Clicking but not turning over, lights still bright
Discussion in 'Parallel Universe' started by Mermalady, Sep 15, 2019.
  1. Mermalady
    Mermalady Adventurer
    Feb 28, 2012
    22
    San francisco
    2009 f800gs.
    Having trouble starting.bike had been in storage for a while by PO (just purchased it). Put it on the trickle charger for a day and still having these symptoms. Will start when the trickle charger/jump pack is on. Without..
    Turn the key, everything comes on. Hit the button, only a click and nothing turns over. All the lights, when I turn them in, are still very bright, including the aftermarket auxiliary lights.
    Is this a starter thing or just a bad battery?
  2. SnoDrtRider
    SnoDrtRider I've been lost here before...
    Mar 21, 2006
    6,881
    South Jersey... Close to the Pines
    Put a fresh battery in... You will thank me later.
    morfic and Eatmore Mudd like this.
  3. JRWooden
    JRWooden Homeless motorcycle vagabond ... and ... loving it
    Jul 5, 2008
    6,286
    The great state of confusion
    Since it starts OK with jump-pack my guess ... would be bad (or not fully charged) battery.
    If you have a voltmeter hook that to system voltage and see how low the voltage drops when you hit the starter button...
    If it goes down to less that 10V then it's likely either bad or not fully charged battery.
    lots more details here: https://www.revzilla.com/common-tread/how-to-test-a-motorcycle-battery
    but if the battery is more than a couple years old, and was left to fully discharge with no float charger on it ... I vote with @SnoDrtRider
    morfic likes this.
  4. Mermalady
    Feb 28, 2012
    22
    San francisco
  5. satur9
    satur9 angry black guy
    Mar 7, 2009
    835
    hfil
    Battery. A bad cell may read voltage fine. But craps out when load ( starter ) is applied.
