1. eNewsletter Sign Up
Combined Audio Output
Discussion in 'The Garage' started by Chili, Jul 14, 2007.
  1. Chili
    Chili Mr. Fix-it
    Nov 13, 2006
    49
    Snowbird, Oregon/California
    I want to combine the audio out put from my Garmin Zumo and my radar dectector and run them into my IPOD type ear pods. Both units have their own volume controls, and I am not concerned about a microphone out put.
    I am remembering something about it not being as simple as a "Y" connector.
    Is there a commercially available unit to do what I need?
    Or if someone can post a schematic of a diagram, I could make one up. :bow
  2. Rubber Cow
    Rubber Cow GS Dork
    Jul 9, 2001
    5,374
    Aloha... yes, Aloha, Oregon
    Yes, here's the unit
    http://www.tesseractcorp.com/
    As they point out on their site, Aerostich sells them as well.
    I run a Starcom intercom and can do the same mixing. Autocom will also do this. Both of these brands have a earbud option for the headsets.
    Cheers,
    Jorge
  3. Chili
    Chili Mr. Fix-it
    Nov 13, 2006
    49
    Ah....I was thinking something cheap...no frills, no amplifier, no volume control, just a fancy "Y" connector...if that's possible.
  4. johnjen
    johnjen Now, even more NOW!…
    Nov 28, 2001
    17,012
    If you don't isolate the outputs from each other you run the risk of damaging them. Outputs aren't meant to 'see' other voltages coming back at them. Isolation is often done with resistors, which lowers the output accordingly. Sometimes active electronics are used. Either way the signals need to be boosted back up. If your devices are either cheap or robust enough then the possible consequences of not isolating them (lack of reliability) is of minor importance.
    JJ
  5. Mac
    Mac Long timer
    Mar 18, 2006
    2,240
    Colorado Springs
  6. Chili
    Chili Mr. Fix-it
    Nov 13, 2006
    49
    The Autocomm unit is the kind of thing I am looking for.
    I also found this discussion while looking for a DIY solution:
    http://www.tkk.fi/Misc/Electronics/circuits/linesum.html
    I hate to have my bank account drained by something as small as electrons, when there are cheap solutions out there. :dj
  7. Chili
    Chili Mr. Fix-it
    Nov 13, 2006
    49
    Looks like about $5, maybe $10 to make one up out of my parts bin and whatever I need to buy. :thumb
    Now if it will only work!!!
  8. Rubber Cow
    Rubber Cow GS Dork
    Jul 9, 2001
    5,374
    When you're done with that and need a DIY amplifier build yourself one of these:
    http://www.evilfire.com/altoids/
    A friend of mine and I did and it works great.
    Cheers,
    Jorge
    #8
  9. Chili
    Chili Mr. Fix-it
    Nov 13, 2006
    49
    That's perfect, as I was considering using an Altoids box as a case for my project anyway. Just need to throw a few more parts into it.
    #9
