1. eNewsletter Sign Up
Cleaning Titanium...
Discussion in 'The Garage' started by MikeO, Jul 16, 2007.
  1. MikeO
    MikeO Long timer Supporter
    Jul 27, 2002
    17,143
    Scarning, Norfolk today...
    I've got a titanium Z-Technik exhaust system on my 1150 Adventure...
    ...which, the more observant of you will have noticed, I have singularly failed to keep clean...
    In my own defence, I bought the system used (from Aurelius) and, having fitted a lowering kit, noticed that the clamp fitted in a different place with this kit in place. The mark left by this is just one of various marks over the length of the silencer.
    It also appears to have pitted - like the original BMW stainless steel silencer.
    So - the question is - how do I clean it? It isn't meant to have a polished finish, but rather a dull machined look. I'm not too concerned about the "Y-piece"...
    ...which is probably just as well... :lol3
    Any ideas?
    Mike :ear
  2. Stook
    Stook Who you callin' a n00b?
    Aug 23, 2006
    94
    Deep Woods, East Texas
    (pictures removed to simplify reply)
    Short answer: It won't be easy.
    Longer answer, good chance you are going to need a highly diluted acid solution followed by a rinse agent that will neutralise the acid (so it stops eating away at the titanium right about the time the dirty surface layer is consumed).
    Hopefully you will get better answers with easier solutions suggested. :)
  3. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    4,884
    Mesa, AZ
    MikeO,
    I'll start with I am a Metallurgist and I work for a Titanium company.
    The yellow stuff is an oxide scale that forms when you get Ti to 1000°F. Acid doesn't remove this, its pretty much inert to everything. We sandblast it off our forgings.
    If you go that route, it may still have some discoloration, but should look OK.
    If you want it to look like new, you have to sandblast and pickel to remove the very hard surface condition called alpha-case. A do-it-yourself acid cleaner won't work, as it isn't strong enough to tear apart the Ti atoms from everything they are bonded with.
    The next step would be to take it to a professional pickling shop that will use a combination of hydrofluoric acid and hydrochloric acid to remove what is left. Just tell them how much you want removed (usually .010" is sufficient). Once the alpha-case is removed, it will have the bright gray surface again.
    Then just don't get it hot again.
    I'd stick with the sandblasted finish.
  4. krampus
    krampus get lost
    Sep 2, 2006
    543
    NorCal
    I'll start with I'm a bonehead weekend wrench...plus, you're reading this on the internet, so you know it must be true. Try Simple Green "Automotive" as a loob + fine steel wool "00" or finer and a bunch of good ol' fashioned elbow grease. Might not be perfect, but it'll prolly turn out nicer than you thought. The only caveat I know is that Ti can be brittle...others more informed than I should chime in.
  5. GSWayne
    GSWayne Old Guy nOOb Supporter
    Mar 29, 2005
    3,848
    Santa Barbara
    Thanks for the professional advice, but I have a one question.
    Do you really mean .010"? Isn't that about a third of the thickness of the muffler material? I haven't measured the thickness of one, but I would think it would be pretty thin.
  6. Poolside
    Poolside Syndicated
    Apr 1, 2003
    11,888
    Silicon Beach, CA
    <BR>
    Did you hear the part about don't get the titanium hot again? He (tbarstow) means that the oxidization process begins again and ends up right where you started.
    Maybe try some 220 grit metal sandpaper once in a while and create a directional brushed finish.
    <BR><BR>
  7. tbarstow
    Jul 9, 2007
    4,884
    Mesa, AZ
    I don't know how thick they are, but I'll check the thickness of the stuff we sell to Akropovic. I'd sand blast it and leave it alone.
    But really, its a GS, its SUPPOSED to be dirty!
  8. MikeO
    Jul 27, 2002
    17,143
    Many thanks for all the replies.
    I started off by spending an hour or so with an old T-shirt and a can of WD-40...
    The silencer came up remarkably well.
    ...and the Y-pipes are as good now as when I bought them.
    The only problem areas are where the clamp fits...
    Aurelius fitted the exhaust in its normal position, I fitted it with a lowering kit. The rubber (butyl?) lined clamp has marked the surface in the two different areas it fitted.
    The marks seem to be scuffs on the surface of the metal where the pipe has moved fractionally and repeatedly over many miles. I don't think there is any way to get rid of them without doing something extreme like wire-brushing or sand/bead blasting the whole can.
    Does anybody have any other ideas?
    Cheers,
    Mike :ear
    #8
  9. Mr Head
    Mr Head Adventure Hippie Supporter
    Sep 21, 2003
    15,056
    San Clemente, CA
    Looks good.
    You know with the bags on the bike you can't see the pipe...
    #9
  10. MikeO
    Jul 27, 2002
    17,143
    Yes - that's the tactic I've been using - but now I want to sell the system...
    Mike :)
    #10
  11. SnowFarmer
    SnowFarmer Adventurer
    May 8, 2007
    12
    Bishop, CA
    I have a lot of Titanium for my motocross bike. S100 works wonders.
    The metallurgist could tell you more about it, I got the idea from Factory Honda (they use Hondabrite) which is re branded S100.
    Mind you this stuff is caustic to aluminum. But we soak bolts in the stuff and they come out looking brand new.
    #11
  12. MikeO
    Jul 27, 2002
    17,143
    As far as I can see from their website, S100 is a cleaner. I'm pretty happy that the system is about as clean as it's going to get - the marks I 'd like to remove are scuffs on the surface of the can...
    Mike :)
    #12
