Clutch cable freeplay
Discussion in 'Parallel World (790/890)' started by robin_nerf, Apr 14, 2021.
  1. robin_nerf
    robin_nerf Adventurer
    May 28, 2020
    60
    Sweden
    I'm a bit unsure of the clutch freeplay, read the manual that is suppose to be 5mm but since this is my first bike (890 Adv R) I'm not sure if the clutch-arm is suppose to move within the freeplay ?
    The clutch-arm seems to move a tiny bit even if I make the freeplay big(sloppy clutch lever), not sure if the clutch can be TO sloppy and it's better to have it sloppy then tight ?
  2. chippertheripper
    chippertheripper motorcycle junkie Supporter
    May 30, 2009
    12,657
    s.e. mass
    Definitely better to have more free play than a dragging clutch.
  3. TrailTrauma
    TrailTrauma Nemophilist Supporter
    Jan 17, 2012
    6,555
    Ontario .. Superior
    Here's what I built into my riding routine - prior to riding, or even getting back on after riding then taking a break .. lean over the bike, and grab the piece which happens to be orange in this photo below (because it is the Camel 1-finger replacement for visual purposes) and jiggle it back and forth. I always look for my slack there, and not really at the lever. Things can change in a hell of a hurry depending on terrain difficulty, your acceptance of traction control (and therefore not continually slipping the clutch!), and so on...SO check it regularly!
    Mud Bucket likes this.
  4. sonoran
    sonoran a treat especial Supporter
    Sep 28, 2009
    57,465
    33°05'38.7"N 111°40'57.2"W
    Measuring free play at the end of the clutch lever is a little challenging. To make it easier I fit a nickel between the lever and perch that translates to approx 5mm at the lever end.
  5. Bighammer49686
    Bighammer49686 Been here awhile
    Mar 7, 2018
    456
    Traverse City, Michigan
    I adjust my cable to remove the freeplay. The roads around here suck and with it more snug to it's perch, the lever seems to vibrate less.
  6. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    8,138
    Star Tannery, VA
    I find sitting on the side of the road or trail with a broken bike more aggravating than clutch lever vibration. Assuming you're serious, you may want to plan ahead and order up a spare clutch pack and carry it with you. This is a really easy clutch to burn up completely if allowed to slip under load. It heats up quickly. If you haven't seen all the photos of crispy clutch plates and in some cases clutch packs that have exploded and turned into broken shrapnel inside peoples motors you might want to take a look. KTM has not been overly sympathetic to those that have destroyed them.
  7. Bighammer49686
    Mar 7, 2018
    456
    I appreciate your concern (assuming you're serious) but I said I adjust it just to take out the freeplay, not pull some length and hold it there. Do what you want and go for sloppy loose. I prefer mine tighter.
  8. windblown101
    May 17, 2010
    8,138
    Star Tannery, VA
    Yep, I was being sincere.
    Your bike, your preferences. No sweat. Just trying to be helpful.
    #8
    Beshar and sieg like this.
  9. markgrolex
    markgrolex Been here awhile
    Jul 23, 2017
    497
    West Grove PA
    he tee'd one up for you here Dan :-)
    #9
    TrailTrauma and Dan D. like this.
  10. Dan D.
    Dan D. Long timer
    Mar 13, 2020
    1,300
    Jacksonville, FL
    #10
    windblown101 and TrailTrauma like this.
  11. TrailTrauma
    Jan 17, 2012
    6,555
    Ontario .. Superior
    I'm trying to do the calculus on whether you might be serious or full retard.
    Then again, those aren't mutually exclusive quantities.
    #11
    TimC63 and sieg like this.
  12. AdvRonski
    AdvRonski They call me......Ronski
    Feb 4, 2007
    1,740
    Finally made it to Fruita!
    I can’t remember seeing a better example of the Dunning-Kruger effect. This should be fun.
    #12
    kirill_k likes this.
  13. windblown101
    May 17, 2010
    8,138
    Star Tannery, VA
    Pretty much.
    "Never attempt to teach a pig to sing; it wastes your time and annoys the pig."
    #13
  14. Bighammer49686
    Mar 7, 2018
    456
    Say all you want, but you are not going to wear out a clutch because the cable has no slack. It's not pulling the cable at all, it's just not loose.
    #14
  15. Dan D.
    Dan D. Long timer
    Mar 13, 2020
    1,300
    Jacksonville, FL
    Assuming temperature has no effect on your initial adjustment/setting.
    #15
  16. kubcat
    kubcat Riding is Eudaemonic Supporter
    Sep 22, 2016
    2,266
    Upstate NY
    The Ghost of Christmas Yet To Come has paid you a visit showing you your future if you won't change your ways, Mr. Scrooge...:grim:gerg mwah ha ha ha
    https://www.facebook.com/groups/ktm790adventurer/permalink/1398982770521520/
    #16
    brianbrannon likes this.
