Cluch noise..
Discussion in 'Dakar champion (950/990)' started by Crazygreek, Nov 8, 2019.
  1. Crazygreek
    Crazygreek Adventurer
    May 28, 2015
    71
    Greece
    Good morning!When then bike is cold I listened noise from cluch cover in neutral,when I push the clutch the noise dissapear.I clean the oil jet before 5000kms.My bike is adventure 990R with 37k kms on klock and is 1st hand.
  2. kelly007
    kelly007 Adventurer
    Oct 9, 2008
    68
    South Africa
    Mine also does that, pretty sure it's normal. With the clutch out i think the booster assembly rattles around
    Boatman and Crazygreek like this.
  3. Crazygreek
    May 28, 2015
    71
    Greece
    thanks Kelly,because I wondering if I can doing something about that
  4. chopper13
    chopper13 Been here awhile
    Dec 3, 2010
    188
    in northwestern ohio
    Jutter spring,I replaced mine with another plate and heavier springs
    Crazygreek likes this.
  5. Boatman
    Boatman Membership has it's privileges ;-) Supporter
    Mar 9, 2005
    14,088
    Mill Spring, NC
    As stated above I'm pretty sure is the clutch booster also.
    But I would pull the cover and make sure your bolts are tight that compress the springs
  6. Crazygreek
    May 28, 2015
    71
    Greece
    thanks a lot boatman, I check it with the first opportunity.
  7. Boatman
    Mar 9, 2005
    14,088
    Mill Spring, NC
    You dont need to drain the oil to check the clutch bolts. Just lean the bike over on the side stand. Remove the brake lever and take the outer clutch cover off. Should only get a small amount of oil dripping out.
  8. zimtim
    zimtim Adventurer
    Aug 15, 2012
    96
    UK
    Mine used to do this.
    Only though when bike was cold, once it was warmed and I had pulled clutch in a few times the noise would disappear.
    I discussed this with another owner and we decided it was just clutch plates sticking until they had a nice warm coating of oil.
    #8
  9. Boatman
    Mar 9, 2005
    14,088
    Mill Spring, NC
    That makes no sense. With the clutch engaged (lever relaxed) the plates are all packed together from the spring pressure. No way you can get rattling plates with clutch engaged.
    #9
    bobnoxious67 and Crazygreek like this.
  10. zimtim
    zimtim Adventurer
    Aug 15, 2012
    96
    UK
    Why would the noise go after the clutch had been engaged a few times.
    I'm not trying to be argumentative just trying to find a more reasonable explanation.
    #10
  11. Boatman
    Mar 9, 2005
    14,088
    Mill Spring, NC
    No problem.
    On a fully cold motor most of the oil has dripped down off the booster. When you start it the booster rattles around a bit and oil then acts as a buffer. Also once the booster ramps start to engage the noise will go away.
    To hear the plates rattle would require them to be completely dry.
    #11
    Crazygreek and zimtim like this.
  12. Peltsi
    Peltsi Been here awhile
    Jul 20, 2015
    127
    Finland
    What is the purpose of the clutch booster? I had never heard about it before KTM. Doesn't other manufacturers use similar design.
    I guess I have a rattling clutch booster too. And maybe I should check them bolts also.
    #12
  13. Boatman
    Mar 9, 2005
    14,088
    Mill Spring, NC
    Booster gives more pressure in the clutch pack to help keep slippage at bay. This allows the use of lighter clutch springs resulting in a lighter feel at the lever.
    #13
    Salzig, Crazygreek and Peltsi like this.
  14. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,228
    SWEDEN, Norsjö
    No need to unbolt brake lever. Just removing the pin at the back so it can be pushed down a little further and you can get the cover off.
    /Johan
    #14
  15. tomdubz
    tomdubz getting there Supporter
    Jun 29, 2010
    1,270
    4 Cornerstan
    Are the jutter, judder, booster springs all the same thing? And if so, what is it actually called on the fiche?
    #15
  16. Boatman
    Mar 9, 2005
    14,088
    Mill Spring, NC
    I assume he's talking about the "belville spring".
    #16
  17. radmann10
    radmann10 Derf Supporter
    Apr 29, 2014
    1,127
    Phoenix, AZ
    My 990 makes the same noise, pull in the clutch and it stops. It hasn't changed/got worse in 58,000 miles so I'm not too concerned about it!
    #17
    Crazygreek and Boatman like this.
