Chillis rolls out of Vegas
Discussion in 'Ride Reports - Day Trippin'' started by Chillis, Feb 29, 2020.
  1. NEPA 450x
    NEPA 450x Still riding after all these years, Supporter
    Dec 26, 2016
    3,243
    Marrs
    A bunch of "Monkeys" :imaposer:fpalm
  2. NEPA 450x
    Dec 26, 2016
    3,243
    Marrs
    Back in the day, i have used ,,,,
    R12,,,,if i was in a hurry,,:fpalm
    Dirt Road Cowboy and Chillis like this.
  3. NEPA 450x
    Dec 26, 2016
    3,243
    Marrs
    Did you roll a magnet over it ?
    Im lat on this tonight,
    F K took me 2 hours to get gooked up to wifi from hotspot,,,
    Motors are easy ,,,:fpalm
  4. Chillis
    Chillis Long timer Supporter
    Aug 25, 2005
    19,091
    __________
    It was magnetic.
    Dude you would love this bike. Weighs nothing and is very quick, only to get much better with tuning and break in.
  5. NEPA 450x
    Dec 26, 2016
    3,243
    Marrs
    if i was skeptical about the Flywheel/key/crank fit i would ,,
    Dykem or majic marker both and TQ it all together and pull flywheel and check fit,
    Or at least TQ it together , drink a pbr and pack nut off FW 3 turns,
    Feel it and reTQ it ,,,
    If it bit/fit good the first time,
    Really i would of took bare crank and fit key and FW to it so it mattes well , also easy to remove FW,
    And see depth and fit,,,
    and cure it if it was not,
    So when you "finalize " it it's a home run,,,,
    Dam 1 in of snow outside,,,65 deg to 28 ,,,,
    Makes me hurt from all the fun i had in life ,Chillis,,,,
  6. NEPA 450x
    Dec 26, 2016
    3,243
    Marrs
    I bet Chillis,
    Ive been around the block a couple times riding/driving ,,,were my hair was standing up for hours,,,lol
    but theres not much in my life i've missed,,,:hmmmmm:fpalm
    Thats why im on Marrs,,, they dont do this stuff on earth,,,:fpalm
  7. Chillis
    Aug 25, 2005
    19,091
    __________
    Snow? Where are those may flowers!?
    Flywheel has a solid fit now. Had to play with the key a bit to get the flywheel to fit flush. The bike feels a lot different with it fitting properly.
    Should have did that marker test though just to verify. I'm confident the issue will not arise again. Cleaned the tapers of each piece twice to be sure nothing would cause a slip.
  8. Chillis
    Aug 25, 2005
    19,091
    __________
    No pics or video while doing short runs to break in/tune the engine. I may have to start over with tuning too because timing may be too far advanced.
    Too much unclarity on tuning the engine with the ARacer.
    That said, I hit 80 mph in 4th gear trying to fill out the auto tuning map. This thing will fly once set up!
    y2blade, black 8, klaviator and 4 others like this.
  9. ZoomerP
    ZoomerP Long timer Supporter
    Apr 16, 2020
    2,987
    American Southwest-ish
    Do you plan to do any dyno work, or just figure it out on your own?
    Chillis and Dirt Road Cowboy like this.
  10. Chillis
    Aug 25, 2005
    19,091
    __________
    Just setting the parameters for the ecu and then auto tune it until it runs properly.
  11. KICKNBACK
    KICKNBACK Old enough to know better young enough not to care
    Oct 16, 2012
    3,158
    THE 949 Cancer Sucks!!!!!
    80 mph on that bike is crazy, people don’t see you on a normal size bike going slower
  12. Chillis
    Aug 25, 2005
    19,091
    __________
    The plight of a motorcyclist! It is so much fun! This is definitely my favorite bike now. Hope it holds up!
  13. simbaboy
    simbaboy Lansing MBS Supporter
    Apr 22, 2012
    6,208
    Lansing, MI
    Brian, what is the weight of a stock Monkey?
    Imu
    Dirt Road Cowboy likes this.
  14. Chillis
    Aug 25, 2005
    19,091
    __________
    Like 231 lbs wet.
    Lighter exhaust and lithium battery can drop another 10 lbs easy.
  15. Chillis
    Aug 25, 2005
    19,091
    __________
  16. Some Beach
    Some Beach Been here awhile Supporter
    Dec 17, 2015
    323
    Phoenix, AZ
    Thanks for the heads up but I have the stock looking SP TAKEGAWA and like it a lot.
    Chillis likes this.
  17. Chillis
    Aug 25, 2005
    19,091
    __________
    A lot quieter than the other one you had on?
  18. MVI
    MVI MVI Moto Supporter
    Oct 7, 2018
    4,176
    NRH, TEXAS
    No Vibes and tires well balance? How are the brakes ?
    Be Safe my Friend, Hope you are on a road with a spotter and no other traffic about....
  19. Chillis
    Aug 25, 2005
    19,091
    __________
    Everything is good. As the auto tune adjusts the vibrations are less.
  20. lookatdirt
    lookatdirt Long timer
    Jun 1, 2009
    1,912
    The Tri-State area
    Go fast. Take chances!
    Looks amazing!
