Cide1’s Ural + Hack Thread (was Ural 650 Reliability)
Discussion in 'Hacks' started by cide1, Oct 5, 2017.
  1. cide1
    cide1 Been here awhile
    Mar 10, 2014
    278
    Fishers, IN
    So I've bought a 1998 Ural 1wd with the 650 motor. It looks pretty original and unmolested. Has about 12k on the odometer. It didn't run when I bought it, but a few electrical tweaks, and a valve adjustment and I got it running (although poorly). As I'm thinking about trying to get this back on the road, the response everywhere else has been "don't plan for it ever to be reliable" which I just don't believe. IMZ made something like 4 million of these over 70 years, and people have been around the world with them. So....my question is: "Say I was willing to put $1000 in making this run more reliably, what should I do?"
    I live on the edge of a city surrounded by two lane country roads, and I have family 30 miles away on these type of roads. I want to be able to do 60 miles round trip at 50 MPH and have a pretty fair shot at getting there and back.
    So far, I've ordered all new cables, new Pekar carbs, new petcock and fuel lines. It has a relatively recent battery. The brakes are non-existant, and will need addressed, and it will need new tires. I believe the ignition, alternator, regulator, wiring harness, etc. are all stock as made in 1998.
  2. eastbloc
    eastbloc comprador bourgeois
    Jun 27, 2003
    1,476
    Brooklyn
    They made them for about 40 years. Before that, they were flatheads.
    I think you’ll be fine with the purpose you have in mind, with regular maintenance. You might eat a crankshaft once in a while but you may not, especially if you don’t abuse the thing and keep it to 50mph I see no reason you should not get many happy kilometers out of a 650.
    cide1 likes this.
  3. Wolfgang55
    Wolfgang55 Long timer
    Dec 24, 2006
    4,109
    Only N flowin river emptying in an ocean
    You sound sincere in your desire to make it work.
    This could be a great hobby which has some fun returns.
    If you're not disappointed easily you'll make a good owner/rider of your 60 yr old design sidecar.
    9Realms and cide1 like this.
  4. cycleman2
    cycleman2 Long timer
    Jan 18, 2010
    1,276
    Alberta, Canada
    Check out he Soviet Steeds site, good info over there about your rig.
    eastbloc likes this.
  5. eastbloc
    Jun 27, 2003
    1,476
    Brooklyn
    I’m currently in the process of replacing my Russian gear tower on my 650 with Herzog gears, and installing a Denso alternator. If you have the 35A alternator on your rig, you’ll want to toss that in the bin — it can lead to premature engine failure. It’s known as a “hand-grenade” for a reason.
    Take some photos and post them here or on Soviet Steeds, we’ll be able to tell you more about what you have.
    Sent from my iPad using Tapatalk
  6. cide1
    Mar 10, 2014
    278
    Fishers, IN
    So what happens to the alternator that gave it this nick name? Is there a good place to source a Denso replacement?
  7. FLYING EYEBALL
    FLYING EYEBALL out of step
    Mar 18, 2008
    11,038
    north of seattle
    I believe hand grenades are known to blow up.
    You're going to find the best Ural info over on soviet steeds.
    good luck
  8. eastbloc
    Jun 27, 2003
    1,476
    Brooklyn
    The hand grenade will seize and take the motor with it, since it doesn’t have a rubber cush drive to disengage the two. It’s also a suspected factor in premature crank failure.
    +1 on Soviet Steeds, see you there.
    #8
  9. Tourbus
    Tourbus Lost but not worried
    Aug 15, 2010
    271
    SW Mo. Escapee from the Tax Nightmare
    Closer to 45 mph road speed might be more realistic. But all bikes have are different and have a sweet spot they like to run in.
    Wear ear plugs, the less you hear, the less you worry.
    Do everything for the 10,000K service.
    Replace any Russian bearings you run across, with SKF or another name brand.
    #9
  10. 9Realms
    9Realms Drawn in by the complex plot
    Jul 23, 2010
    5,043
    Central Mn
    Feel free to put up some images, I would be interested in seeing the progress on it.
    I worked on or "refitted" a bike over 9 months a few years ago, it was a great way to break up an otherwise long cold winter. Very pleasant memories.
    I'm subscribed. :johntm
    #10
  11. cide1
    Mar 10, 2014
    278
    Fishers, IN
    Here are two pictures I have handy... (I know its a Solo, I hope you guys understand that the Hacks forum is the best place on advrider to discuss these). I've got a lead on a matching sidecar to go with it, but given that's its a Solo that needs attention, I may buy the sidecar and install it on my Triumph Thruxton / Bonneville hybrid.
    #11
    9Realms likes this.
  12. cide1
    Mar 10, 2014
    278
    Fishers, IN
    Will a 750 alternator fit the same spot as the 650 generator?
