COMFORTABLE Knee Armor?
Discussion in 'Equipment' started by JustKip, Mar 18, 2019.
  1. JustKip
    JustKip Long timer
    Apr 28, 2007
    8,691
    Fresno, CA
    I busted up my knee pretty good 5 years ago (tibial plateau - Schatzker type 5) and did quite a lot of nerve damage both in the wreck and surgery. The CE armor in my First Gear and Tourmaster pants is painful to start, and unbearable after just a few minutes. I like the idea of armor, and like overpants in cooler weather, but the 2 I've tried are completely unacceptable(and the armor I was wearing did nothing to prevent hyperextension that caused the break). Is there anything out there with soft edges or plenty of neoprene padding, that won't irritate an already uncomfortable and overly sensitive to touch area?
    Schuk and Snake Oiler like this.
  2. levain
    levain STILL Jim Williams Supporter
    Oct 29, 2005
    10,209
    Charlotte, Vt
    Grreatdog likes this.
  3. tntriumph
    tntriumph Adventurer Supporter
    Sep 20, 2016
    74
    Smoky Mtns of TN
  4. shrederscott
    shrederscott Long timer
    Mar 19, 2014
    2,701
    denver
    HI
    I would avoid D30 pads...they are soft and comfy only when warm ...in cooler weather it gets hard and stiff and uncomfortable.
    I suggest forcefield pads ...they are temp stable ..work great for impact.protection.
    For the type of injury you had only a knee brace will offer protection. .. and then in an injury it may simply transfer the force to your leg bones and break them.
    No perfect solution
    Good luck
    Scott
  5. cblais19
    cblais19 Long timer
    Nov 3, 2017
    3,072
    NoVA
    ++ for Microlock. I've tried all the molecular/soft armors and the Knox is by far the most compliant at all temps. Forcefield Isolator is also good, but has a stiffer matrix at all times. I've got a bunch of Isolator CE2 pads that I'm actually replacing with Microlock due to the comfort difference.
  6. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    4,017
    Pennsylvania, but living in a toy hauler full-time
    Just caught the posting. I'm in the same situation and looking for an armor for my knees. The tube stuff look interesting but the concern is the compression factor to hold them inplace. With the nerve damage I have I'm afraid it could become very uncomfortable in a,short time.
    I was pointed in the direction of the forcefield Pro v2. But thought I'd ask if you have found a solution that might be good to try.
  7. JustKip
    JustKip Long timer
    Apr 28, 2007
    8,691
    Fresno, CA
    I'm still riding naked. Just riding less. I'm with ya on not wanting continued contact. Any touch is uncomfortable , and worse than last year.
  8. Snake Oiler
    Apr 22, 2016
    4,017
    Well going with out really wasn't an option I'd considered. Damn I was hoping for a better idea on which direction I should explore
    #8
  9. Tor
    Tor Making Life A Ride
    Nov 27, 2005
    2,516
    Asgard
    I am using Klim Badlands jacket and pants. The pressure on my knee cap from the D3O armor in the pants were unbearable after a couple of hours sitting on the bike with a bent knee.
    I changed to Forcefield armor, which is thinner. It helped some, but still gets uncomfortable over time. Looking for a solution myself. If the armor had an opening right where the kneecap is, but still protects, due to thickness, I would probably be good. I might carve a hole in the D3O, just to try.
    #9
  10. DCrider
    DCrider Live from THE Hill
    May 7, 2008
    8,306
    Washington, DC
    #10
  11. BoilerRealm
    BoilerRealm Been here awhile
    Mar 4, 2017
    289
    Soddy Daisy, TN
    Its not near as thick and tough, but the new Rev'it Seesmart armor is very comfortable. I'm sure its not the best protection, but it is CE level 1 certified.
    #11
    Snake Oiler likes this.
  12. cblais19
    cblais19 Long timer
    Nov 3, 2017
    3,072
    NoVA
    The softest high protection (CE2) armor I've found is the Knox MicroLock. It's more pliable then Forcefield, SasTec, or D3O; and has a softer feel when joint pressure is applied. It's /really/ good stuff, and I've switched to it for my jacket. I'm using the Forcefield ProPants as my leg armor solution, and they're still pretty good - but I might try switching the knee armor in them as well, since it does start to get tiring after 6-7hrs.
    #12
    Peanut_Buttery likes this.
  13. SRTie4k
    SRTie4k Northeast Explorer
    May 11, 2009
    2,682
    Nude Hampster
    I've never found the Rev'It CE2 knee armor very comfortable. It's not pliable enough.
    Ironic, considering all I own is Rev'It gear.
    #13
  14. cblais19
    cblais19 Long timer
    Nov 3, 2017
    3,072
    NoVA
    Note that he was talking about the super thin SeeSmart stuff, not the CE2 SeeFlex (which yes, is very heavy and rigid).
    #14
  15. Snake Oiler
    Apr 22, 2016
    4,017
    I was reading about the Knox Microlock. Some good reviews I've seen. Also the forcefield pants or Bohn pants, which the Bohn is only level 1 from the way I've read. The thought was maybe try a larger pant size of one of those and if it is not bothersome to get a better level 2 from Knox for in tgem.
    Another thought was the forcefield back protecter which is layered and cut it to size for the knee armor. But not being a formed shape could cause a problem.
    #15
  16. shinyribs
    shinyribs Thumpers for life
    Sep 24, 2011
    5,776
    The South
    Dainese makes the best armor. They call their standard armor "composite armor". It's a hard shell plastic with a foam/fabric backing that actually hinges, breathes and wicks. I recently tore up a knee after hitting a deer but I can still wear my Dainese pants and not feel the armor.
    Compared to the sastec junk that just came in some new Scorpion stuff I was trying. Obviously Dainese understands that knees and elbows aren't the same...
    #16
  17. Snake Oiler
    Apr 22, 2016
    4,017
    Now do those fit into a pant leg or strap directly to the leg?
    #17
  18. shinyribs
    Sep 24, 2011
    5,776
    The South
    You can get them both ways. But you'd be hard pressed to fit Dainese armor in to another brands pant leg just based on it's sheer size. Massive coverage, but slim and not bulky.
    #18
  19. Snake Oiler
    Apr 22, 2016
    4,017
    Thanks for your help. I'll have to check them out. I've been just dealing with the pain from the klim badlands and alpinestar pants. But it's getting worse over time. So it's moved to the top of my list.
    #19
  20. shinyribs
    Sep 24, 2011
    5,776
    The South
    I bought a used pair of Dainese jackets/pants on a whim and I'm not usually a gear snob, but I was very impressed with the armor and have become spoiled to it. Dainese does armor and leather very well, unfortunately their textiles seem to be mostly comfort driven and not built out of the heartiest materials. It's pretty annoying.
    #20
