CJ750 Exhaust on a Ural M67-36?
Discussion in 'Hacks' started by RetiredandRiding, Feb 23, 2018.
  1. RetiredandRiding
    RetiredandRiding Retired to Ride
    May 22, 2015
    1,117
    Da Lat, Vietnam
    Apologies if this was answered previously. I can't find it.
    I have a 1982 M67-36. Will a CJ750 exhaust fit without too much modification? No mods needed would be ideal, though I can do some.
  2. cycleman2
    cycleman2 Long timer
    Jan 18, 2010
    1,273
    Alberta, Canada
    If the outlet & inlet diameters match, you can likely make it work , just by messing with hanging brackets. I've used old HD mufflers on several of my bike projects over the years and an older set off a sportster would work on a 650/750 cc bike. Just make sure both sides flow the same as I don't know if there is a cross over pipe on your 82 rig.
  3. RetiredandRiding
    May 22, 2015
    1,117
    Da Lat, Vietnam
    Thanks. No cross-over. Moving hanging brackets will be easy as the bike is currently COMPLETELY disassembled for soda-blasting and painting.