    #12
  13. usgser
    usgser Long timer
    Nov 6, 2005
    3,040
    Westside WA
    You say "I got it running (although poorly". Go back to basics. In order: 1 insure valve lash is in spec. 2. insure ign and timing is in spec. 3. Insure carbs/induction system is in tuned spec. Once you have a known base line to diagnose from you can than rethink fix or bail out. Granted the 650's have weaker cranks that lugging the motor can destry but there are still tons(literally) of Ural 650's still running around and very sweetly. Driven sanely and kept well maintained it's a smooth adequate motor so long as you're not expecting a freeway flier. $1000 budget huh? If you do your own work I'd expect you can your project motor smooth within budget. If you evaluate it's time to punt on your 650 you might consider going a little over budget and springing for a used 750 motor. Only you can determine that based on original issue, budget, time, willingness to do the work. There are times when it's a sound economic plan to do a used motor swap but only once you've got a very firm grip on what your motors issue is. A new to you unkown used motor may be better or worse than your 650. Short of catastrophic failures Im a believer in fix what ya got before dumping money into an unknowm motor. These are pretty simple old tech so no need for an expensive hourly shop guru but ya gotta put in the time/effort. You bought a project...well ya got one. I'm holding out for an older flathead Ural as my next project but wouldn't be afraid of a poorly running stock complete 650 Ural. Spend your time/effort/money intended use/expectations on figuring out you poor running issue before committing to the next grand plan. I vote fix it , ride it, maintain it.
    Best of luck.
    #13
  14. Tarka
    Tarka Strangely strange. Oddly normal.
    May 10, 2007
    2,729
    Across the pond.
    Someone asked if the 750 alternator will fit.
    It's the same,so yes.
    In fact,the very early 750 actually had a hand grenade one anyway.
    The so called hand grenade alternator can shear its shaft and drop the drive gear down the timing gear stack,jam against the casing and burst it.
    I was lucky as it somehow went the other way and ended up almost flat avoiding case damage.
    Also,the rotor windings can lose contact with the sliprings internally.
    I had 3 of these alternators fail.
    I once made up an adapter to mount a small Mitsubishi alternator but for some weird reason the drive gear kept coming loose.
    Instead of spending lots of money on a Nippon Denso alternator I bought an earlier L424 one and a solid state rectifier.
    Been on over five years now with no trouble.
    The original Russian coil is likely to die on you,most likely by failing when it gets hot and causing intermittent and increasingly bad misfiring and back firing.
    It'll trick you into thinking it's crap in the carbs,and while you're draining them or checking jets the coil will cool down.
    The bike will run great until the coil heats up and the problem reappears.
    I solved this by buying a generic universal twin outlet coil and mounting it on a bracket under the tank.....no problems since.
    A bit of mechanical empathy and common sense checkovers with regular servicing should keep a 650 sweet and happy for many years.
    My 650 has been in regular use for over ten years now and I actually prefer it to my 750 for anything other than very long trips.
    #14
    Alexander B likes this.
  15. mtrdrms
    mtrdrms Been here awhile
    Jan 21, 2011
    659
    NW CT
    #15
    cide1 likes this.
  16. cide1
    Mar 10, 2014
    278
    Fishers, IN
    Thanks all for the feedback. I'm thinking a new alternator, electronic ignition and plugs, brakes and tires, new carbs and cables, new petcock and gas lines, and a once through the maintenance / tuneup procedures will give me a solid starting point.
    What I'm quickly coming to realize is that this bike is two projects: 1.) It has lots of deferred maintenance with consumable parts that need replaced, and 2.) An electronic ignition and modern alternator make an older Ural more reliable.
    #16
  17. cide1
    Mar 10, 2014
    278
    Fishers, IN
    I have purchased a hack, picking up in a week or two.
    Sent from my iPhone using Tapatalk Pro
    #17
    Bobmws, High Octane and FR700 like this.
  18. cide1
    Mar 10, 2014
    278
    Fishers, IN
    The front forks were binding up and not springing back up. I figure a rebuild is in order. I was having trouble figuring out what was inside, so I took one apart and grabbed this picture for reference: [​IMG]
    #18
  19. cide1
    Mar 10, 2014
    278
    Fishers, IN
    I've been doing some deeper research on the bike, and I found out it's not a '98, but rather a '95. This makes it one of the first Urals brought into the US officially. It also means that it has the G424 alternator, not the Russian hand grenade. Woohoo! One less thing to worry about.
    #19
  20. SandHog
    SandHog Been here awhile
    Dec 20, 2007
    130
    Where the road goes on forever
    I have rode both the 650 and the 750. The 650 really feels " Russian ". Treat it tenderly and maintain it, and it will be a blast around town and two laners under 55. The G424 will keep the lights on just fine. Enjoy....
    #20
