembly tomorrow and maybe tomorrow night or Saturday morning is enough time for the loctite to set. Not taking chances there. Will check cure time.
  7. simbaboy
    simbaboy Lansing MBS Supporter
    Apr 22, 2012
    6,208
    Lansing, MI
    Nice and easy and slow.
    I wish you immense success in all your endeavors.
    Imu
    B10Dave, pnw, Chillis and 3 others like this.
  8. ZoomerP
    Apr 16, 2020
    2,987
    I like how "tomorrow" was technically achieved in less than two hours. lol
    As many times as you've been to this point, maybe it should be named the Millennium Monkey.
    Woodruff keys are a galactic problem.
  9. Chillis
    Aug 25, 2005
    19,091
    __________
    A classic! Due for a millionth viewing.
    After I'd gotten everything mostly together it is just the three hanger bolts to get the motor back in. Then the connectors are easy enough.
  10. ZoomerP
    Apr 16, 2020
    2,987
    I'd love to have a vehicle make that sound when throwing a DTC. At least I'd get a laugh before it blew up.
    pnw, Dirt Road Cowboy and Chillis like this.
  11. Chillis
    Aug 25, 2005
    19,091
    __________
    Just gives even more respect to the detail and effort of those movies.
    She's done. I'll light it up later this evening maybe.
  12. B10Dave
    B10Dave Long timer
    Jan 11, 2012
    2,594
    Kingsmill Corner Ont.
    Good luck Brian; hope all is well now in Monkeyville.
    simbaboy, ZoomerP, Chillis and 2 others like this.
  13. KICKNBACK
    KICKNBACK Old enough to know better young enough not to care
    Oct 16, 2012
    3,158
    THE 949 Cancer Sucks!!!!!
    Charles Moncky, a Baltimore mechanic, invented the monkey wrench around 1858. Moncky's wrench was named using a purposeful misspelling of his name.
    It’s appropriate that you are using one.
    :hide
  14. Chillis
    Aug 25, 2005
    19,091
    __________
    Used it to torque my flywheel and piston circlips.
    :1drink
  15. KICKNBACK
    Oct 16, 2012
    3,158
    :imaposer
    Dirt Road Cowboy likes this.
  16. motocopter
    motocopter Long timer
    Oct 5, 2012
    3,771
    mid-TN
    A CO2 extinguisher has worked in a pinch in the distant past. Shop stories.... :lol3
    B10Dave, Dirt Road Cowboy and Chillis like this.
  17. lookatdirt
    lookatdirt Long timer
    Jun 1, 2009
    1,912
    The Tri-State area
    Good luck!
  18. Chillis
    Aug 25, 2005
    19,091
    __________
    Couldn't wait. Started a new flash, adjusted fuel base to idle at 12.8:1 AFR, rpm limit 12k, idle 1500 rpm, timing changed to 2 degrees idle and the immediate blocks around it 1 and everything else is 0 timing.
    Warmed it up and later I'll get a run in with auto tune.
    Still need to adjust the AFR table for big bore specs so auto tune knows what to shoot for.
    Edit: much smoother now.
    klaviator, black 8, simbaboy and 3 others like this.
  19. simbaboy
    Apr 22, 2012
    6,208
    Lansing, MI
    P--A--T--I--E--N--C--E, YOUNG MAN.
    IMU
  20. Chillis
    Aug 25, 2005
    19,091
    __________
    Just did the first auto tune run. This thing is so fun. Need to get the map dialed as it is pretty lean.
    Going to do warm ups to auto tune temps and work on the different throttle positions.
    The countershaft seal fix worked. No oil hosing the frame.
    y2blade, klaviator, dp064 and 6 others like this.
